DIY Tesla Switch Guide
Started by geotron, March 05, 2010, 01:23:11 AM
geotron
http://www.energeticforum.com/renewable-energy/962-use-tesla-switch.html
Dr.Lindemann states in reply #2 that the "SG 1524 dual flip-flop"
timer was used.  How does this one differ from a 555 IC?
Also, the diagram I've attached has me curious as well.
I haven't much clue on how these work - battery powered?
Well I guess that besides the various component parts for this
project, the only things I will need to source are -
1) A suitable board to solder things onto.
2) A test meter
3) Soldering Wire
4) A set of four 12v batteries
5) High-Voltage Cables
Additionally I am open to suggestion in this area.
I've had plenty of experience working with metal in a
welding fabrication environment, so perhaps some of it
will bleed through into my work here.
I was kind of thinking that to start out with, perhaps
a set of rechargeable NiMH AA batteries might simplify
things a little... although I have no idea how this
might change my set of required component parts - besides
maybe having smaller diodes.
My plan will remain the same throughout to precicely
duplicate the schematic as presented... After which
providing it works (which I don't much doubt), I will
likely be in a much better position to handle the
construction of different models without so many
questions.
geotron
Here's a nice analog one I'm considering...
Perhaps small individual meters would
prove to be of unique convenience. I know
I've seen them somewhere...
geotron
I see that this might be something I could wire up
by myself.  If so, I may just forgoe ordering one. (edit: make that six)
A local source would be nice - are these commonly found in
at audio shops?
gyulasun
Hi Geotron,
Quote from: geotron on March 05, 2010, 10:08:12 PM
Here you can see SG3524 incl SG1524 and 2524) data sheets, they are still available.
http://www.datasheetcatalog.com/datasheets_pdf/S/G/3/5/SG3524.shtml
The type number difference denotes commercial, industrial (temperature) ranges, no problem for tinkering, you can use SG3524 as the cheapest type, most component sales have them like farnell.com  digikey.com  futurlec.com  etc
I do not think you would need to replace the SG3524 with a 555 timer, the former is available for $ 2-3 apice.
The CD4011 is a quad CMOS NAND gate and a simply RC oscillator is formed with it, the oscillator frequency is adjustable by the potmeter. Yes it needs a DC voltage source like a battery or a small power supply like a wall-plug-in with DC output voltage of 8-12V, depends on the relay coil too.
The MC7805 is a DC voltage stabilizer with a fixed 5V output, the CD4011 is fed by it, helps stabilize the RC oscillator frequency vs input DC voltage fluctuations.
questions.
Well, regarding the four battery type I do not know if NiMH is ok or not, in 1984 the used types must have been lead acid batteries.  The diode type surely depends on the currents involved and the currents depend on the battery AmperHour capacity first, this is the main focus with diodes (and cables). No much need for HV cables, rather for high cross section area ones between the batteries but as I indicated it all depends on AmperHour capacity.
Re on you analog multimeter, it seems ok and it is able to measure DC (and probably AC) currents too.
rgds,  Gyula
Groundloop
@geotron,
All the parts needed to build a close replica of the Tesla Switch can be bought from:
http://www2.mouser.com/Home.aspx
Here is the hard to find parts:
Mouser No:    511-SG3524N
Mfr. #:    SG3524N
Manufacturer:    STMicroelectronics
Desc.:    Voltage Mode PWM Controllers Regulated Volt Mode
Mouser No:    863-MR852G
Mfr. #:    MR852G
Manufacturer:    ON Semiconductor
Desc.:    Rectifiers 200V 3A Fast
Mouser No:    42TL013-RC
Mfr. #:    42TL013-RC
Manufacturer:    Xicon
Desc.:    Audio & Signal Transformers XFMR 1KCT/8CT
Attached is the circuit that Mr. Bedini and Mr. Brandt made back in August 1984.
@gyulasun,
I think Mr. Bedini did use NiCad AA batteries for the "Sigar box" test circuit.
Regards,
Groundloop.
