Bouancy hacked?
Started by Cherryman, January 23, 2010, 05:19:59 PM
Cherryman
Hello all,
(I posted this also with the "neigbours" but i'm curious of opinions here as well too)
I was sitting in the bathtub and playing with an empty bottle. The bouyancy force while pushing something under water is quite noticable.
I started thinking how to utalize this.
So i came up with a concept and would like some opinions.
I think that the bouyancy of a submerged object can be utalized by using a balanced rotating setup.
The force it takes to turn a balanced wheel seems less then the force created by bouancy.
If that is true, then you can think of utalizing it. This can be mechanical, electrical, or whatever you think of.
I made an example animation and a picture, with a linear generator. (But this could also be a mechanical setup)
The tubes are filled with water, and two have magnets inside with floating endcaps, this will also streamline the waterflow.
The other two tubes have magnets with caps that doesn't float.
When you turn the wheel, it stays balanced, so the force needed to turn the wheel could be less then the bouyancy/sinking created.
Its just a concept drawing, not in scale. Magnets are a bit large compared , to the floating caps. The magnets with the green caps float, and with the red caps sinks.
(PS. I noticed in the animation a strange jump.. sorry for that)
Link to animation:  http://nl.tinypic.com/r/2ppg46w/6
Cherryman
For those wondering.. Push am empty bottle below the water surface and feel the force!  ;D
mr_bojangles
what if instead of using 4 tubes, you used 2 (connected through the middle)
if you use the floating ones, maybe it could be overbalanced even
i like the use of the "faraday flashlight" method,
"If at first you don't succeed, try, try again. Then quit. There's no point in being a damn fool about it."
-WC Fields
infringer
very nice design you could use this as a turbine blade make them more efficient ...
Or a standalone depending...
REGISTER AND BECOME A MEMBER RIGHT NOW!!!!!
........::::::::: http://www.energyinfringer.com  :::::::::........
"""""""everything is energy and energy is everything""""""
-infringer-
Cherryman
Actually, the design has many possibillities... I have several (drawing stage already)
But does anyone see a problem with the concept? :
Bouyancy will exceed the turning of a balanced wheel
