Magnetic amplification and neutralization motor by Art Porter
Started by LarryC, February 20, 2010, 05:07:38 PM
alextecmen
I have new rotors to test with the drill, the contact strips that I have used is one, two in the shape of a cross (four contacts per revolution), I am going to make one with eight contacts per revolution, I am also going to get a solid core, and see the difference of induction. I think all that will improve
Thank you  synchro1 for your information, let's keep working and building with the contributions that each one inform
alextecmen
The drill that I am using is like one of these at the lowest speed, I adjust the discs that I build and adapt to the shaft
synchro1
Suspend a magnetic object by a rubber band over the top and see if you can get it to attract and jump while stretching with the power pulse.
alextecmen
Quote from: synchro1 on October 23, 2020, 03:43:24 PM
OK good as soon as I can I do it to see the effect of magnetism
alextecmen
Okay. Continuing with the work, I built or assembled another rotor with 8 strips of transformer plates, balanced them on a plastic cover, and then fastened it to the drill, as you can see in the image.
Apply 24 volts to the coil. and I have configured the 12 volt car light with a diode to take advantage of the energy from the back fem.
By rotating the disk with the drill, I manually make contact with the wires in the contact bars, and the light starts to turn on, with this rotor with more blades, I further improve the brightness of the light, and the consumption of the coil. It is variable.
What I observe that sometimes there is very good brightness and speed of the disk and current consumption about 1.5 amp, but it also happens that sometimes I do not have much speed (due to greater pressure that I make on the contacts), and I get very good brightness and low current draw 0.9 to .06 amp more or less. it means that you have to find the right pulse or operating frequency, just like Art Porter did.
Then change the source for another 24 volt but higher amperage, in vacuum gave 33 volts, and with this source I get more lighting, I have not tested the circuit with battery, but I will.
With this new source when the bulb had good lighting, the voltage dropped to 25 volts and amperage from 1.5 to 0.5 amps, and as I said it is variable because sometimes it has very good brightness and low consumption.
I will continue with changes, I am going to change the core rods and put a solid core on the coil, I ask you friends, will it improve the induction, I think so, I await your comments.
I'm going to buy a relay, I'm going to see how to make a signal generator.
What I have done is move forward, so that I can create the Art Porter prototype with its recommendations and characteristics, if it worked for Mr. Art Porter, it should also work for us.Thank you soonModify message
