Improved Rotary Attraction Motor
Started by Neo-X, June 11, 2010, 12:23:29 PM
frii143
Hi,,,
I have a question about your device. What if you put a device that uses its centripetal force on it to mess around with the Mass and Speed to see if that will maintain free energy. A device model like what a skater does when they pull their arms and they go faster. Another one could be several device with springs that slides out weights hopefully it would increase the mass for the work put in and hopefully it will maintain Mass (a flywheel) at the same speed swiching between them. I wish I could be more helpful but frankly I don't know much about Physics or what has been tried in the past by free energy inventors.
Neo-X
@gyulasun
Thanks for help... I dont know how to use an IC and I have no money to buy.. Im thinking to use a two transistor to make flipflop circuit and my other problem is the magnet. I have no rectangular magnet...
@frii143
All I know is theirs no energy you can get in a centripetal force. Centripetal force can only transform and store the energy.. For example in a skater, if you use your feet to rotate your body while your arms are extending outward, the energy is stored in the mass of your arms and when drop down your arms an energy is released increasing your rotation and then stopped by friction.. Similar to a flywheel when a force is applied to rotate it, the energy is stored in its mass and when the applied force is stopped it continue to rotate because of its stored energy until it stopped by friction.. This means the greater the mass, the greater the energy can be stored.. A planet doesnt stop because theirs no friction.. If you are wondering why other device gets overunity thats because they know how to extract power in magnetism and gravity.. Energy can be extracted in magnetism and gravity thats why almost all overunity devices uses magnet and gravity. But it doesnt mean that magnet create energy, you cant create energy from nothing thats the laws of physics. Their is enormous wave energy in around us even in empty space. It is the ether wave that can pass through in any material except for magnet. The magnet acts only like a diode or a valve rectifying the wave energy in space in only one direction. Thats why a magnets have a repelling and attraction forces similar to an electric fan facing together...
gyulasun
Quote from: Neo-X on June 13, 2010, 12:38:11 AM
@Neo-X
Well, I thought of direct you to proven and working circuits in case you are less familiar with electronic circuits but I cannot build and send you a ready made setup or even a kit, sorry.  Here is a schematic and printed circuit board plan for a 555 timer IC based pulse generator with variable duty cycle and variable frequency:
http://www.overunity.com/index.php?topic=8411.msg243175#msg243175
Maybe some members here could help you in obtaining such components, you may also check locally what you can obtain (potmeters, diodes, resistors are not that expensive... and if you search for magnetic door locks or latches they have one or two block magnets, magnetized through their thickness, see this link for illustration, you may have access to such things at your local hardware stores for cheap:
http://www.thehardwarehut.com/catalog-product.php?p_ref=259864
rgds,  Gyula
Neo-X
@ gyulasun
Okay thanks I will try to study that circuit it is slight complicated...
gyulasun
Well, you can read some explanation on the 555 at several places:
http://en.wikipedia.org/wiki/555_timer_IC
http://www.doctronics.co.uk/555.htm
and an animation on the basic operation is here:
http://www.williamson-labs.com/480_555.htm
Basically you can consider it as "programmable" astabil multivibrator and with the two diodes added to it like I showed you earlier the duty cycle can be varied independently from the frequency.
Its Pin 3 output or its Pin 7 Discharge output can directly drive a MOSFET, and you can connect your coil to be pulsed in series with the drain electrode of the MOSFET. The other end of the coil is connected to the battery positive.
Good studying  :)
Gyula
