Inventor Conceives Energy Breakthrough
Started by tomd000, July 30, 2010, 09:12:10 AM
fritz
Energy Amplification LOL:
If you have a coil with 1A - and  it has 200 windings on a core - you will measure 200A as flux in the coil LOL. like on any transformer or core in the world LOL.
If you take a clamp meter and make 10 windings on the clamp you will measure 10 times the current in the wire.
Another point is how he will measure the energy in the hole with the clamp on the core ?
I don´t think he will get the OU price ;-)))
Maybe he should start with an air coil first.
IotaYodi
Hmm! sighting of a flying saucer in 1968 in Berkeley.
Those who know Berkeley and the 60's may have a problem with this.
What I know I know!
Its what I don't know that's a problem!
Elvis Oswald
Fritz... the guy said that he got the 200 amps with the same voltage.
"every transformer in the world" will decrease the voltage when increasing amperage.  This machine is increasing the amperage without decreasing the voltage.
fritz
What you see in the movie is that he feeds 1Amp DC to a coil wound on a toroid coil.
He measures this 1 amp by using a clamp meter - he is measuring an magnetic DC flux equivalent to 1 amp.
Then he uses another clamp meter hooked on that toroid coil.
This measures the flux inside that coil.
The flux is 200Amps.
These 200Amps are the summed up fields of 200 turns of wire which 1Amp.
There is no part with 200Amp
There is no transformation anyway - this would only work with AC
The demonstration shows that 200 turns of wire with 1Amp make a field that is 200 times stronge. wow.
s - only a field.
This guy is talking lots of BS.
