Anyone have a cure for arthritis?
Started by Mark69, May 26, 2010, 12:47:52 PM
Mark69
Haven't had a chance to catch up on anything here, will try the MSM tablets first.  Didn't search "Hulda" or "Dotto" yet.
Mark
MrMag
I highly recommend the MSM. It works good for me.  I did find Dotto and GK did send me a link for it. Not much info on him. Not sure why that is. I still like the Lakhovsky device better. If I can get up off my ass maybe I'll try to build one.
Hulda's information is very interesting. She lists a lot of frequencies to use to kill parasites, bacteria ... in your body. I haven't done a side by side comparison  with Rife but she is doing somewhat the same thing. The unit she uses is very simple to make and if you have a signal generator, you can just use it.
nickle989
Change of diet can help.  If you are more acidic then this is bad bad bad.  You need to move to a more alkaline diet.  Red meats are not a help.  Caffeine is also bad as it restricts blood flow in the small veins.  When you can get the blood flowing again in the small veins besides bringing oxygen it also takes away the garbage.  If you smoke well then that is the first thing to quit.  If you take the "herb" then make a tee with it.  If you are over weight well you need to loose the fat as this is also hard on the joints.
troyd1
Go to Mercola. Here is a search link: http://www.google.com/search?q=site%3Amercola.com+arthritis&rls=com.microsoft:en-us:IE-SearchBox&ie=UTF-8&oe=UTF-8&sourceid=ie7
Also, EFT is very effective. I have used it for many mental and physical issues. It works every time I try it. I like this persons version: http://www.youtube.com/user/HealingMagic?feature=chclk. He has almost 300 videos, some testimonials and some with actual tapping. Maybe check out a fibromyalgia one if there is not an arthritis one.
Although I have not tried it, I think Bowen therapy would also be very good.
columbus
The pill is called reparagen. Sold in CVS.
reparagen.com
Also experimenting with diet helps a lot. For example, eliminating oils, switching from white bread to dark rye bread and adding papaya and noni.
