Patent announcement
Started by brian334, August 10, 2010, 09:36:15 AM
conradelektro
@brian334
For me, there is no need to proof that a machine does not work.
It is the inventor who has to proof that it really works, best by building a working prototype and showing it publicly.
If you followed the many threads in this forum you probably saw that none of the alleged "wounder machines" where ever proven to work. All attempts to get clear and concise information about a working machine always failed.
The burden of proof is on you! And I sincerely hope that you will be the first one in this forum (in fact, the first one in human history) who succeeds. I would be very sad if we once again discuss an illusion.
It is very simple, just show a working machine and explain how it can be replicated. But exactly this "simple demonstration" never happens.
Replication does not mean, that your patent protection vanishes. It would help you to attract funding.
Sorry for writing the obvious, I will not insist further. It just needed to be said and I do not want to speculate publicly why the inventors of strange machines never proceed in an obvious way.
Greetings, Conrad
Omnibus
Quote from: brian334 on August 11, 2010, 11:33:30 AM
Mr. Bus,
Will you explain why any of these machines won’t work?
These machines will not work because the energy gained when the contraption floats to the top will be exactly equal to the energy spent to empty it when at the bottom. It's for you now to prove that's not the case.
ResinRat2
Hello Brian,
Thanks very much for posting the patent number to your invention. Congratulations on getting the patent.
Do you have a working prototype? I would very much be interested in seeing pictures of a device if you could post them here on this forum.
Thanks again for your efforts.
RR2
the_big_m_in_ok
Quote from: Omnibus on August 10, 2010, 02:21:29 PM
If you get an error message like this from Google Patents Advanced Patent Search, try:
http://www.pat2pdf.org
They have a lot more complete database.
http://www.pat2pdf.org/patents/pat7770389.pdf
--Lee
Omnibus
It is not at all evident that the patent in question has achieved its goal:
QuoteIt is the goal of this machine to empty the tank after the tank has been submersed, and in the process of emptying the tank do less work than the empty tank does when it floats up
