Pulsed DC Transformer with Embedded Magnets
Started by ltseung888, February 24, 2010, 03:55:56 AM
0 Members and 170 Guests are viewing this topic.
Charlieb000
Quote from: SchubertReijiMaigo on December 27, 2010, 06:42:55 AM
If you can extract it (or rather convert Reactive energy into useful energy) via a motor or a transformer, why ?
Because creating magnetics (or electric) fieds cost nothing in real energy loaded or not if properly tuned.
This is why the rotoverter can be OU but you need to tune for each different loads the tank, (this is why some experimenter have failed, they are happy to run at idle a big motor at 60 watts but "forget" to retune when they loaded it. The lenz law decrease L untune LCR, destroy Q factor, and in the end you draw more and more real current like any conventional stuff...) If you tune at loaded state you can have one HP (746 watts) with 120 watts of real power (maybe the R losses).........
i do not think the rotorverter is OU, only the "shorted coil" (misnamed) part is overunity.
induction motors get more efficient when you load them heavily. when you have a three phase motor and putting caps on some of the phases you are taking them out of phase with the mains. did you know you can turn a induction motor into a generator? i believe that the caps are turning some coils into generator coils, and putting load on the input coil and viola, more efficient (energy not wasted = free energy). the shorted part is putting energy back into the coil from a capacitor (whicch recieved it in a way like the tesla switch) causing the coil to emit magnetism which attracts rotor.
as for the ugly weirdo square waves (i am talking about spikes), study how a switching power supply works, including how to momentarily turn the thing off when the output cap reaches the desired voltage, then you can monitor the input and output in a sensible mannar.
now i cant stick around all day everyday otherwise it would be as if i was a facebook user!
CB.
tagor
Quote from: Charlieb000 on December 27, 2010, 06:45:33 AM
two stage oscilator video 6:
that one is the only obvious one i know of and it is quite convincing (you find another one on the inventor's website). you can work out the output if you get the formulas on the forces.
http://en.wikipedia.org/wiki/Reactive_centrifugal_force
but this topic isnt about that so i will limit my talking about it.
cb.
I dont understand , where is the video 6 ?
there is nothing convincing on the inventor's website !!
you are speaking of watt , and now you give me a link on force !! , what is this ?
force is not energy
The Observer
Quote from: Charlieb000 on December 27, 2010, 06:17:27 AM
with my replies so far i assumed the topic was still on the pulsed DC transformer, i just found out tsung just changed the device he was talking about without changing the subject (Re: Pulsed....)* and i see all talk about this new device is completely useless, because tseung has not given us any workable information causing people to comment on what they dont know...
can we keep the subject on what we can use - please?
*amittably when you click on reply down the bottom, the subject is automatically set to the topic name - which can be modified, but is better is to start a new topic if you have a new device.
Charlie,
Thanks for you comments.
You are obviously very sharp and we appreciate your time.
--> As far as topic name goes... it does not need to be changed. <--
     Why?
         A Common Joule Thief is a Pulsed DC Transformer with Embedded Magnets. (what LT is using with a resonant circuit)
             It's output is the result of the Magnets Turning under their own power (Anisotropic Energy mixed with Magnetic Energy) after the pulse.
           The Embedded Magnets are Extremely Powerful, Atomic Sized and Rotate on a Dime.
           Their Density and Strength are reflected in the parameter known as Magnetic Permeability.
           This is why you need a Large High Permeability Core to make a JT light a CFL for the better part of a day.
You actually may be able to comprehend the following.. most don't (or at least think it's amazing).
A Piece of FerroMagnetic Material can AMPLIFY the Field of  a Coil by 1,000 to 1,000,000 times without using any extra current !
I believe when we all start talking about this... we will really be getting somewhere.
GodSpeed,
                The Observer
ltseung888
Prototype A should be in the hands of the Physics Professor within the next few days.  I expect that he will following the academic procedures and the report will take longer even if the results are positive.
Prototype C and a components package have also been shipped out via Federal Express this morining.  The receivers are Bob Boyce and Major Todd Hathaway.  They are both very well known in the alternative energy field.  They will report the results much sooner.
It is conceivable that FLEET leading-out or bringing-in energy from the surrounding environment can be confirmed in USA before the end of 2010.
Thanks to the Almighty.  The Energy Crisis is over.
XS-NRG
