Electrical igniter for gas engines A keystone to understanding by Magluvin
Started by Magluvin, March 01, 2010, 01:30:50 AM
wattsup
Quote from: DreamThinkBuild on April 23, 2010, 10:03:39 AM
Hi Wattsup,
Here is a patent you may be interested in.
http://www.google.com/patents/about?id=bl0LAAAAEBAJ
Figure 4 is similar in some respects to your design.
Another switching design, using supercaps.
http://www.google.com/patents/about?id=nVoOAAAAEBAJ
If you combine these 2 patents you have a dc power source that could possibly run from an electrostatic generator or piezo element.
Those patents are close but not quite the same. But in general guys will get the idea that capacitors can be charged individually, then put into parallel before they are all discharged into a bigger, then do the same to the next bigger cap until they are all charged and then all discharge into an even bigger cap. Make as many stages as you want.
i think it was during an interview that Tesla said you can do this and get millions of volts. lol
I maybe should not have posted on this thread so I am sorry for that. I will open a new thread on this and again sorry for interjecting.
the_big_m_in_ok
Tito L. Oracion said:
ok!
its like a multiplication effect.
or divide and conquer. ;D
LIKE A BOMB EFFECT!
THE REACTION OF A COIL INTO ANOTHER COILS AND TO OTHER COILS AND TO OTHER COILS AND SOOOOOO ON.... HMMMM......
Okay...maybe I'm understanding what some of you are getting at.
Don Smith implied, or actually stated, any number of coils can be placed near each other and achieve overunity as long at they're all in resonance.
That's the 'infinite' I took away from what I read on the thread.  If so, I agree with Tito.  I'm winding coils by hand now for a high frequency, low voltage(read: fairly safe) system to experiment with in my apartment.
--Lee
Tito L. Oracion
Quote from: wattsup on April 23, 2010, 09:10:20 AM
That's it. How fast do you think that supernova was traveling in space ether just before it blows up. Once it blows, some particles will travel in the opposite direction of its travel and if they move out fast enough, will in essence for a split second be in the same space, not moving in ether and just disintegrate and turn into tiny black holes. If there is enough matter surrounding these blacks holes, the matter will fall towards the holes and the holes will get bigger and join together. At least that's how I see it. It's not one black hole but many smaller ones that agglomerate. All the conditions have to be just right, proper mass speed, proper explosion strength, proper counter direction velocity of propelled mass, proper amount of available mass (wood for the fire) surrounding the black holes, etc. That's why they are so rare.
@all
This generous ether is available. Let's say you can get 1 volt from a single wire aerial line connected to a radiant energy circuit that outputs 1 volt onto two wires, positive and negative. You can grab 1 volt per second or 1 million 1 volts per second, it's up to you and it will always be available, but only 1 volt. What do you do. You know the 1 volt will charge a capacitor very very very quickly. So what do you do? It's there for the taking.
Tesla has shown that a capacitor will eagerly accept and store that energy. So again what do you do. Well...........
In 99% of cases, guys are just amplifying the 1 volt into 5 volts but all that does is raise the volts and decrease the amps. So you are basically playing like a yoyo and getting no where.
You could also play the coil to coil game but again, there will be more and more losses to overcome.
This is my idea on how to harvest it.
http://www.overunity.com/index.php?topic=8185.msg237431#msg237431
With such a circuit, you can grab as much energy as you need, anywhere. You can make more stages or more units and parallel them. You will not be stretching out the voltage and quickly produce real voltage and amperage.
I will open a new thread on this idea today or tomorrow. Just busy with so many other things. lol
hi sir your really a genious hmmmm.....
I salute you again for that  ;)
;D
Magluvin
Well, I can visualize getting energy from the vacuum or aether. The igniter for example. What if the impulse ending abruptly into an inductor, leaves the current and field build continue by way of inertia, inertia that Tesla spoke of.
So that extra climb could be where gain begins. But the cutoff needs to be at peek current during discharge, meaning either immediately, or at peak field rise of an inductor.
So having proper cutoff during peak of impulse, leave the inductor with only 1 place to get the excess energy while winding down from the inertial climb, something you wont get without dc impulse with proper cutoff.
So some very good switching method will be needed, as good as one can afford to get min and max, on and off continuity, and speed/control.  Im not going to let my next whack at this go caveman. =]
I have an idea to just apply this to a pulse motor as the output for cap discharge. And it can be comparatively challenged by setting up the motor as a normal pulse motor. It seems like a logical scheme. Or we could measure sparks. =]
What I want to see from it is, if the pulse motor itself, getting very short reed pulses of higher current into .14ohm big coils, using more power total than the use of the large inductor having less current flowing through it for most of the time to charge the cap to run the motor coils.
I imagine even though there is a variation in rpm and torque, that the power used comparison will have to be calibrated accordingly to find out if more or less power is used either way.
But it will be also a bit more interesting with the motor going along with it. I yike motors.   ;D
Im just getting to the point that I can open the project stuff boxes from the move.
Mags
forest
Mags, switching method is the solution IMHO
The key for all electrical OU devices.
ARC not spark if you are using spark gap, or a proper exact timing compared to LC circuit energy flow.
It's like a ocean wave, if you watch on the shelf sometimes a proper synchronized wave breaks at the peak of amplitude and spread all the energy forward against coast.
In LC energy continuously change form, EM wave showing two faces.If you have antenna then one end of wire is open. If you have a perfect circuit breaker disconnecting antenna at the peak of amplitude of wave energy is accumulated in antenna opened on both sides and here is very abrupt collapse allowing ambient background to take place again . Something like that.I didn't resolved it completely - it's just a theory but very plausible.
Think another way : if that ambient background is returning to its natural position then this energy flow is opposite to first created by your circuit artificial field.Now look what happen : your artificial field if allowed to spread as EM wave (but we shouldn't do that) would be diminished according to the law with square of distance from source.Very fast. Yet ambient source flow is opposite to the center - it is like concentration of field to a point  :o
