Electrical igniter for gas engines A keystone to understanding by Magluvin
Started by Magluvin, March 01, 2010, 01:30:50 AM
Magluvin
Thats the problem Teets, and I suppose you are just getting that now, we dont get it.
We wish we could get it. But none of us do.
It would be nice if someone told us that they knew how to make Lemonade with water sugar but would not give us the last ingredient. One of us just might be able to figure it out that last ingredient.
But you tell us that you know how to make a club sandwhich, but the only ingredient given is white toast, most all of us will most likely be making the sandwhich quite a bit differently than yours and not get the same taste. That is if nobody knows about the club before you say you have it.
Your idea of clues are not even close for anyone to get what you have. And you know this by now. Yet we keep hearing from you like you are really giving us something. There are many hear eagar and willing to put in the effort. But we wish to know more and be more sure before we are led down that unkown road for nothing. It happens a lot and most are tired of it.
I saw something in this patent before you brought it up that you had seen something in it much earlier. But Im not seeing it now as I percieved it from the begining.
You can talk dominos all day, but it does not help without some basic comparison.
Mags
ramset
                                          8)
                                          8)
                                          8)
Teetsla
Quote:
I said for every pulse there is like a domino effect happening ok.
"Like" How?  Like "Magic"?   :o
Teets,
When an OU event happens,I am sure it would or could look like "Domino's".[cascade]
SSOOoooo..............
How does it happen?
Chet
PS
Teetums
If I were you I would ask this guy ->   <- what to do.
I don't think he revealed this to keep it a secret.
The same secret that drove Tesla mad!
The Truth shall set you free!
Thanks Grandma
sparks
  Mags
   Checkout the Papps Engine.  It uses an electrical ignition system of sorts. The funny thing is that it is exploding inert gas over and over and over again.  As the gas condenses or is restored from a plasma to a gas it sucks the piston forward.  Then the fusion catalyzed explosion and repeated an timed as necessary.  The power comes from the restorative force of the atom.
This force sets up the dominoes.  The electrical ignition system knocks em over.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
wattsup
Quote from: sparks on April 22, 2010, 09:35:21 PM
    Followed by a great number of implosions
"To get a stellar implosion (leading to a supernova and then either a black hole or neutron star), the fuel at the center of the star gets used up, and the core cools rapidly. The pressure that has been holding up the outer layer drops, and the outer shells start falling toward the center. The gas has a long way to fall (the radius of a red giant can be as large as the distance from the Earth to the Sun) and builds up a tremendous speed. It all meets at the center, at which point most of the mass rebounds into a supernova explosion. About 20% of the mass gets compacted at the center and either forms a neutron star or (if the original star was really large) a black hole."
That's it. How fast do you think that supernova was traveling in space ether just before it blows up. Once it blows, some particles will travel in the opposite direction of its travel and if they move out fast enough, will in essence for a split second be in the same space, not moving in ether and just disintegrate and turn into tiny black holes. If there is enough matter surrounding these blacks holes, the matter will fall towards the holes and the holes will get bigger and join together. At least that's how I see it. It's not one black hole but many smaller ones that agglomerate. All the conditions have to be just right, proper mass speed, proper explosion strength, proper counter direction velocity of propelled mass, proper amount of available mass (wood for the fire) surrounding the black holes, etc. That's why they are so rare.
@all
This generous ether is available. Let's say you can get 1 volt from a single wire aerial line connected to a radiant energy circuit that outputs 1 volt onto two wires, positive and negative. You can grab 1 volt per second or 1 million 1 volts per second, it's up to you and it will always be available, but only 1 volt. What do you do. You know the 1 volt will charge a capacitor very very very quickly. So what do you do? It's there for the taking.
Tesla has shown that a capacitor will eagerly accept and store that energy. So again what do you do. Well...........
In 99% of cases, guys are just amplifying the 1 volt into 5 volts but all that does is raise the volts and decrease the amps. So you are basically playing like a yoyo and getting no where.
You could also play the coil to coil game but again, there will be more and more losses to overcome.
This is my idea on how to harvest it.
http://www.overunity.com/index.php?topic=8185.msg237431#msg237431
With such a circuit, you can grab as much energy as you need, anywhere. You can make more stages or more units and parallel them. You will not be stretching out the voltage and quickly produce real voltage and amperage.
I will open a new thread on this idea today or tomorrow. Just busy with so many other things. lol
DreamThinkBuild
Hi Wattsup,
Here is a patent you may be interested in.
http://www.google.com/patents/about?id=bl0LAAAAEBAJ
Figure 4 is similar in some respects to your design.
Another switching design, using supercaps.
http://www.google.com/patents/about?id=nVoOAAAAEBAJ
If you combine these 2 patents you have a dc power source that could possibly run from an electrostatic generator or piezo element.
