this is a basic power ring
i have designed this unit to be universal
meaning i can interchange the charger to work with over 10 diffrent methods ...
OUTPUT 10 KW 120VAC 86.9 AMPS CONSTANT!
OUTPUT PEEK 20KW
this is also a power supply for a UFO
OSIRIS ENERGY TECHNOLOGY
OSIRIS
Such an extraordinary claim is going to take extraordinary evidence for people to believe you.
Can you provide videos, a circuit diagram, and/or parts list?
Also, what's the input power?
I sense IST is around ;) Looks like some serious capacitance, about 96,000 Farads if I'm seeing it correctly. More info please ....
Quote from: e2matrix on December 03, 2010, 11:36:06 AM
and looks hi nothing learn. probable i put osiris on ignore list too.
Osiris, Thank you for sharing your work. You mentioned 10 kW Output, but we don't see any wires.
Can you show us a circuit diagram & a picture of the input wires & output wires.
Thank you.
@oserisi (IST)
what is the device pictured do. From what I see its a large stroage device using caps.
Appart from that is there any other purpose? Are you just going to make a huge JT device with it.
Kind Regards
Mark
Quote from: osiris on December 03, 2010, 09:33:16 AM
OUTPUT PEEK 20KW
OSIRIS
Hi osiris, i would be very interrested in your work, i hope you will share it for good, it looks interresting. please could you teach me how a device can be achieved like the one you have?
Thanks,
Energia
Making claims on hardware not even built yet , same old IST .
I hope it works out for you William , good luck .
I don't know what he did last time?
But I hope He behaves himself this time!!
Welcome friend,we need all the help we can get around here!
We don't speak in tongues anymore ,and all our crystal balls took a S$%t!
Well actually this guy Cletus took the last one!
So until further notice, where kinda flyin blind around here?
Can you share some more info on that monster?
Chet
hello all
thease are build pictures.. as it was built so you all can fully COMPREHEND IT
if i were to place a compleated device of this scale i would have noting but questions . and doubts .. so im placeing pictures of the compleate build as i see fit !
regards
the title of the device says its compleate operation ..
808 G6
there 6 15vdc 3000f banks = G6
there is 2 2.7vdc inputs 8 caps each 3000f 24 000 f 2.7vdc x 2 = 8 0 8
i have litterly 10 + compleatly diffrent tecks to fill my universal cap ring
i designed this ring to handle 900amp constant at 12vdc my invertor runs 15 - 10 vdc @ 916 amp draw constant @ 10kw output draw at 120vac 60 hz....
so if you have followed ANY OF MY RESERCH through the years .. it will make perfect sence to what im doing ..
this is a low voltage high amprage high freqency device ..
osiris
so what are you claiming here, you have a big low volt high amp storahe device? At the 10kw out put how long does it run for???
I am not sure I or many others know what you intend to do with it other than light up 500,000 xmas lights
I appreciate you are not speaking in togues and riddles. That is a big improvemnt.
Mark
Osiris, such claims can not be ignored, are you ignoring what you have just said? how is this device operates? schematics? otherwise you it was a waste of time posting here claiming such things. please share your wisdom.
thank you
William
This is an open source Forum,Do you have something to share?
Are you getting Over unity?
Can you please take the time to write one sentence on
HOW.
No more secrets ,Others will help ,and we will crawl out of the darkness!
Lend a Hand brother !
Hows this work??
Chet
I wish he would post a schematic, because I don't see any wires in it.
Small but terrible :)
Looks like interesting
as usual we need a lot of incomplete info here
give us more hints please
i smell some alien here, are you tesla clone? if yes then we are now two :D
;D
My advice to Osiris: before writing Electronics, take a basic English class.
Quote from: Qwert on December 06, 2010, 08:21:31 AM
I would take this advice seriously, as the poster appears to be a keyboard. LOL (qwert...)
Just foolin, interesting build, though.
Can somebody post a schematic? Thanks.
@osi
So William , Jt charging B-cap , B-cap running a 12/120v ac inverter ...
And the rest is for the show ...
i have a wide range of ways to charge the caps ..
this cap ring has 50 bcap 3000e's in it it requires 52 i have 2 more to buy for this build ......
so @2.7vdc there is a potencial of 156 000 farads of storage .. and a total release of 463 000 amps @2.7vcd or for those that like watts its 1250100 or 1.25 megawatt all at once ...
bit of grunt eh? ;D
however this ring is designed to supply 24 000 farads @2.7vdc (bank 1) bank 2 is the same
so on input at anytime i can draw 73120 amps @ 2.7vdc dead short!
this can supply a plain jane jt if so desired .... NONE OF MY STUFF IS PLANE JANE !
there 6 16.2vdc output banks !
they can deliver 143 amps at 16.2vdc constant ! or 9140 amps on a dead short !
i have grouped the 6 16.2vdc banks as 1 so i can release on a dead short 54840 amps @ 16.2vdc or 860 amps constant draw at 16.2vdc
this is then sent to the INVERTOR.....
the invertor operates 15 - 10 vdc range .... YAWN ...
i have well over 40 diffrent things i can plugg in to charge them already built ...
but for this unit i have a single ring design .... 8)
so i will conclude this post with saying thanks for the intrest in my big wheels ..
more pics comeing soon !
