High Voltage CFL Circuit
Started by nievesoliveras, August 14, 2010, 09:00:21 PM
nievesoliveras
I did a small job, earnt some money and ordered both of the drivers posted before. Just in case I fail.
Also on that order come the 6 mosfets.
Jesus
XS-NRG
which mosfets did you order?
are they logic level?
the gate needs to be cmos compatible or you have to use additional circuitry to fully close it.
the thread title is about a CFL inverter, you are speaking of a motor etc.
what is your ultimate goal with it ?
i have designed many circuits like motionless high speed field rotation aswell as automatic resonance hunters to detect and tap into external energy fields.  :)
there was even a time when i was building recievers to communicate with ghosts but that was a little bit off target and i never managed to get it to work  :D
and now im glad i didn't get it to work because then i would probably be posting the same nonsence that L. Tseung twat is posting about.
nievesoliveras
It is not a motor. It is a car alternator.  The high voltage cfl circuit will be integrated on the final result.
Then came that for running the alternator as a motor I needed to learn pic programming.
I can also use a hardisk spindle motor as the generator if I can make it run with the pic programming.
Sincerely, I got a litle lost now with all the obstacles.
Jesus
nievesoliveras
Maybe I open another topic with the name "Possible self running ilumination with a car alternator". Using the high voltage Cfl circuits.
Jesus
nievesoliveras
@xs-nrg
The touristic island of Puerto Rico is at:
