GENERATOR- YOU DO THE IN/OUT POWER MATH
Started by magnetman12003, April 19, 2010, 09:16:15 AM
DeepCut
Thanks Gyula.
I hadn't thought of using maths to get the other figure ! I spent all day today just reading and memorising electronics so i shoulda thought of that !
My digi meter arrived today, a different brand from the old one but still cheap and crappy ;+}
Last night, with the 100 ohm resistor, the motor wouldn't even start.
Gary.
DeepCut
I tried starting the motor at 18 V then attaching the resistor but the motor just slows to a stop pretty quickly.
Also, my new multimeter was fine, but now i can't even read the voltage off a 1.5V battery !
Every reading i try to take the meter signifies 'off the scale' by showing a '1' on the left-side of the display !!
Is this the magnetic field having an effect upon the meter, and will the damn thing work again ?!
Or is it all the beer i've drank tonight ? ;+}
Gary.
Bruce_TPU
Quote from: DeepCut on May 07, 2010, 07:43:34 PM
Gary.
Hi Gary,
Take a deep breath my friend.... lol  All is well!  I would suggest you take a few quick pictures with your phone, of your resistor, how and where it is hooked, for Gyula to see.  And then look how I have the picture below of how to wire your two output coils.
Cheers,
Bruce
DeepCut
Hi Bruce,
thanks for the coil diagrams, i have them connected in series at the moment, will try parallel after this post.
A picture of where my resistor is placed is here, it looks clumsy but it's tight and not making contact where it shouldn't. I've marked the bridge ins/outs :
http://qvision.pwp.blueyonder.co.uk/resistor.jpg
Gary.
DeepCut
Bruce,
when the coils are wired in parallel, before being attached to the bridge or a resistor or anything, the motor won't run.
I have tried both permutations of connection and no joy :(
Surely, because each coil is a separate output, the induced voltages are sort of fighting each other ?
Shame, because i'd like more amps :)
*EDIT* sry im being dumb i NEED the resistor in there don't i otherwise it's a shor-circuit ? *EDIT*
*EDIT* nope. same thing. im not being dumb am i ? as soon as the two coils are connected in parallel it acts like a short-circuit ? *EDIT*
Gary.