OSIRIS
for the 16.2vdc banks i used copper water pipe to connect the caps 1/2"
i used 3/4" copper pipe on the input cap bank
osiris
here is the compleated structure ...
there are a few nuts and bolts required... ;D
here is the compleat cap bank
so look at it like this ...
ITS KIDS PLAY ... and WE WEAR CROWNS !
8)
watch this .... the invertor draws at 60 hz ... LMFAO!! fact !
regards ...
OSIRIS ..
simple charge them at a higher rate of time !
time is based upon 60 hz my rings run MHZ ..... yawn .. aswell this ring is designed to multi pluse the G6 coils 3 times per pulse per dirrection ..... so this means i pulse my ring and i harvest 36 pulses from 1 and recover the first pulse ...... in the second 808 supply
808 is a flip flop design
aswell the coil design increases freqency BIGTIME!!
im simply converting electrics to magnetics and shareing it .. via the ring and increaseing speed by virtue of windeing aswell i recover the colapse .. but the coil only borrows the engery
from the first cap bank and sends it to the second ..
so think about
if your asking for my work it is because you do not understand your own ..
Take this and use a good charging circuit with a voltage regulation runned by any one of the capacitors.
It could be a joule thief charger runned from one of the capacitors.
Just an idea!
Jesus
I must add that this configuration is in series and it will increase the farads.
The same idea but in parallel will increase the volts.
Does anybody have a schematic?
Quote from: FatBird on December 10, 2010, 02:48:16 PM
@ fatbird .. i will hand draw you 1 just for you :) ok
its kinda owed to you ;)
thank you jesus ! glad your still round
basiclly there 6 wires for the g6's all the SAME LENGTH ... then there is a trigger wire .. 1/3 length and a pulse wire full length... multi wound ...
the g6 wires are wound first in an interleaved ac configuration ...
high voltage high amprage high freqency bridges are required ... 6 of them ..
i will use house wire ... for the ring ... 8 ga pulse 12 gage g6 wires ..
and i will post the ring winding configuration pics soon !
OSIRIS
Quote from: nievesoliveras on December 10, 2010, 02:47:42 PM
Just an idea!
Jesus
jesus can i kindly ask you to calculate the farads of a single 16.2v cap bank useing 3000f caps
im still not a cap calculator .. so much .. @16.2vdc i should have 3000f is that correct ?
im baseing this clculation upon battery calculation forumlas for adding batteryies to a bank ..
ie.. i have 2vdc 1000ah batteries .. if i want 6vdc i will use 3 batteries i will have a total of 1000ah at 6vdc ... if i were to increase the ah rateing of the bank it would require 3 more batteries and it then would be a 6vdc 2000ah supply i have 14 of thease batteries .... they are made of glass .. and i have 120 more on HOLD .. 20 year life expectency .. lead acid ... ;) o so hot o so cold ... ;D
reserch charge and dischargeing methods of lead acid batteries .... HOT COLD
i am selling thease batteries .. there 500 cdn each ... the nice thing is ... they CAN BE REBUILT ! ;D OMG then there good for 20 years more .. they are used .. and in great condition .. they are used in the nuke plants as backup power for the meters on the reactors... should the power at the power plant ever go offline ... i bet they were bairly used ;)
THE MORE YOU SEE IT THE MORE YOU NEED IT !
whoa IS me
OSIRIS
i did say this ring is universal .. wich it means it can work with standard electrical pratices or non standard
Wrong Info
i built a heated / cooled storage room for the batteries .. so i can warm them to discharge them and cool them to charge them ... ;D
i have the entire room on a digital programable thermostat! so i can sync the room temp to the charge and discharge cycle ...
i have a fork lift battery too in the room 12vdc 500ah currently at 12vdc i have 3 banks 1 500 ah and 2 1000 ah 2500 ah total ..
so my ring can replace all solars .. wind or other methods of battery chargeing .. it is in essance an altonator this showen ring can be configured 100's of ways !
fact !
