The problem with making a magnet motor work!!!
Started by jacko, March 22, 2010, 02:36:14 PM
jacko
The problem to making any magnet motor is to get past the sticky spot. As you all know that's the point where the magnet or magnets are pulling more than pushing,or visa verse!!! With most designs they use some outside influence to overcome this problem. OK, this may help, but they will never be able to release the full power that is there to be found,or used. If a magnet motor can't run freely then we can never get full power. So how do you solve this problem???? Well I think it can be solved by having no sticky spot. A magnet motor will only be taken notice of when it runs and is able to give useable power. Lets forget about making a motor that generates power and just think about a power source that can be used to turn a generator. We have  loads of generators, we only need a way to turn them.So if you think magnets and getting everything turning then you're going down the right road.....
Mk1
The problem is the shape of the magnets , and failing to see how they work.
happyfunball
The problem with using solid granite as a fuel is, it's not combustible. That is solid granite's sticky spot, so to speak. And it will always be there. Maybe try gasoline? Ethanol?
jacko
No guys and gals. The problem is we're not looking a magnets the right way!!!! Like I said in my other posts,,,,play with magnets. Take one in each hand and feel how they react to each other. Feel the way when you try to push them together that they fight to get apart when you use north and south, or how they want to come together the other way round. If you don't push then together head on they want to pass each other. Likewise when you try to stop then joining head on, they still want to pass each other. There in lies our STICKY SPOT!!!!! So now we have to find a way round this minor problem. MINOR,,,, yes minor!!! So how can we solve this?????  Every magnet in a magnet motor must always be in motion. This does away with the so called sticky spot!! How do we do this? Well all things that are round must go round. The field of every magnet is round. like all things in nature. Nature does not do stright lines. Everything goes ROUND! Ok by now I'm probably losing readers, who think this is about as interesting as watching paint dry, or grass grow. For a magnet motor to work, all the magnets there in, MUST be in contact at the point of max power at all times. It will not work any other way.
jacko
To Mk1.
It doesn't matter what shape magnets are.. Their field of power is always round... You can use an array of magnets to cancell each other out, there by creating a spike point to push other magnets attached to a wheel round, but you are only loosing power.
