Anyone have a cure for arthritis?
Started by Mark69, May 26, 2010, 12:47:52 PM
Mark69
@crowclaw,
Hope she is doing better, thanks for the info.  How difficult would you say the build is?  I am a beginner at electronics.  Can you make instructions for those of us that have limited skills?  Keep us informed on the progress!
Mark
crowclaw
Quote from: Mark69 on June 17, 2010, 07:35:08 PM
@crowclaw,
Mark
Hi Mark,
The circuit is very simple and I will certainly post further information regarding it. All you need to do is to assemble  a battery box to accommodate your "D" cells  I used a combination of 10 ( each pair of two connect in series) The 5 pairs then connect in a parallel block to give 3 volts. The idea is to connect your screen mat or healing pad to the + end for 15 mins and then swap to the - end for 15 mins and just repeat sequence. A simple mechanical timer can be used or a 555 timer circuit. If you visit the various links to Lee Crocks sites you can get more details.
crowclaw
Hi to all,
This is a simplified design for those who wish to experiment with the energy cleaner I am currently experimenting with:
crowclaw
Could some one kindly open my attachment and post it here on my behalf as I had  trouble converting this excell document to an image to be viewed within this thread. Kind Regards M
angryScientist
Quote from: crowclaw on June 18, 2010, 04:59:07 PM
Hell o there, I am no longer an angryScientist rather am much worse than that. If you want to do what your talking about you might want to try this;
1.) Get "spred32". It's free. Does Exel. (What more do you need? Slow stroke?) Google you stupid fuck.
2.) Running windows? (Of course you are; silly question) Press "Print screen" and, or "Control"+"Print screen". That will copy the screen you are seeing onto the Clip Board.
3.) Open paint. Press "Control"+"V" and, or Go to the menu bar click "Edit", "Paste".
Does every one else feel a little dim or is it just me?.....    !
I almost for got to mention. It wont do you any good, you stupid fuck. Pull the head out of your ass. Demand your body, what?!
I see. I chi.
Good luck.
Good luck.