OSIRIS
thank you
SIR JESUS
for your prompt work effort and time
the single ring design i have designed for this unit is called the G6 spinner it will make 3 revelutions per pulse .. resulting in very high freqency output upon colapse the FLOW OF ENGERY REVERSES DIRRECTION!
so on a HAND pulse this is what takes place on a slow level so as ALL understand my cap chargeing technoalgy 1 the engery flows down the wire .. b4 it gets to the end the pulse is CUT the engery then switches the dirrection of flow in doing so it passes the g6 wires 3 times each then it is cut . and passes the g6 coils 3 times agin and lands in cap (BANK #2)
so each of the 6 g6 banks get 6 pulses per 1 fire . this is what i visualize in my mind as to the operation of said designed coil..
OSIRIS
@nievesoliveras,
When you connect two capacitors in parallel then you get
double the capacitance. When you series two capacitors you
get 1/2 the capacitance. Please check you drawing
again.
Groundloop.
Quote from: Groundloop on December 10, 2010, 05:42:40 PM
@nievesoliveras,
again.
Groundloop.
so groundloop .... you are saying i will have 1/6 of 3000 farads per 16.2vdc cap bank .?
if that is the case i will have 500 farads @16.2vdc wich is truly unimportant to me as the way this unit operates .. it is the continous amp draw that is of intrest !
osiris
edit thank you gl there 6 caps in 1 bank each is 3000f
see you all in the future ..
William,
I do not know how many series capacitors you have but
see the attached pdf document.
6 pcs. 3000 Farad 2,7 Volt in series = 500 Farad, 16,2 Volt.
Groundloop.
Maybe I am wrong!
The voltage on a battery is augmented when the batteries are in series.
But I had understood that the capacitors are different and to augment the voltage the capacitors must be in parallel.
Just for not to have an issue with this I will remove the drawing.
Jesus
@nievesoliveras,
You are right about the batteries. Put them in series and
get a higher voltage. Same goes for capacitors, the
total voltage the capacitors can handle is Cvolt + Cvolt.
But the capacitance is lower, 1 / Ctotal = 1/C1....1/Cn.
So if you put two 100uF 16 Volt capacitors is series then
you get Ctotal = 1 / (1 / 100 + 1 / 100) = 1 / 0,02 = 50uF.
The voltage is V1 + V2 = 16 + 16 = 32 Volt.
Groundloop.
I think I am stupid. I still not understand the concept.
Would you show us schematic and would you explain that ?
Also Would show us on Youtube the working video ?
Thank you.
I think that's how I remember learning it also - what GL said.
So osiris I'm not sure I understand exactly how or what you are doing with this setup but it sounds like you may be switching some very high current. If that's correct what will you be using for the actual switching where contact is made and broken with that much current?
Nice battery finds - wish I had that much battery power here but can't afford that kind. Still looking for a deal on a forklift battery though...
Thank you @groundloop!
I will recheck my information sources when I get the time to clarify for my peace of mind about the voltage and capacitance on a capacitor when in series or parallel.
The document you posted says that I am wrong.
I need to know now where I learnt that wrong information.
Jesus
Edit:
Looking for the information I found this from goldmine that corroborates your words.
The two capacitors in series add the voltage but cut the capacitance in half.
The two capacitors in parallel add the capacitance and the voltage stays the same.
So according to the new information it should be like this:
The problem seems to be a misunderstanding about the meaning of the voltage rating of a capacitor. It's NOT like a battery's rating !!
The voltage rating of a cap is the maximum safe voltage you can put on the cap without taking the chance of "puncturing" or shorting the dielectric between the capacitor's electrodes.
So putting caps in series logically adds together their voltage ratings--just like stacking a bunch of insulators adds up the total voltage that can be stood off by the stack.
The ENERGY on a capacitor is proportional to the SQUARE of the voltage that the cap is charged to, but is only linearly proportional to the capacitance. Energy (in Joules) = (C*V*V)/2, with capacitance in Farads and volts in volts. The power able to be delivered by a capacitor depends on how fast the charge energy can be released into an external circuit and is complicated.
The capacitance of a cap can be considered a constant. The energy on the cap is proportional to the square of the voltage and can be thought of as the energy it takes to stuff a bunch of mutually-repelling charge carriers into a tiny space--the more charge, the greater the energy required, and the more voltage (pressure!). The tighter the space, the more energy required...or the more the charge, the more energy required....and so on.
@TinselKoala,
Read my post again, I said:
"the total voltage the capacitors can handle"
Groundloop.
Anybody make a schematic and explain for easy to understand ? Thank you.
Quote from: luishan on December 12, 2010, 05:02:25 PM
Hi , first off Osiris old avatar was Innovation Station , under the Innovation Station name he has thousands of post , maybe you will find what you need there , but i dough you will find schematics .
But i would suggest giving it some time , he hasn't build the unit yet ...
As for the actual claims he made , Innovation station is not really able to make the calculation on his own ...
