Bruce's Discovery, Tesla's Missing Link for his Unipolar Generator!
Started by Bruce_TPU, March 21, 2010, 07:22:45 PM
Bruce_TPU
Evening ALL,
I am going to continue to wind more pancake coils, but then I will also be winding an entire set of Tesla's bifilar pancake coils.  This way I will be able to test with both sets when the time comes.
Current pancake coil:
Ohms  .7
40 feet
12 awg
stranded-42 strands
Cheers,
Bruce
gravityblock
Quote from: Bruce_TPU on April 18, 2010, 05:44:43 PM
@ ALL
I am coating first coil with laquer and have a picture below.  It took every bit of 40 feet for a 10" pancake coil.  So... 40' x 42 strands gives me...1680 feet worth of wire, for magnetic flux field to produce power~!   ;)  With 6 coils, without thin iron powder disc would be about 1.25" seperation between huge magnets (I may be able to throw in a few more, need to see where the strength of the N52's diminish... If any one has some, and a way to test flux field strength vs. distance, please post for me here, inquiring minds want to know.
Cheers,
Bruce
What about a paper clip test?  See at what distance a paper clip will attract to the large magnet, then double this distance since the coils will be sandwiched between two magnets.  This may be a good starting point, then you can subtract coils until you find the best results in your testing.
GB
Bruce_TPU
Quote from: gravityblock on April 18, 2010, 11:12:49 PM
GB
Hi GB and ALL,
That's a simple idea.  I may end up purchasing a gaussmeter.  I have been wanting one anyway.
I have decided to coat the top layer of my pancake coils with a thin layer of black iron oxide/laquer, after much thought.
I researched a letter that Tesla wrote a friend, about his fueless generator, yesterday.  Interesting.  I am more convinced than ever that the unipolar generator combined with his bifilar pancake coil was it.  The bifilar pancake coil shows a voltage gain of 900% over what classical science calculates should be there, from a graph I saw yesterday, as well.
I am glad that I will be winding both.   ;)
Cheers,
Bruce
Airstriker
Hi Bruce,
Any chance of seeing this letter and graphs you're talking about ? Thanks in advance.
e2matrix
Quote from: Bruce_TPU on April 19, 2010, 08:36:43 AM
Hi GB and ALL,
Cheers,
Bruce
I know that you have a great deal more knowledge about this than I do but I have to ask why the iron oxide coating since it seems counterintuitive to me.  I'm sure there is something obvious I don't know but it just seems it would tend to block the fields from reaching the copper in the coil OR it would hinder flow along the copper.  I'm at least hoping you may save one uncoated to see the difference between the two.  All this is just based on an intuition - which has been known to be totally wrong before though   :)
