Relative Permittivity of Water
Started by Torana, October 14, 2010, 04:35:01 AM
Torana
The circuit of post#139 is from "Open-source-energy" It is dated 8-11-2011...August
The following circuit is from "heretical builders"           It is dated 8-5-2011...August
Might close I would say, does 5 come before 11?  ...6 days difference!
Notice the polarity of the Bridge rectifier? ?  negative earth.
Tony woodside circuit is the same circuit all over AGAIN!  ...the ONLY upgrade is an LED!
Torana
This circuit is from "heretical builders"  It is dated 12-10-2010
Anyone who personally wants to copy, ...you best bet is to ask the Author any questions.
Please NO pm to ME .
http://www.hereticalbuilders.com/showthread.php?t=174&page=4
***NO I CAN NOT GIVE HI RES PICS ...THIS IS NOT MY CIRCUIT...ASK THE AUTHOR.***
Torana
***I DO NOT FIX 8XA CIRCUITS.    NOR DO I CALL A SCR A TRANSISTOR , MOSFET ...
***I CALL A SCR A THYRISTOR ....BECAUSE THAT IS EXACTLY WHAT IT IS...
***PEOPLE HAVE FREEDOM OF CHOICE HOW THEY SPEND THEIR MONEY
***I DO NOT INFLUENCE HOW PEOPLE SPEND THEIR MONEY
wfchobby
Hi Torana,
Im not fussed about the 8xa circuit except it might give some clues as to the possible waveform and gating signal required to feed a VIC or similar. 8xa for me no go because unless its fed by an inverter it not designed for end use in a working vehicle so therefore its no use building it unless one is keen to spend precious $$$$ for a workbench unit for experimenting that has no further use in practical application on an actual engine.imho of course
Torana
Hello H2o my ol friend,
stans fig are for INJECTION ,  I calc  LA to NY by info given , micro litre INJECTION , Rev of crank , Hour , Minute , second  , Mile .
****NOTICE.. it does not say Ohio - LA - NY - Ohio ..  (Whoops ! ! )
...it IS completely THEORETICAL  =  ****NON FACTUAL****
I was being GENEROUS by using IMPERIAL GALLONS
65 MPH @ 25 MP,Litre of WATER
2462 miles / 25 miles = 98.48 LITRES of WATER in the TANK
98.48 litres / 4.55 litres = 21.64 IMPERIAL GALLONS
98.48 litres / 3.79 litres = 25.98 US GALLONS
If US gallon is used then stan was a LIER ! !
***IF YOUR proving stans figures were BOGUS then YOUR the stan HATER and IM the STAN FAN  ? ?
....NICE TURN AROUND ! !
I was trying to make the fig work without manipulation....It says "22 GALLONS "...NOT US or IMPERIAL..
