Mk1 tested intuition helper, its time for overdrive !
Started by Mk1, June 22, 2010, 07:16:08 AM
Mk1
@all
I have discovered this about 2 years ago , Solfeggio freq , for me it worked wright away.
http://www.youtube.com/watch?v=hhHe8C6Qej4&feature=related
I actually used it 2 time since ...
Ok suggestion to do this , first clear your head , then make the same tone , lets you body vibrate to the tone , go to the end of the video .
You don't really need to repeat unless feeling the need for it .
There are other freq , you should look into that , its also easy to find on YT.
e2matrix
I am familiar with that youtube and his web site.  Those are nice and powerful in personal development.  You can download those from that users web site here:
http://www.sourcevibrations.com/Downloads.html
Mk1
@e2matrix
I use to laugh at those type of things , but now know better ...
I just wish everyone would listen to it , and put there experiment in overdrive !
Mk1
Most of you wonder what hold the world together , aren't we made of 99 percent void , 100 percent of what we see is only 1 percent of the reality?
No that 1 percent moves around , but why are they spreading , but instead holding together , because they are dancing , vibration holds them together , you have a build it signal generator , when it fails you die .
a demonstration http://www.youtube.com/watch?v=Zkox6niJ1Wc
Icke speaking about it
http://www.youtube.com/watch?v=oCmGjD9j9bU&feature=related
giantkiller
I, too, have gotten involved with this.
http://gnaural.sourceforge.net/
You can create your own sequences making the beat frequencies of the solfeggios. The patterns I have created actually make the images in front of your eyes warp and the sounds you hear warble. This is really cool. It helps you to think and sleep.
I have finished the next build of the S)olefeggio H)eterodyning I)nterference T)ransmitter device(google that!), seen at www.planetary-enginnering.com. Now it is portable. I have added the FM voice input to transmit subliminal mesages through the solfegggio beat sequences. I now have a hand held MicroHAARP device. I have already caused physical harm to humans as test 1. The second test I plan is to play the 'Pied Piper' behind where I live to chase away the voles from under the ground. Muhaa, haa, haa!
There is nothing like kicking ass with the correct weapons. I know.. I am stuck in Doom.