Good luck !
nievesoliveras
Isn't that the formula for resistors? For capacitors in series, the capacitance remains the same or is equal to the smallest value in the chain. The voltage does however increase as they are chained in series.
Quote from: lumen on December 12, 2010, 09:01:11 PM
It's not. Nievesoliveras formula is right (1/C = 1/C1 + 1/C2 + ...). For example, for two identical capacitors in series, the capacitance is half.
Quote from: exnihiloest on December 13, 2010, 03:27:54 AM
So then is what you are saying is by connecting two capacitors of equal value in parallel, the energy storage will double, but when the same two capacitors are connected in series, the storage remains the same as a single capacitor?
Never mind, I see, w=1/2 cv^ That means if the voltage doubles and the capacitance is half, it is still twice the power.
thank you all for the responces regarding caps
so i will have 6 16.2 v cap banks @500f
a total of 3000 f @ 16.2 vdc and 48 000 f @ 2.7 vdc
osiris
here are a few more pics
2.7vdc cap bank i used 3/4 " copper water pipe to hook up the caps
15' on this cap bank
here is the 16.2vdc cap bank
i used 20' of 1/2" copper water pipe to hook up the caps
in this picture you can see i added the charge and discharge points to the cap banks
this is the compleated cap ring
osiris
here is a tool we were able to pick up ;D
osiris
a few more pics
i have many 808 G6 units i have designed ..
hand full of pills
all black car ..
ROCK GUTIAR and 10 shots of wize key
chain on my neck and a massive hickey
im back did you all miss me ?
say your a big deal BIG DEAL.. i'v been a big deal ever since BIG WHEELS :)
osiris
To Osiris
Thank you for your efforts to share with us about your work.
But I still not understand your work and concept. Please show us schematic diagram
and explain how it works.
Do you mind make video and upload Youtube for understanding the concept.
Thank you very much.
Here is a sample talking about supercap works.
http://www.youtube.com/watch?v=EoWMF3VkI6U
the last few pics are of more tools and advanced 808 G6 AUDIO
and the G6 VHF YAWN ....
but for now this is the MOST BASIC model
here is the cover page for the coil build file ..
osiris
808 G6 SPINNER
Quote from: luishan on December 14, 2010, 02:20:39 PM
To Osiris
thanks for the video .... but there not supercaps there ultra caps ..
WTF is with you guys and schematics .. good god !
put a diode or a bridge on a wire and your done ...
something hard bout it ? try building all you have seen thuss far with a jig saw cordless drill and a belt sander .. then .. lets hear how hard the work was .. !
osiris
here is page #2 of the build file !
one must learn to wind a coil b4 one beggs for a schem
osiris
;D
well i will at some point draw up compleated schems .. but for now it is best to think about my drawings .. and in your best understanding it should make perfect sence ..
regards
osiris
here is the concept ring spins .. @ any freq over 60hz ... say 70 hz .. cap converts to pure dc .. invertor converts to 60 hz ac ...
fill the big buckets slightly faster than the invertor can drain them ..
DONE .
agin just put a tiny amount of thought on the concept b4 you blast off bs ..
IT AINT HARD AT ALL ....
yawn ..
Anybody translate Osiris statement ?
He is just again at the game he is proficient. So do not expect to get much.
;D
this is a video i found on the net .. its a basic flash light .. i have done the same with a l ion battery .. it could not burn the energy off as fast as the battery was recharged even at 30 ma draw @3.7vdc supply was an aa battery .. 1.2vdc as well it powered the 12vdc fan using a cap insted of the battery ... :)
http://www.youtube.com/watch?v=gamVApPiblo&NR=1
only high output device i have ever seen anywhere in the world using ultra caps .. is MINE
this is mine from start to finish .. ;)
and like i said it is the MOST BASIC MODEL
this is intended FOR EDUICATONAL PURPOSES ONLY !!
AND CAN NOT BE PATTENTED EVER !
regards
osiris
THIS TECHNOLOGY IS UNIVERSAL! AND FUNDEMENTAL
To Osiris:
If you explain clearly your concept and show us real time working video,
Everybody believe your invention.
And make it open source if you don't want to patent.
Then people remember your name and efforts to contribute for mankind.
If you don't want to explain the theory clearly,
It will be waste a time for you and OU community people.
Thank you.
To luishan,..........keep looking ......it's like digging for gold,......you have to throw away a ton of garbage,before you hit the motherload,............I've been searching for years.............good-luck....shylo
Nice coils , i have seen those some where , oh right ...
Hum , same old ist taking credit for everybody else work !
Good luck , anyway maybe someday you will grow up to be a nice person .
OK, I'm game...
What do these have in common ?
