High End Overunity
Started by jadon1979, September 23, 2010, 12:29:48 AM
jadon1979
Ok... I haven't built this but once you understand the experiments done with a neosphere and a Rodin Coil (ridiculously high RPMS) then you'll understand that with high end wind turbines you can produce a massive amount of energy with little investment.  This idea is free to the world.  People shouldn't be making money off this... it's how we got into the situation we're in now and that is called Greed my friends.
jadon1979
Now imagine only 1 shaft coming off the Neosphere.... and done in a star pattern around the inside circle of the Rodin... then have the same thing underneath the rodin coil.  Imagine the production!
twinbeard
Quote from: jadon1979 on September 23, 2010, 01:25:06 AM
I think you will find that this setup will lack the torque necessary to drive a standard turbine type generator.  You have to make your generator Lenzless for this to work properly, and keep the mass you are driving down;)
Cheers,
Twinbeard
jadon1979
I believe with the higher revolution wind turbines I'd actually have to increase the rotor size to decrease the torque.  This way I could setup a gearing type system and add an array of wind turbines.  I've played around with some of them and it's very little torque.  The sphere will do at least 20k rpm by itself.
twinbeard
Quote from: jadon1979 on September 23, 2010, 02:16:39 AM
Have you played with them under load?
Here, look:
http://www.youtube.com/user/piratetwinbeard
I have a sphere at somewhere around 3.2 Million RPMs...
You still have to bypass Lenz drag.
Cheers,
Twinbeard
