Working Air Battery
Started by lasersaber, June 08, 2010, 11:39:33 AM
screaminvern
Quote from: lasersaber on June 16, 2010, 03:35:17 PM
  Back when I first tried making these I used a copper pipe instead of a carbon rod.  They always worked great right at first but dropped in power rapidly in a very short time.  The power dropped but the mag ribbon seemed to be in fine condition.
  What do you think the difference is between the copper and carbon concerning the power drop?
lasersaber
QuoteAlso, Please tell us if the outside ones are still going? Or, how long they lasted?
This is what I think is pretty amazing.  I ran the outside mag ribbon most of last winter under load.  It was still working fine this spring but coming apart at all the splices.  I dug up all the underground ribbon and it's the very same ribbon I have been using in all my air battery experiments up until the last two large carbon rod models on my latest YouTube video.  I thought I might as well order some new ribbon since they were working so well.
QuoteWhat do you think the difference is between the copper and carbon concerning the power drop?
I would have to do a little research to answer that.  I never had this issue when the electrodes were far apart in the ground.  I know from experience that it has something to do with the two dissimilar metals being in close proximity to each other.  NS coils also seem to suffer from this problem a little bit.  I have not noticed it at all in this new air battery design.
jeanna
Quote from: lasersaber on June 16, 2010, 04:33:19 PM
Seriously?
How did you get it to give power and not deteriorate?
Did you put anything on it?
I agree it is truly amazing.
thank you for sharing this,
jeanna
markdansie
I think I have experienced the chemical build up you speak of on a different design.  Back when I first tried making these I used a copper pipe instead of a carbon rod.  They always worked great right at first but dropped in power rapidly in a very short time.  The power dropped but the mag ribbon seemed to be in fine condition.  It was because of these early experiments that I switched to a carbon core.  Since using the carbon core I have never had this problem.  I have not had any issues with the new design yet.  My original air batteries are still working fine.
Thank you so much for this info. I am really excited about this and eargerly await my part to start building.
Mark
Mk1
@all
Not all soil and water is equal , some have alkaline battery some have acid battery , It would probably be a good thing to test the PH levels ...
This could give us a hint , the cathode reaction should be different , and we could determine witch is better for its lifespan .
Mark