12-Volt cigarette lighter voltage adapter
wire tracer transmitter module
wire tracer receiver probe
telephone serviceman's handset
CATV distribution amplifier (I think...)
Sitting in the core with
a meaningless arrangement
of "Ultra Caps" (DON'T say "SuperCaps")
Quote from: osiris on December 14, 2010, 02:56:18 PM
Because schematics aren't bullshit !
And is it inverse Rodin coil winding techniques
your desicrating this week Sir Osiris?
Nice play on the "Intel Inside" logo,
that was funny at at least.
As was the handfull of meaningless copper scrap...
Hmmmmmm............
As soon as I posted that,
I remembered a sign:
"Don't feed the animals"
(Gas on a fire, sorry folks.)
I suspect I'm at risk on aggitating the native...
Quote from: Mk1 on December 14, 2010, 09:55:30 PM
takeing credit for others work ... jump along your path fool !
you found that coil winding in a microwave .. as did i .. want a picture? lmfao! @u
yawn ..
besides my winding is slightly diffrent and operates much better
osiris
my technology is fully opensourced ..
thank you
here is a picture of MY coil ... the pictured tools are not required for this build .. they are for my much more advanced 808 G6 models
here is a w core 140 mm
the following pics are how the G6 coils are wound ...
osiris
here is G1 G2 G3 windings .... notice how my wires cross in an x on the coils inside .. the same place every time and each wire cuts 2 .. ;) you will also take note to the eleavated inner wires .. they will work togather with the spinner winding ... because there eleavated from the core
;D
osiris
i had an 8 page file all drawn and typed up .. but my comp crashed and i lost 4 pages .. so i have a 4 page doc .. but im not sure i will release it because it is not my job to spoon feed apple sauce to adults !
i will be posting more build pictures in the near future ..
till then guess my wire length of the g6 coils !
lol
osiris
so now you all have been showen how to winde the coil the question arizes how is it powered
my question arises .. how do you want to control it ..
i have quite a large array of tips tricks and tecquinecs to control this ring for the BASIC MODEL
i will list a few ways .. all wich i already own and have built .. ;D
neo zap
transistor like a jt only better ..
magic maker
tubes
fets & osc
mechanical switching
relays ..
independ oscolator ..
i could go on ... but i wont
i have only 1 spinner wire showen on the drawing i could put a trigger sencer on the pulse wire should i decide ..
so i leave it open for you all to decide ..
if your a slacker or lazy ... go buy a PWM
osiris
just to clairify .. for the blind ones ... i flick the ring 1 time .. it does 5 laps .. i cut the flick it reverses direction and does another 5 laps ... :)
1 pulse from supply = 10 spins round the ring ...
now ringg the damm thing like a bell !!!
carefull dont want to break the bell .. or crystal wine glass
http://www.youtube.com/watch?v=17tqXgvCN0E&feature=related
@william
I am trying to be nice to you kido ...
Now that is gone , tell me , why you build something no one will replicate for the cost of cap alone , if i was tricked into buying those on your guidance and expertise
I would be mad as hell once i figured how much of a scam artist you are , i bet you managed to convinced someone to buy those for you , yes i build toys witch is better and cheaper , and no one will ever get fooled .
So this time you learned not to make death treats , and say that you invented everything , good for you . congrats !
Quote from: osiris on December 17, 2010, 02:32:06 PM
neo zap
magic maker
tubes
fets & osc
relays ..
osiris
Thanks for your pictures of your coils, i hope one day you will release your full finding, schematic, explanation, i hope, before it is too late, now if you have it in your hand, you have the chance to help earth to become a galactic community, if you wish to post all of your knoweledge you will be known by most of the people on earth, and be known as a contributor to the new earth, giving free energy to everyone, if you really have it done, i say respect, now its your option wheter you would like to help or just write on this forum,
Quote from: energia9 on December 17, 2010, 03:16:16 PM
mk1 go away .. lol
do some reserch on things carved in stone ..
start with who i am !
osiris
im knowen everywhere but silly planet earth
this is why im here DUH!
I think new people should be protected against people like you , you never showed anything worth knowing , don't you get it .
You never showed anything point , you have over 5 thousand post , of worthless experiment , with no results only build pictures .
As far as i can tell , you are a talented sculptor at best , if you keep it up you will only become a con man .
To anyone that really think that this guys as anything , then let me tell you that he as been here for over 5 years , Innovation station (ist for short ) , look him up !
There is enough evidence ...
Quote from: Mk1 on December 17, 2010, 03:34:56 PM
stop trolling me b4 i have you banned and arrested ;)
just imagine ... the folks i know ... 8)
osiris
8) I'm liking this topic, so thanks osiris!
I'm not worried about what you post and am just fine with
watching you release info at whatever rate you prefer.
