Rodin/Starship Coil and Earth Rotation
Started by Atlastired, September 28, 2010, 10:58:44 AM
gravityblock
Quote from: Atlastired on September 29, 2010, 04:10:37 AM
www.lunarplanner.com/HCpages/Venus.html
This is the site to look at
243 years for a double cycle that come directly on the Sun at a few degrees lower than the previous, so how many cycle do we need for Venus to come at the right angle to create a pole shift in our Rodin/Starship Coil that is the Magnetosphere?
3? Who knows, our ancesters who experienced it have documented it in coded mythologies and religious texts.
But if we have been already altered in our elyptic patern by the first Venus transit in 2004, that will, in my opinion decrease the distance between Venus and the Earth, thus increasing the blocking effect of Venus in 2012
So, it is your opinion only that the distance between Venus and the Earth will decrease, and will increase the blocking effect of Venus in 2012.  Your opinion doesn't hold much weight around here, and besides when Venus is fully on the sun's disk in 2012, Venus covers only 0.1 percent of the sun.  You have already recanted your previous statement of a potential for a total blockage and replaced it now with only an increase in the blocking effect, as can be seen in your above and below quotes.
Quote from: Atlastired on September 28, 2010, 05:15:56 PM
WRONG, in a spherical radiation like the Sun, it is not a 2 Dimensions radiation, the Sun's upper/lower visible part during a Venus transit is radiating at an angle that will not reach the Earth, only a small 3D spherical plane of radiation will hit us, and Venus has the potential to block it totally.
At the time of the Venus transit in 2012, the sun measures 1891.38 seconds of arc across, while Venus is only 58.26 seconds of arc in diameter. This makes Venus just visible to the unaided eye as a small black dot. When fully on the sun’s disk, Venus covers only 0.1 percent of the sun, so you won’t notice any decrease of sunlight during the transit..  Therefore, it is essential to use a safe solar filter!
Predictions for the transit of Venus, 2012 June 5-6, http://www.transitofvenus.nl/details.html
GB
Qwert
Quote from: Atlastired on September 28, 2010, 10:58:44 AM
This is free of "Jewish Fraud Physic" like Scientist Philipp Lenard used to say, so we are free to really understand what is going on.
Can you show us your method, how do you come to the conviction that something IS or IS NOT a "Jewish Fraud Physic"?
gravityblock
Quote from: Qwert on September 29, 2010, 05:19:00 PM
My best guest would be anything other than "The Physics of the Primary State of Matter" according to Karl Schappeller, http://www.megaupload.com/?d=IRBTBAO0
If Schappeller is correct, then an ether propulsion system is possible along with transmutation of the elements.  To travel outside of our solar system, an ether propulsion system should be used instead of the vacuum method I previously described, which is sufficient only for travel within a planet's atmosphere and within our solar system.
The problem with replicating the Schappeller's device is we don't know what the sublimate/electret he used, or anything about the special battery to start his device (appears to be an earth battery of some sort).  Also, we would need hollow copper tubes of wire which is then filled with his secret sublimate.
I don't know, Schappeller may be a "Jewish Fraud" also, LOL
GB
Atlastired
Quote from: gravityblock on September 29, 2010, 10:36:26 AM
Ok once again for the same one who slow the class down.
Take two marbles of the same size, Take a big spot light (2D Radiation), in a black room put one at one extremity of the Spot light, and now with the second marble try to cast a complete shadow on the first marble.
At a special distance and degree you would.
that's a replicable science fact, try it
Earth Elyptical plane is the observation point for calculating the distance between Earth and Venus, we are experienting a change in our elyptical plane, so it will affect the distance between Venus and Earth.
This is logic, try it
In a spherical radiation, the particules are following a straight line.
Think of it like a plastic sphere with thousand of little holes and a pressure water hose attached to it.
The flow of water will follow the angle of departure.
Now imagine our Earth millions of KM away receiving only a small radiated angle of the Sun, than now picture a planet the same size of our Earth (Venus) at its closest position from Earth and its farthest position from the Sun coming and stealing our little ray of sunshine.
Yeah but the sun look bigger! Yes indeed the Sun look bigger aint somethin
Funny that our little green aliens believer now is asking for facts not opinions...LOL
Qwert
Quote from: Atlastired on September 30, 2010, 04:55:15 AM
...In a spherical radiation, the particules are following a straight line.
This could be true IF all particles have exactly the same speed. Since they don't, those slower collide with faster all over and their path from the beginning is, well, just more or less CHAOTIC. In addition, when they reach a planet's (Venus in this case) atmosphere or surface, some of them also reflect and collide with those later coming. In effect, the space behind Venus is full of particles which more or less chaotically go to the Earth.
