Magnetic amplification and neutralization motor by Art Porter
Started by LarryC, February 20, 2010, 05:07:38 PM
synchro1
Quote from: alextecmen on October 20, 2020, 04:00:37 PM
Windows
Press the Windows key + Shift + S.
You can drag to select a portion of the screen to capture. The screenshot will be copied to the clipboard, which you can paste into another program. May 18, 2020.
alextecmen
thanks synchro1 for the guidance
Magnetic
these are the magnets i am using
alextecmen
In this structure install the coil and magnets.
I have to improve some things to have the expected effects
I see that this experiment is no longer interesting to you, since they are in other experiments, but with your comments and information or guide that you provide I can improve it.
Thank you all
alextecmen
Returning to work, continuing with the prototype and project of the researcher Art Poster.
Change the coil for a larger one with thicker wire, this coil already had it, it is a bifilar coil, 20 gauge, the core is made of welding rods, they are a little outside the coil, I used it in other experiments , and remember that there it was saved, well I said I'm going to try this coil, to see what results I get.
Install and adjust the coil, make the relevant connections, to see the effect of the emf induction, connect a 12 volt, 21 watt car light, apply 24 volts DC.
The energization and shutdown of the coil was done manually, I connect and disconnect by touching and not touching one of the power cables.
Now if I already get a little but significant lighting in the focus, which indicates that I am moving forward.
The connection and disconnection of the energy to the coil, the faster it was done, the brighter the bulb, for now I don't have a relay, or a signal generator, I'll get them.
But I have an idea that I will use to connect and disconnect.
Now that I have more progress, I am going to build the coil to Art Porter's specs, and get her 3 "magnet.
If Mr. Art Porter obtained acceptable results, taking advantage of the magnetism in opposition, with the return of the fem. I think one can also make progress.