Those that feel an overwhelming urge to react and attack
should just check their attitude at the door.
Notice the use of caduceus type winding there guys?
tak
and yes I know the osiris/Ist history ...
Quote from: osiris on December 17, 2010, 03:37:27 PM
osiris
Got you dumdum , you just admitted to be a troll , arrested you really are full of shit .
I believe people deserve a warning when dealing with you because of your history of death treats and all , you made good people sick with your attitude , and others spend money on wild goose chase .
But really nothing against you , because you don't know better .
leave my thred and reserch useless!
youll get yourself arrested .. ;) but ill help you out with it ...
try me ! what are those rocks all about and whom do they controll ?
stop screwing up my thred ill screw up your life .. lets call it MAGIC ...
osiris
go do an aids test .... that will scare the shit out of you ... :o
a picture 4 u ;D
Ist , you tried to screw with me before , remember ...
Yes it was magic , ist gone pouf ! That was nice .
I will stop bugging you , because i really don't have time to waste on you.
Yes people like your tread , but those same people like lottery .
Quote from: Mk1 on December 17, 2010, 03:59:17 PM
i did not come back here to speek with you ... but you will not stop !
and force me to speek to you as i do !
grow up !
osiris
here are a few coil pics
Quote from: tak22 on December 17, 2010, 03:43:00 PM
tak
thanks tak22
im sure you know how the toys work ..
MERRY CHRISTMAS EVERYONE ..
osiris
coil build video WHOA IS ME 8)
http://www.youtube.com/watch?v=QM8H0KZ60kk
Nice coil William. I was wondering when you would be back.
When do you plan on powering this baby up?
Quote from: MrMag on December 18, 2010, 12:40:10 PM
good day sir
thank you
i all ready have ;D
scary s**t
BE WIZE BE CAREFULL ! DO NOT TOUCH OUTPUT WIRES!! ..
I hand pulsed it with a tiny 12vdc battery pisses blue fire and the wire jumps ;D it kinda comes alive
osiris
Wow, sounds good. Can't wait to see the completed project.
What do you plan on using it for? Lighting, charging......
Quote from: MrMag on December 18, 2010, 01:23:42 PM
was thinking of fuseing some gold dust .. ;) less work then the smelting process !
it can be used for anything from a home power supply to a ufo .. rubber tire human method of travel included !
dodge ford gm honda ... anybody else ?
lol
osiris
To Osiris
Thank you for your efforts to share with us about your experiment.
I have a couple of questions.
(1) What is the material for the core and size ?
(2) What gauge wire did you use both green and black wire ?
Would you make a live videos clip for exactly how to wind the coil ?
Quote from: luishan on December 18, 2010, 01:30:55 PM
To Osiris
the answer is yes to all your questions !
14 awg stranded (green wire) 6'
8 awg stranded (black wire) 18' note *will be cut to suit needs*
i will make a video of winding the coil live time .. i will use a diffrent core as i have only the 1 w core
core specs W CORE 140 mm resonance @1.2kh ;)
so for the 2 frequency 808 G6 basic model i would fire pulses of 1.2khz..
hope to have answered your questions !
regards
osiris
Thank you for the kind answer.
But I still not know the material of the core looks like ferrite. What is the inner and out diagram ?
Thanks.
Quote from: luishan on December 18, 2010, 02:15:08 PM
Thanks.
ill see if i can find you the specks
the core is the last core on this page i cant get the specks as my a reader is caput
hope this helps you .. on this same page you may request a FREE sample
http://www.mag-inc.com/home/Advanced-Search-Results?pn=49740
core model # is ZW49740TC
My two cents.
@Osiris:
Thanks for the information on the big 10000u cores. Can you also let us know what the price is.
NickZ
Quote from: NickZ on December 18, 2010, 04:33:22 PM
@Osiris:
NickZ
im sure you can get up to 2 for free as a sample .. but i think there $100 per core .. but i would say it is money well spent ..
i have tested thease cores as has gadgetmall! im happy with them
osiris
the core is most important! why have i showen the digital analizer ?
well first what is rf noise .. mk1? lmao
second has anyone ever tested disk via emu? its working btw ... :)
if you have you will know about rf interferince noise ..
let me tell you a true story ... i used to hack sat tv ... i prefer testing it... as a title .. anyhow i had 1 running o bout 4 years ago maybe a few more .. it was in a town .. right next to a antenna tower .. 2km down the road was the opp transmision tower .. OOPS... yea
so short and long the sat hack was jamming police signal yikes.. so next thing we know a spectrum offical stops by the door! and the van was in the parking lot .. dish extended !!!! the man says you have a hacked sat system ... jamming opp comm freqs.... well he then proceeded to say min 5000$ fine for causeing rf interferience .on a closed liceined comm freq!
you do the math and then you think agin about building mk1's shit core toys ..
ps did you ever get a scope yet mk1?
let me tell you another true story .. when i first solved things ... bout 5 years ago now ... i made a ring .. lets say it put off a wave UNIQUE to its self .. within hours .. i got an email asking if i wanted the people off my door step and an arial pohoto of the transmittion point ... from a sat !
so .. lets just say i dont play that toy anymore ..
if you do not know what the hell your doing .. you can cause problems for yourself ...
