Lets Just burn water instead for now! Plasma Injector rework
Started by Hope, July 24, 2010, 02:27:59 PM
Hope
Have found further water crackers now on youtube, apparently the light burst can be within a vacuum and aimed (lensed and magnified)  then also sent down the same path as the resonate frequency(s).  Thus adding alot of movement pressure and should enable bringing down the overall power needed to strip the hydrogen / oxy bond at a change state.   The ends of these HHO torches are cool to the touch.  So this may help heat sink any temps gasoline creates, HHO cools its own metal torch (water humidity is high i guess).
e2matrix
Interesting topic.  I don't think Compututor was really trying to block.  I think he was trying to help but maybe he's thinking a little too much inside the matrix.  I actually suspect talking to spark plug manufacturers will have you filtered to a person whose sole purpose is protect their huge stake in keeping the standard ICE matrix in place.  Allowing alternate ideas to blossom could easily mean the end of their empire.
Low-Q
Quote from: CompuTutor on July 26, 2010, 11:17:48 PM
Does anyone here know of a better product
we can all (Afford to) purchase over the counter or online ?
Plaster? Will that work?
Hope
I agree re-reading the topic THANK YOU COMPuTUTOR for your trying to help!
Since this gas burns at such a quick rate it produces more power,  It could be that some of the other engine technologies could cause HHO dry vapor to ignite from wave-building lensed laser static.   But since HHO is the king of thermo expansion with water/oxy assist we will also obviously benefit from using this heat further with the normal sciences at hand even.  We can also do this with our HHO assisted dino burners,  and I feel with something like a Laser pulse shot as a "heater/exciter" to a spot on the end of the plug "the collector"  it would be simpler than the first half-baked idea, injection of HHO is already simple.  Can a plasma burst be lensed thru a quartz or other type lens and directed into each chamber thru Optic cables (you can wood burn thru them I know already)   This would keep the sealed ignitors away from the combustion better.  Then we could fire all our fuels at zero degrees.  Or even simpler yet totally convert to HHO and even your normal spark ignition can be adjusted to work just fine.  In the long run a thermo silica battery will be a DIY method to store that energy with over 90% reported efficiency.  Grown crystal plugs,  if this becomes the standard the method is already a working science.
Hope
After reading Rosemary, Smoky2, Davids remarks on the shock pulse caused by disrupting a magnetic focus with a 3 dollar laser,  shock waves look promising to compress the gas into friction ignition.
