magnet to generator to motor to transmission "generator"
Started by silverdragonrs, April 03, 2006, 10:22:18 PM
silverdragonrs
look at this and tell me what you think (need help finishing it please) this system with only one of each component would be around three feet in length add one foot per additional component. the transmission/rpm booster i added will need customised to work with this system. (ill work on this customasation tonight in addition i will be adding a few balanced weights between each component..... but for now...... here it is)
here is my magnetically assited motor driven self powered inline generator w/ transmission/rpm booster
danny
I would like to quote my idol... if you please.. press any key now.. "Anykey?!, Where's the N E Key?" ~ Homer Simpson ~ ......... one day.. With lotsa hard work and dedication.. I .. will be this good.. :)
silverdragonrs
i forgot to mention i am in the porcess of creating a frictionless bearing for this project. i will be willing to give half of the credit to what ever person helps me the most in my designs. (credit being the name of the machine i guess since patents and such are mostly pointless anymore) so if you would like to see the paschal- (your name here) machine a reallity then lend a hand! :)
silverdragonrs
here is the frictionless bearing i promissed it took two hours to complete. give me some input on it will ya. :)
silverdragonrs
does anyone have a simplefied/or not schematic of the internal working of a 12v(input) electric motor. actually any motor under 5 hp would work really. i need to study it and see what i can do to finish this project.
dracozny
one problem with your frictionless bearing is when you install it into a motor the weight of the stator and the constant vibrations of the motor as it rotates will add friction to the bearing.
there are many frictionless bearings that compensate for this usually by using sensors and an electromagnet as well as a monitoring circuit.
