Relative Permittivity of Water
Started by Torana, October 14, 2010, 04:35:01 AM
Torana
Its not fair for me to say ....."anyone can check his formulas"
So Ive got the disc in front of me , IM going to go thru each formula (yawn) , Ill do them in maybe 3 batches  over the weekend.
IF a formula is correct , itll be labeled so
IF a formula is BOGUS , itll be labeled so and the correct formula next to it
Theres an interesting twist in those formulas which will upset things and the full picture will reveal.
**BOGUS = not genuine , Collins dictionary.
Torana
EQ 1; Z series = Xc - Xl    correct but not complete .
At freq below resonance , Xc is larger than Xl , so the remainder is Z = X
At resonance Xc is equal to Xl therefore Xc - Xl = zero , result Z = R , a resistive circuit
EQ 2; Xc = 1 / 2 pi f c     correct (capacitive reactanc)
EQ 3; Xl = 2 pi f L           correct (inductive reactance)
EQ 4; f = 1 / 2 pi sq rt (L C )    correct  ( Resonant freq)
EQ 5; Vt = I Z               correct    (Ohms Law)
EQ 6;  Vl = Vt Xl / Xl - Xc    BOGUS  (Ohms law Vl = I XL)
EQ 7; Vc = Vt Xc / Xl - Xc   BOGUS  (V x ohms / ohms ) ? ?
EQ 8; Z = sq rt R ^2 + ( Xl - Xc )^2   correct ( impedance)
EQ 9; Z = R1 + Z2 + Z3 + RE    BOGUS  (EQ 8 is used) ( RE = dielectric constant ? ? how?)
EQ 10; E = I R                     correct  (ohms law for DC )
EQ 11; P = I E    watts                 correct  ( POWER basic form )
EQ 12; A = F / M                  correct-ish  (Newtons 2nd law of motion F = ma , newtons.kg.metre)
EQ 13; F = q q1 / R^2           correct  (coulomb force)
(mutual force F = Q1 Q2 /d^2  ,F = Q1 Q2 / e d^2 ,   separated by a dielectric)  Q = es units ,d = cm ,e = permittivity
EQ 14; V = q / e R               BOGUS  (this is semi EQ 21 , denominator is distance and dielectric)
EQ 15;  R s= Vin - V led / I led  intensity ?  correct-ish (This is a series resistor selection formula)
EQ 16;  Pwatts = Vcc It    parallel array   correct (without parallel R or G calculation)
manufacturer lists power rate and freq IF its a flashing LED
EQ 17; Le = sq rt Ion^2  T1 / T1 + T2    BOGUS  ( liminous intensity = candela )
****SECTION 3 PAGE 8 =  REPEAT EQ 1 to EQ 17  =  FILLING ****
Torana
EQ 18;  Ein = Md C^2           correct I GUESS ,Einstein-ish
http://www.worsleyschool.net/science/files/emc2/emc2.html
EQ 31; E = hv                    correct-ish ,  h= 6.547 x 10 -27 erg , BOGUS
          E = hv = hc / lambda ,  h = 6.626 x 10 -34 J.s , 6.62 x 10 -27 erg sec , v = frequency of em radiation
EQ 32: hv / c    momentum of photon , correct (magnitude of momentum hv / c = h / lambda )
c = quantum of em energy ?   (c = light speed in metres )
FIG  5 - 11  Optical photon , planck = 6.547 x 10 - 27 erg sec   BOGUS
SECTION 7 page 4
Resonant charging chokes (614/615) 36 AWG =.006  BOGUS
SECTION 7 page 5
Primary coil (622)  22 AWG = .028  BOGUS
Secondary pick up coil (623) 35 AWG = .007  BOGUS
36 AWG = .00500
35 AWG = .00561
22 AWG = .02534
http://www.bulkwire.com/wiregauge.asp
LIKE IT MATTERS . .... to be continued.
Torana
EQ 19; wa = L I^2 / Z             BOGUS    ( stored energy = L I^2 / 2 OR .5 LI^2)
EQ 20; L = .8(NA)^2 /6a+9b+10c    correct  (this is an AIR CORE COIL) Wheelers formula
http://home.earthlink.net/~jimlux/hv/wheeler.htm
EQ 21; C = .2249 eA /c Eo       BOGUS   "permittivity (Eo) of the dielectric property of water"=crap
"Eo =free space permittivity of water" more crap.
(imperial C = .2249 KA / d , OR metric C =e er A/ d ,written as C = KA/d , permittivity of free space =8.854 x 10 -12, for conversion , the inch = 25.4 mm , so 8.854 x 25.4 = 224.9  , pico farad being 1.0 x 10-12 ,the same as the free space figure .)
EQ 22; area (A) = h/2 (a + b ) Tapered Resonant Cavity    correct  ( Huber / Smalian formula for parabolic Frustum)
http://mathforum.org/dr.math/faq/formulas/faq.cone.html
EQ 23; Circumference Surface point (E9) = pi D         correct (A CIRCLE = 2 pi radius )
EQ 24;  Z = Xl - Xc                              correct    "in terms of component reactance, inductors (L11L2) should ALWAYS be larger than capacitor"
(for Xl to be larger means freq is above the resonant freq ,therefore Z = X for a NON RESONANT CIRCUIT , at resonance Xl = Xc)
SECTION 7 page 10  REPEAT EQ 9  BOGUS ... and Filling .
