hydrogen from water (inline and safer to use)
Started by silverdragonrs, April 02, 2006, 06:49:17 PM
d3adp00l
its a fairly complicated design, and given the fact that I can't see the whole thing at once, is kinda like looking at building plans through a spyglass. however if the is a large distance between plates then there is a problem. Car batteries are only about 50amp/hrs and if you are gonna rely on amperage of the battery to get the work done, I don't think the system will work. Higher voltage seems to do better for producing h2, rather than high amperage. Try building a small test cell to get a feel for what if going on in these cell. Also I haven't seem a single person project how much H2 it would take to run a car engine. what the stoich mixture would be, how that would translate into gas production needs, which would transistion into electrical input needs. In fact I haven't seen any water cell guys hook their projects up to any motors? Even if it was a massive ineffiecent cell, I haven't seen anyone hook it up to a motor. The closest was some whahoos on youtube who ran a hose into the aircleaner of a generator. They Blew their cell apart somehow. Lets get a fixed system running before we jump into cars.
History is full of people who out of fear,
Or ignorance, or lust for power have
destroyed knowledge of immeasurable
value which truly belongs to us all.
WE must not let it happen again.
-Carl Sagan
pg46
d3adp00l -
There is plenty of information all over the web about how much hydrogen is required to run engines and there are lots of guys hooking up their cells to cars all over the world.
Plenty of information of actual cells and performances over at magdrive people for example at www.fuelfromh20.com .
stoich mixture as you called it is already just right at HHO in other words no additional air needed at all for hydroxy gas. However it can be leaned a way out but you would lose in HP. For booster cells not much is required if any for adjustments to the engines.
To figure out your HHO gas requirements you can use the cc sizes of your cylinders and the number of them and calculate what is needed for a particlar engine and at what RPM's etc.
Best Regards,
d3adp00l
@pg46 if the case is that everyone plans to connect their cell directly into the intake of a motor with no outside air to enter, I would say its a fools errand. Heres why, let take a small motor about a 2.4 liter. At a moderate rpm for said motor 3000 rpm. And with an assumed volumetric efficiency of 80%. Now let see how much hho you would need,
2.4L x .5 (a four stroke engine fires everyother rotation)
1.2L X 3000rpm = 3600L per minutes
3600 X .8 = 2880 liters per minutes to run a car!!!!
So to put it simply, You Can't Produce That Much Hho.
So a mixture of air and hho would be needed.
Everyone I have seen on the web is using hho in conjuction with hydrocarbon fuels.
-Carl Sagan
pg46
Sorry silverdragonrs -
I didn't mean to cut in and hijack your thread. I was just trying to respond to our friend d3adp00l 's negative comments about the possibility of using hydrogen and /or hydroxy to run ICEs.
I wanted to point out that there are actually already commercially available booster units that are easy to obtain. Magdrive claims and provide's a video clip where he supposedly is running a 460 Ford engine alone on his HHO generator. Mind you it is only idling after all and with no load on it. Still, it's not a bad start and it's running a rather large engine after all.
Our friend d3adp00l  could look at the research and discover just where this technology in this field actually is today. People like Bob Boyce for example have designed and built cells that do produce enough fuel to run engines. Most recently American Paul Zigorous did the same thing.
Most people do just use cells as boosters to augment their existing fuel. That's not a bad place to start afterall. Perhaps one might look to converting say a 100 cc motorcyle over to run on hydroxy rather than a 2400cc engine to start with.
Check out what ironhead and Moab and others are up to in this field on this forum. There are some good experimenters out there trying their best and sharing their results for all of us to learn from together.
Best of Luck,
raburgeson
Aluminium and Galium was tried with success as far as producing Hydrogen. The Gallium keeps the surface of the Aluminium from producing the capacitance Oxide layer. However the Aluminium is used up in the process becoming completely Aluminium-oxide. Redigestion of the Aluminium is a fairly expensive proccess. This still then is not the answer. We need a process the has an oxidizer that removes the Oxygen from the water and have the Oxygen easily removed say by combustion or catalyst to return the oxidizer to it's original form to be used again. I actually tried using Aluminium-oxide to try to perform the secound part of a process. Well, a billion ways to try to succeed in our quest and that one failed. plug on people. Sooner or later we are going to get lucky.
