Can some explain how to tune oscilation from tesla 369 earthquake 2 power
Started by cletushowell, August 17, 2010, 11:55:20 AM
Low-Q
I am not personally against you, I ccouldn't see the serious part of your posts because they are written like you should have put lots of words into a bucket and poured it on the floor. There are numbers and words, I can see that, but there is no way I and many others can understand in which order these words and numbers are suppose to be. You also talk about Bin Laden...WW3, and now Pearl Harbor - that was bombed in WW2 if I am correct....
I will try my best again and understand your videos. Maybe I can understand something out of that. No doubt that you are very wise, but a big problem many very skilled persons have, is to explain in an educational way, and carefully explain step by step. I don't know if you are a medical issue, a crackpot or a genious - it is sometimes very hard to differ these type of persons apart.
So my apologies for calling you something bad, but I was a bit concerned about the content of your posts and videos for a while.
Good luck in your experiments, and I hope you find something useful in your research. But if you expect me or many others to understand what you are doing, I think it is better to try to write down the context step by step. I can see you have added a video. That is a very good start. Good luck :)
Vidar
cletushowell
Like i said if you can type
everything in a blog good for you I cant
step by step but i can sumerize
string theory
antigravity
moray valve
teslas earth quake
photon energy
a earth battery that sent so much energy
it lit the whole forrest on fire in russia
something they fucking degraded me on
god like productions but better yet
some thing they deserved
they built the fucked up nuke plant
I released the energy
maybee you should watch my
I got a problem video because your stuck
on one my dictating
some say I got a problem
http://www.youtube.com/watch?v=AsNLqRbr-ks&feature=youtube_gdata_player
Low-Q
Quote from: cletushowell on August 19, 2010, 12:59:03 PM
http://www.youtube.com/watch?v=oU6PwrBV0EE&feature=youtube_gdata_player
here is the video if you can type this
feel free your better then me
I cant dictate it odviously.
Feel free to post diagrams of the dc
circuit if you know what it is its not about me
its about us working together to finish this
I have tried to understand this video. You basicly are talking about voltage. It seems there is an unconventional way of transforming AC where you use DC to offset the 0 potential... Anyways, if you only counts with voltage, there is no way one can calculate the energy it is suppose to provide.
Oscillation are also an issue. If you load an oscillator, you also change the phase between voltage and current. This means you start to load it so more energy must be put in, in order to get more energy out.
I cannot see where the overunity are, but I understand there is higher voltage. It is most probably lower currents, so the total energy are not changed.
Vidar
Low-Q
Quote from: cletushowell on August 19, 2010, 01:57:14 PM
1. There are over 300 religous books in the world, and everyone say that their word are the right one. How can you be so sure that God will do anything - or that God has anything to do with everything?
2. You do not have a problem. You are an exentric person that colorize a world of grey, boring, and  mainsteam people. That might be a problem, but you are not the reason for this problem.
Vidar
cletushowell
It very simple if they dont have 144,000
thhere false doctrin works of casting 9 marco rodin
nimrod the 666 m rodin
so it worked its very simple when you tune the osxilations
its goes overlimit contiously i had it perfect
but now stuck on the very top post the 1.2
so if you dont even understand. The 369
your wasting my time I didnt say this was a education
forum I said if you know how to tune oscilation
so mr vidar do you know how to tune it
or just going to keep degrading my
free energy
car coil from negative dc to positive side of coil
polorise it thru the negative side to ground rod
then add spiral square wave creates the secondary
ground if i get it circling in over limit again ill post the video
