Fibonacci, platonic solids and Vortex coils
Started by Mk1, March 09, 2010, 10:39:44 PM
ElectricGoose
Quote from: Mk1 on March 13, 2010, 10:19:51 PM
Ok in this movie
http://www.youtube.com/user/abramrk1#p/u/3/wS935WyumjY
The coil has more space between to coils , see what happen to the bulb one the pickup coil when i connect on one the transistor , the bulb on the pickup coil gets brighter , but this not true for the slim , now is it because of the spacing in the pickup coil or the one on the jt , i am still not sure, sorry ...
The 45 degree angle slope seemed logical but lab experiment will be needed to have a definitive value for that slope.
I did notice a big improvement (in voltage output) over my first one that had a 15/75 slope.
Mark
Thanks Mark!
Perhaps less truly is more!
E-Goose
Mk1
Quote from: ElectricGoose on March 14, 2010, 01:15:27 AM
Thanks Mark!
E-Goose
I just finished testing a few suggestion , and tested the slim one the bulb gets dimmer with one on the transistor ...
I also tested a choke one the secondary output , it barely worked .
Also Watson from Watson blog , told me to use 2sd965 from the fuji circuit
it works pretty well . He also mentioned the nte11 , i will get a pair one nte11 and one nte12 .
ElectricGoose
Quote from: Mk1 on March 14, 2010, 01:31:28 AM
I just finished testing a few suggestion , and tested the slim one the bulb gets dimmer with one one the transistor ...
Mark
Not sure what you meant "bulb gets dimmer with one one the transistor"??  Regarding the choke...you attempted to use this as a secondary pickup coil OR to smooth the output of your already existing secondary?
Nte112 UHF schottky diode?  Might clean things up somewhat.
E-Goose
Mk1
Quote from: ElectricGoose on March 14, 2010, 03:19:04 AM
Mark
E-Goose
If you look at the video when i connect the bulb on the transistor the bulb on pickup coil get brighter that is the one with the taller core , but with the slim one when i have a bulb one both the transistor and the pickup coil they get dimmer . Btw this is what i mean when i say loading the transistor.
Choke was to smooth the output of your already existing secondary .
Nte11 specs :
http://www.datasheetcatalog.com/datasheets_pdf/N/T/E/1/NTE11.shtml
Mark
ElectricGoose
Quote from: Mk1 on March 14, 2010, 03:52:10 AM
Nte11 specs :
Mark
Ahh...I didnt pick that up in the vid.  Hmm...perhaps this indicates that the primary prefers a harsher angle to the winding (I assume being deeper former, it WAS a little steeper than your little one?)  Problem is, there are so many variables here, it might be that and might not be.
E-Goose