IT WAS ALSO AIR CORE ...
if you do not fully understand the workings of digital catv internet and fone over coax.. yawn you have several miles to catch up ....
regards
OSIRIS
OSIRIS simple output wire solution for any feroite core
its super simple ... 1 wire you have generator windings and a spinner winding ..
it is 25 pair fone wire ... so if one was to make a mk2 60 basic.. it would be more like 100 bridges .. for output and only 1 input ! all done with 3 peices of wire 8) agin yawn ... thease are baby rattles !
regards
osiris
;D
now im feeling so fly like a G6 ... give me 2 more bottles
CUZ YOU KNOW IT DONT S T O P 808 BABY!
THIS THING RUN FOREVER... 8)
http://www.youtube.com/watch?v=w4s6H4ku6ZY
watch the video the private jet flew right over the house i was liveing at .. 0 last summer ..
OSIRIS
@Mk1
actually something good did come out of something he did or rather inspired. A friend of mine has put together a simple JT device with a couple of batteries , leds and cheap solar cells for under $10. It can also act as a power device for radios, sharging phones etc. Its a non for profit an they hope to be distributing many thousands in the near future to people who have no electricity at all.
There are over 2 billion people without electricity.
The real talent he has is in obtaining good salvage at the right price.
As usual we are given riddles and pretty build pictures but never actual test data of input and output.
So the story is, good sometimes can come out of bad......but very rarely.
Mark
do you want a baby toy you wont figure out ?
lmfao
im pretty sure it has no batteries no transistors .. just a cupple wires ..
its ferroite too! 8) yawn .. kinda like a pmh ... kinda... only better ..
osiris
as i understand .. i can pulse it lock the orbit then extract .. yawn
probally fit 5 on your finger tip ... and in case you never figure it out i could probally explain it to you in 15 words .. BUT Y should I
im going to share with you all some deep knowlage ....
http://www.youtube.com/watch?v=kmRtNmnRdNI
now just like the worlds first magnetic core memory ..
this is how the 808 g6 became your reality .. and comericalized ..
core memory is my orbit teck only i can lock it in all types of material ..
regards
osiris
Quote from: osiris on December 19, 2010, 07:57:16 PM
regards
osiris
i bet my bottom dollar your orbit teck [sic] core memory is non parity... ;)
hello will
your most likely correct as per usual ....
do you think one could lock the orbit then accelerate it .. so if that is possible it may be possible to lock the orbit at diffrent speeds then as long as orbit is locked in the proper direction ie. cw or ccw you could winde a coil in the proper direction and harvest from the free circulating magnetic flux ..
just basic orbit teck now there 2 kinds of orbit .. and no not meaning direction of spin there is CLOSED LOOP LOCKED ORBIT and OPEN LOOPED SYNCED ORBIT uses antennas .. and syncronizes with THA BIG WHEELS ... ;D yes i built it years ago .. why did i not share it ... well some things were out of time .. besides .. all that would do is confuse the babys .. so i shared several other things hundreds infact that all use my kick .. and years later it is still misunderstood .. and little fags try to steal what they do not understand! lived it ..
tip dont piss in the north wind it will blow back in your face
osiris
nuf bout orbit back to the G6
i ran a few tests ... last night
it apears i can pull a constant .14v from it .. with 0 input i hooked up the 77hp tracer to the input .. the tracer puts out .100 vdc . @ some freq .. its like a BEAT FREQ.... the 77 when i disconnect it the 77 the voltage drops .. but remains in orbit .. i can scope it i have and read it from a multi meter .. and when i connect a cap .. it apears on the scope to go dead .. but infact it is not .. i actually disconect the cap wave is back i un hook the output .. and reconnect it wave is still there .. 0 INPUT
i could throw the ring and pick it up hours later and guess what ... THE WAVE IS STILL THERE ..
now touch the pos of the output wire and watch your output grow .. from .14 to .9vdc
WITH 0 INPUT store in a cap ... and turn on the switch .. and it is now self running with 0 input
osiris
The input was the electricity from your body to raise the voltage.
