high rate magnet leaching a.k.a don smith
Started by philosophymanus, March 24, 2006, 10:19:24 AM
philosophymanus
 He bousted of resonance but it requires a large high voltage super capacitor to acheive OU with such tactic. The idea is to capture  most of the voltages at megahertz levels but I couldn't find any diodes to use at such levels so I settled with the fastest diodes I could find and they were usable only to 20kh . Luckily, I found out the old farts been avoiding such impossable demands by just wrapping his resonant coils not around air core material but resonanting a coil using a crystal oscillator (5volt) .The surrounding resonant coils don't pick up OU amounts of energy via resonance. But, simply trigger oscillation in surrounding coils 20hz which if wrapped aroung magnets in the correct fashion will leach roughly 5volts off magnets per cycle. Understand?
philosophymanus
Quote from: philosophymanus on March 24, 2006, 10:19:24 AM
He bousted of resonance but it requires a large high voltage super capacitor to acheive OU with such tactic. The idea is to capture? most of the voltages at megahertz levels but I couldn't find any diodes to use at such levels so I settled with the fastest diodes I could find and they were usable only to 20kh . Luckily, I found out the old farts been avoiding such impossable demands by just wrapping his resonant coils not around air core material but resonanting a coil using a crystal oscillator (5volt) .The surrounding resonant coils don't pick up OU amounts of energy via resonance. But, simply trigger oscillation in surrounding coils 20hz which if wrapped aroung magnets in the correct fashion will leach roughly 5volts off magnets per cycle. Understand?
obtw I think the beardin (spelling?) motionless transformer is simply doing the same.
hartiberlin
Can you post a picture please of your device ?
What kind of output toinput power level do you get ?
Thanks.
philosophymanus
 Hi Mr. Hartman
Perhaps I'll post pics but I have to admit to being as bad as Don Smith when details are given. Thank you for asking. Don't waste your time on any similar looking attempts to Don's pics on his site. I spent lots of money and time studying his said tactics and He failed to mention a number of things such as the fact that frequencies above 20hz can't be converted to a usable D.C. .The diodes on the market just can't produce clean d.c beyond 20hz .His devices don't work unless you apply a source of free energy (magnets) to them. At the moment I'm working on a second alternator in an attempt to duplicate Tilley's fashion of free energy. The first one failed but I'm very excited about the improvements done on my second attempt. I have alot of faith in this second attempt and will definitely look into patenting it and I'll feel safe in posting pics of disassembled alternator.
Oh, by the way the amount of energy feedback is limited only by how many magnet/coil units you tie into system.
Mica Busch
Correct me if I am wrong... But mains 110/220 AC is 60hz, and is daily converted to DC with on-the-shelf diodes. However, I assume we are not dealing with a sinusoidal current/voltage.
From what I can tell [in my Limited understanding] then is that the primary or triggering coil, which is driven with 5 volts or so, drives the surrounding coils wrapped around magnets to act as the secondary of a pseudo-transformer, somehow drawing power out of the magnets. This is how he separates the input from the output, which was the reason for the capacitors in the first instance. By driving only one coil at a certain frequency, surrounding coils can interact [based on windings] with this frequency, building upon it, and putting power out, without having to filter that output from the input as when the input and output coils are one and the same. I think I see what is going on...
