Magnetic amplification and neutralization motor by Art Porter
Started by LarryC, February 20, 2010, 05:07:38 PM
synchro1
Art's coil is shaped to 1.5 to 1: I very carefully measured Unity with your kind of setup! I am using an Electromagnet:
https://www.youtube.com/watch?v=fL7-60ZZa10
synchro1
Take a look at the shape of this 640 pound force electromagnet. The core is a high perm material! This is the kind of force you need to balance the very high strength Neo disks you are using! This gets tricky because it's a W core. Poles on rim and center:
alextecmen
Thanks synchro1, for your information, the very interesting video, and the 640 pound force electromagnet can be used for the Art Porter generator, I think it would be super better
Well over here, continuing with the project, I gave myself the task of making a mechanized switch, for energizing and cutting power to the coil.
With enthusiasm and wanting to achieve better results, I took on the task of using a Rotate Drill Grinder, I adapted a plastic disc with a transformer sheet, sand it and cut to the size of the disc about 4 cm in diameter, like this It had a sheet traversal to the plastic circle that held the drill.
This small adaptation is simple but very meaningful for me, so I can switch the energy of the coil, and get the return of the emf, and energize the focus.
All installed and configured, I turn on the drill at its lowest speed, and manually make contact with the center of the sheet and the other wire on the periphery of the circle, and thus have the ignition and cut of the coil power.
The brightness of the focus is very good, let's say about 80% to 90% or more, since it depended on the good contact that was made in the rotor.
Check the amperage consumption in the direct coil with 24 volts, and it was 2.66 amperes, then checking the amperage consumption already in the coil's on and off operation, the amperage varied from 0.4 to 1.5 amps, and the brightness was variable Also, what I appreciated on occasions at 0.4 amperes had a good brightness, I also noticed that when I made more contact on the switch disk, and the speed was lowered, good brightness was obtained, that is to say, on occasions it had more speed of swchit, it did not obtain more brightness .
I increased the speed of the drill, and the bulb did not turn on much, that is, at a higher speed, the induction did not improve.
I built another disk, now with another conductive strip, the conductive strips were in the shape of a cross, that is, at every 90 degrees the coil would be connected to the energy.
With the new disk (every 90 degrees connection) the brightness, the light of the spotlight increased, much better.
I have managed to advance, and I still do not have the ideal, that is, that the work and the prototype with which I am improvising, is with coils that are not yet those specified by Art Porter, with core of welding rods, without relays, but all that helps me to advance and improve.
I will continue to advance and improve the materials of the prototype.
Thank you again synchro1 for your contribution, you can only provide the link of the electromagnet that you showed.
Friends continue with your projects experimenting and testing your ideas or replicas, good luck to all
synchro1
amazon.
