Improved Rotary Attraction Motor
Started by Neo-X, June 11, 2010, 12:23:29 PM
Neo-X
Neo-X
Oopps! Sorry it tripples my image... How can I delete the first two? By the way as you can see I add one magnet in the stator to double the magnetic field. I think this is much more efficient than Lindemann design...
gyulasun
Hi,
Interesting setup and you combine the flux of the permanent magnet with that of the electromagnet.  Can you test it ?
I would like to show you the motionless version of your setup, patented by Asaoka from Japan in 1999, see this link:
http://v3.espacenet.com/publicationDetails/originalDocument?CC=US&NR=5926083A&KC=A&FT=D&date=19990720&DB=EPODOC&locale=en_EP
You will find how much times less power input was needed to get the same flux with the permanent magnet present, see column 5, from line 51 to line 64 in Page 10.
rgds,  Gyula
Neo-X
Wow your right it very similar except theirs is a coil in the static rotor.
SkyWatcher123
Hi folks, how very interesting. In the patent posted, paramagnetic material is different from ferromagnetic in the fact that it is more like a 1 to 1 ratio in its ability to hold flux, therefore when the middle coil is de-energized the flux from the permanent magnet will prefer the other path of higher permeability, awesome. This paramagnetic material might be good to use for the rotor in your proposed design Neo-X. Hope that helps.
peace love light
Tyson
