Pyramid material
Started by Bush_Doc, September 09, 2010, 03:55:58 PM
Bush_Doc
Hi everybody, I am planning on building a pyramid, and was looking for some help on which materials to use. This is what I think would work well: copper rods for the structure, with sheet copper covering the first layer of the pyramid, then polypropene sheet covering the second layer, then copper for third layer and polypropene for fourth. Would sheet covering produce an electric-dielectric-electric-dielectric covering? Is copper a good material to use for the structural rods or would another metal work better?
screaminvern
Hi Bush_Doc , I don't have an answer to your question, but I'm glad to see some one else messing around with pyramids. I built one out of 3/4" copper tubing with the measurements given in another thread here. I found it interesting that the measurements equal biblical measurements too. The four tubes around the bottom are 20" each which = a long cubit which is a cubit + a hand breadth, and the four tubes going up to the peak are each 1 cubit long, or 17.5".
Bush_Doc
I found out that gold would be best (or even better the secret element), and the measurments I am going to use are the same as the Giza pyramid to open the heart chakra. I have already built a medicine wheel to go with the pyramid and am waiting on funds to buy copper
screaminvern
Gold huh? That's way out of my expense account LOL. However, What do you think about silver plating the copper tubes??  I decided to Measure every thing in biblical measurements after I did some research on King Salomon. Apparently He was abusing sorcery so God put a stop to it. They were using the biblical measurements then so I am curious to see if using the cubits, etc. has an effect on any thing to do with any alternative energy experiments.
Bulbz
Quote from: screaminvern on September 30, 2010, 05:51:29 PM
Perhaps that's why Gold is so expensive, so that nobody can buy enough to experiment with    >:(
Best regards.
Steve Ancell.
