Captret - Capacitor and Electret
Started by ibpointless2, October 19, 2010, 06:49:51 PM
altrez
Hello!
Can you please post a diagram for how I should have my battery chargers hooked up? I think there wrong as well. I cant get any battery / Cap combo I have tried to charge a dead battery.
Thank you so very much.
-Altrez
ibpointless2
Quote from: altrez on January 15, 2011, 06:47:54 PM
Hello!
-Altrez
if you're tying to charge batteries with the captret then there's more than one way. You can start from the beginning of this thread or http://www.energeticforum.com/renewable-energy/6684-captret-perpetual-light-dead-batteries.html
I and many others have found many ways to charge batteries, but the charge was slow. Even though i and many others could get a battery to charge at no loss the charge was very little.
There simple things like this you can try http://www.youtube.com/watch?v=wbn4vede2us
if you want to really get into the charging then you should check out what Plengo's doing here http://www.overunity.com/index.php?topic=10175.0
there's not just one thing you can try but many things! The captret was merely to get people to think and come up with uses for it, i never expect it to be a battery charger. As for your current setup it might be the capacitors, some work better than others. I find that 220uF 50v capacitors work great for some things, try to avoid super caps too.
blueplanet
Hi Folks,
I have a very stupid question. I hope you don't mind.
What is the easiest way to permanently connect the "O" pin of an electrolytic capacitor?
Blueplanet
gravityblock
Quote from: ibpointless2 on January 15, 2011, 11:35:40 PM
According to Plengo, there is no charging in his experiment.
Quote from: plengo on January 04, 2011, 08:33:12 PM
I have bad news updates. Switching the batteries total voltage went DOWN. Now it is about 14.67v way below the initial 18v.
Sooooo, I think this design is not working.
Thanks to all for the support and the ideas.
Fausto.
GB
Bizzy
Hi Blue Planet
I heat a bare wire with my solder iron and drop some solder on it. I While there is still a hot droplet on the wire I quickly press it against some cold steel. The solder will not adhere to the cold steel but will stick to th ehot wire. This gives me a wide and flat connection at the end of the wire. I then palce the wire at the O position and use liquid tape to secure the wire and lead contact to the capacitor.
Bizzy
