Electrical igniter for gas engines A keystone to understanding by Magluvin
Started by Magluvin, March 01, 2010, 01:30:50 AM
Magluvin
Ok  read through some YT problem suggestions and found another way to load the vids and it worked.
http://www.youtube.com/watch?v=akLziSmk8JU
I dont like the changes YT made. I wish it was the same as before.
Mags
Magluvin
Here is another vid with some variations. I found that there is an interaction with the large inductor and the rotor to get it to go faster and added another cap in parallel.
This is getting interesting.  =]
http://www.youtube.com/watch?v=T9XiCMdRSjk
Mags
Magluvin
Just some thoughts on the 2 vids above
It seems that my findings of the motor finding an rpm that is of a frequency that conforms with the inductor/cap charging freq is correct. I have to make timing adjustments of the reed as the speed levels off to get it to go faster. I have had to make these adjustments on pulse motors before, but these are adjustments of more measure, as the phasing between the motor and the inductor/cap goes through phases as the rpms rise.
In the second vid, I am pleased with the speed increase. And the interaction with the large inductor(I just call it that from the patent) and the rotor was something that I came up with after applying a magnet to the inductor core and seeing results. My setup needs to be tightened up and more flexible and I want to have more separation between the inductor and the reed as there might be some interaction.
The inductor, even in the closed loop transformer ferrite core, really affects magnets around it, they pulse, but it does not hardly have any affect on iron. So this suggests that the core of the inductor is not emanating the pulse, it is just modifying the magnets field due to the change in the cores saturation condition from the inductor coil powering on and off. The Orbo effect.
So I thought lets see what the inductor would do next to the rotor, and I saw that it was good. =]
More capacity. In the pat. the cap looks large, as compared to other of his drawings. So more is better so far. Havnt tried more than the 44uf yet.
One more thing that I have seen that I will vid is that I can get the motor setup so that it will run in either direction, not with large inductor next to the rotor, without making any timing changes. Just spin it the other way and it goes. Never had that in any of my pulse motors. In one direction its just a bit faster than the other, but very close. And very interesting.
Gota git. Ill be putting more vids later. There seems to be a lot going on with this that will keep me busy for a while. Im just glad to be able to have the time to mess around again. The move was very stressful.
Mags
Tito L. Oracion
Hi everyone good day
And to mags i'm so sorry but i felt i was first hurt thats why i said that. i'm a peaceful man, the gun is just a toy  ;D
i will just leave it all to God ok.
i'm sorry if i did not do my promise just because of some reason.
i hope in my simple way of giving a little clue hope it helps even just a little.
mags i'm happy for you where ever you are i'm on your side always friend, i don't want spontaneous cruel ok.
by the way don't anymore block me cause i will be the one to stop ok friend?  ;)
maybe i deserve those nutty words from someone but remember, i was first hurt ok.
To everyone i'm sorry please understand me if i cannot give you the best secret i am holding. i am reserving that for my 2 sons ok.
i am happy for all of your success, someday somehow it helps to the world.
Always smile take rest and God bless
happy experimenting
bye friends. This is my final last, but don't worry i'll just be a guest always.  ;D
otits  ;D
Magluvin
