FUELLESS CAR PROTOTYPE by ISMAEL MOTOR
Started by luishan, September 08, 2010, 11:50:07 PM
Poit
Quote from: bolt on February 24, 2011, 10:00:48 AM
Ismael technology is NOT open source. He is able to generalise upon the technology but only to a point of retaining IP rights to protect investors. ............
Exactly! and because he is going down the same path as all the rest, he will fail with out a doubt. Albert Einstein "Insanity doing the same thing over and over again and expecting different results."
The ONLY way free energy can be obtained by the people of the world is to NOT patent it, it is to NOT to seek millions of dollars....... Open source is the only way!
Don't get me wrong..... I would absolutely love for this to get out......... hell, even if Ismael patents it and charges $100k for it, I would gladly pay.... but unfortunately it will never get to this point...... history is the best teacher here.
serm
Last result he tested his MEG
MEG testing result
Duration: Total of 4 hours
Load: 800watts Resistive Bulb [estimate]
Input: 12.8V
Battery capacity: 6,000 watt-h.
Battery remain: 12.7V
Volts drop: After 4 hours =0.1 volts
I think reamined volt was not enough clalified. He could show the remained amp-hour of battery. Becase when battery is drained volt will decreased a little.
Doctor No
Poit! What i remember You were against free energy, and now such a turn?;-]  When Ismael shows anything or makes it open source, he will be most silly man on this planet (or even in Universe;-)). I would like to pay him for this work done 500 mlns EUR in gold, cos it is a bargain simply said.:-)
bolt
Quote from: Doctor No on March 02, 2011, 03:00:25 PM
Ismeal open to serious offers now for quite some time. Not too many people come along with real serious cash but investors so far small project funds mostly from family and friends all need some money back now in difficult economic times. One or two billionaires  made offers but they never just want to hand over cash for technology advancement as its not about the money to them its about control. There are always painful strings attached.  What you end up with is something far worse than a Dragons Den offer!!
As he said before offered to relocate to another country, retain only 20% shareholding, do whatever they want with the technology including shelf it or use on secret projects. Prevent any disclosure for least 15 years, sell your soul to the devil and lend out your daughters at weekends!
If you can handle these type of deals then sure you can be very rich indeed and the rest of the world will never see the MEG again.
Here are some more emails from Ismael:
2:30pm I check again the running MEG , but the brightness of the bulb a little bit dim. I check the batteries, I found the battery from 265v down to 254v . I check individual voltage of the 21 batteries. I found out Two Battery that was used to power my controller & other sensor down to 7.8v & the other one down to 6.2v. but the rest still  in the good level of voltage.
Replace it three times the 75AH capacity compared to the other 19 batteries24 AH. To accomodate the Microcontrollers & sensor drain. After the replacement back again to 261V &  back again to the MARATHON Testing of the household power genset of the future the MEG.
Ismael
We just bought a new tester.
Here's exactly my MEG set up. temporarily I have series of batteries up to 265V/ 24AH.( total of 21set of 12V batteries ) Since yesterday testing 4 hours same batteries.
I supply it to  the MEG resonator & my MEG output connected to a load of  2,000watts bulbs.
Today Since 10:15 am up to 1:40pm = 3 & 25 minutes running untill now. The voltage drop from 265v down to  260v.
This measurement of voltage while the MEG is running. Not when is power off.
The measurement between the power Off & On condition with 2 volts difference. from 265V at off condition & it will down 263 v if the MEG start.
If you will measure from off condition,, totally you will not notice the voltage difference & sometimes it goes higher to 270V.
The load not a exactly 2,000watts, but only 800watts since the volts accross the load only vary from 85v - 92v.
ismael
batteries is 12V 24H Motolite AGM type. Bulbs 100watts 220V incandescent GE.
I swicth off my MEG at 5:45pm, I need to go for church activity. As well to ask more guidance & Blessing for humanity. Start from 10:15am,interrupted for 15 minutes & run again up to 5:45pm , Battery drops to 251v. So far so good I think I am more than 197% already. I will try to increase tomorrow, if give the chance.
Ismael
OK Guy's you can post now the video
Ismael
http://www.youtube.com/watch?v=f36lPtGeybM
Regards, Stefan.
