Bruce's Discovery, Tesla's Missing Link for his Unipolar Generator!
Started by Bruce_TPU, March 21, 2010, 07:22:45 PM
gravityblock
I've been thinking about building a large diameter magnet out of many wedge magnets similar to the second image of this post, http://www.overunity.com/index.php?topic=8852.msg235126#msg235126
In our case, we would put a thin piece of metal between each wedge magnet in order to eliminate any gaps between the wedges, because the wedge magnets will want to repel each other.  We would also want a small inner diameter to fit our shaft.  This should give us the best uniform field.  The only downside is we would need to either have long wedges, or start another ring of wedge magnets inside the larger ring of wedge magnets, and have a ring of metal between the outer and inner rings to eliminate any gaps.  The inner wedges would need to be shaped at a different angle than the outer wedges.  This setup should strengthen the pole faces.
What do you think?
GB
Bruce_TPU
Quote from: gravityblock on April 11, 2010, 01:38:46 PM
What do you think?
GB
Hi GB,
It's not a bad idea, but if I'm not mistaken, those magnets are not all North pole up, or visa versa, so again, you are faced with the same thing, meaning that they would not be touching.  Which I do not see as needed.  My personal motto is always the K.I.S.S. method.  LOL
I like to keep things simple until proven that I must do otherwise.  I really think you would be fine, using regular (less expensive) magnets, either round or square (on inner part).  With mine, I will be using the most powerful magnets, and at 1" thick, they will give me a very strong flux field, I have no doubt.
I also have a friend of mine, from Church, who is going to assist me with using a very small motor to drive it.  He is VERY GOOD at the use of pulleys.
Today, after Church, I went to check out a device he and his step dad have been working on... He is attempting to use a 3/4 HP motor, rated at about 1100 watts, to turn a generator that is rated at 2200 watts output when driven at 3300 rpm.  This normally is done by using a 5 hp motor to turn it.
He then has the motor, also plugged into the generator, so that when he throws two switches, the motor will self run.
He is short about 600 rpm.  They calculated a pulley size incorrectly and will be trying again tomorrow with a smaller pulley on the generator.  From a 3" to a 2".
He spun it up for me, and switched it to self run, one of the belts flew off...LOL nearly hit me, but it was very cool!  Will it work?  I should know this next week.  Their idea of power measurment is that the motor is being self run by the generator...LOL  Works for me!
Anywho, I am taking some pieces in this week, to be welded up, and for my shaft to be cut.  Time to roll on this!
Cheers,
Bruce
Airstriker
Hi Bruce,
This pulley transmission concept of your friend's is pretty funny ;] I don't really understand people doing these things - how a hell do they want it to work ? Waste of time, machines, nerves etc. ;]
Bruce_TPU
Quote from: Airstriker on April 15, 2010, 07:22:23 AM
Hi Bruce,
Funny or not, they are pretty determined!  They believe they can get the large generator up to correct speed, using pulleys.  Their small little motor sure can spin it up, the way they have it rigged.  They just lack about 600 rpm from having the generator at proper speed...BUT, I explained to them, that when the motor (or any other load) is plugged into it, that is when it will cease working...but the say that they can just add some more pulleys...
In their defense, they own a log splitting shop and they really do use some pulley's there in amazing ways...LOL   It's a deep woods, country thang!
@ALL
I am hoping to pick up my pieces from a shop today for my BRUNG Generator.  I am having the piece that will hold the shaft, riveted to the metal discs.  And today I drop off the rod to have it cut into several small pieces to use as needed for my two shaft pieces.  I will show some pics, as soon as I get it.
Cheers,
Bruce
wattsup