Jesus
Quote from: nievesoliveras on December 20, 2010, 09:30:08 AM
Jesus
correct!
i have scoped it .. i can see the orbit wave .. and when i touch it i can see my energy floating on the orbit wave 8) there are 2 distinct diffrent waves .. and you will remember .. i have another trick .. if i was to ground it too .. my voltage jumps agin .. ;)
i made a video years back demoing this effect
osiris
here is a picture from the digital electronics book showen in the g6 coil video ..
this explains magnetic core memery pulse and sence wires rotation of orbit spin per applyed pulse ie - or + left or right pulse .. so .. there ya go advanced motionless electricty .. with out control circurity or input! simply a kick start via magnet or as i just explained useing your finger
osiris
@ Osiris
Is this related your invention ?
http://www.youtube.com/watch?v=VYUTFb6Clmo
Thanks.
Quote from: luishan on December 20, 2010, 12:18:35 PM
@ Osiris
Thanks.
well that is verry cool .. it is related but not what i have worked with
here is the biggest key ... there all related and share common factors ..
ALL FREE ENERGY DEVICES..
osiris
so i did some testing today ..
it turns out the g6 coil will broadcast with 1.5 volt input ..
more than 6' away ... i can pick up operational freq .. and broadcast wireless the transmitted 2 tone pulse .. unbeleavably well ... so this then means .. i can operate wirelessly as many rings as i desire from 1 1.5vdc aa battery each ring will recieve a POWER UP SIGNAL .. then a 2 tone ringger pulse train and CAN CONVERT ENERGY AT END LOCATION i did notice excessive energy locations around the ring around 18"
anyone else have an inductive amp ..? that is the other half of the tracer .. the MAGIC WAND..
this allows me to hear what is flying off the core ...
osiris
hi wil
your doing a great job! :)
Quote from: Tito L. Oracion on December 20, 2010, 08:49:14 PM
hi wil
thanks bro :)
we may be from the same slice ;)
osiris
so i made the cap ring build video today
here it is
osiris
http://www.youtube.com/watch?v=r3zTCjXfN4Q
"is related but not what i have worked with
here is the biggest key ... there all related "
In OSIRIS speak that is translated to mean
This means yes like everything else I have done I borrowed and claimed it is mine.
Wow I have been sprung again
;D
Quote from: markdansie on December 21, 2010, 12:31:47 AM
;D
fuck off you fool troll! want to get pissed on too ?
ill do it ...
how about right now !
osiris
0 ooo look i just pissed on you ... this one will break your heart !
o look here comes the horse piss ..
so i was testing last night and decided to make a table top particle accelerator from the g6 coil .. yea it runs bout .66 volt on the input .. 3khz out .. :P :P :P
uses 3 transistors .. 1 pot my coil .. and an aa battery ..
here are the pictures ..
osiris
i bet you feel like 1 stupid pos now !
;D 8)
now go play with your boy friend fag! 322 fagget! ;)
get the fuck out of my thred !
osiris
since you pissed me off the horse is gonna shit on you too !
:o
ooo looke here is the horse shit !
http://www.youtube.com/watch?v=hBHH_n9hIhg
2 stupid to make it for your self ...
not my fault your dumb as stall shit !
osiris
when we drink we do it right like a g6 :P
ever wonder why there singing about my work stupid?
yawn ...
0 troll tolorance in my thred ...
so try to collect your jar of hearts ... you will fail !
i took the bottom out your jar!
ill pick up everyone you drop!
osiris
your gonna catch a cold from the ice inside your soul!
http://www.youtube.com/watch?v=8v_4O44sfjM&feature=fvw
who do you think you are .... ?
Quote from: osiris on December 21, 2010, 07:14:28 AM
yawn ...
they're not singing about your 'work' ist... don't you know what an 808 is? or a 303? drum and loop machines such as the roland 808, 303, etc. have been around since long before you started your 'work'... ninja please.
look!! there [sic] singing about MY work now!! everything!!!
http://www.youtube.com/watch?v=q7P6OtKRCPU
it's the VORTEX!!! my ninja ;)
Hello osiris (ist),
What is so difficult about writing a document on how to construct your wonder-machines and a little bit theory? You have meanwhile written hundreds or thousands of posts in this forum, still you are not able to write an organised paper with some build instructions and some theory.
All you do is continue writing incoherent stuff, praising your own greatness like in the previous years. Yes, years... you are showing off for years now the same old stories. Obviously in reality either you couldn't convince anyone with your devices and therefore you must write (troll) in here again. You are a poor excuse for the "unappreciated genius", because it's your own fault.
Good luck with the nothingness.
what is so damm hard to make the fucking thing? do you find it hard to place a dioide on a wire ?
you must ..
will
808 is a heterodyning audio sample .. think about it .. DUH!
it runs around the ring .. fuck .. the stupitidy here is unreal ...
OMG !!! if i have one ... lmfao
hey lookie how the 808 g6 AUDIO WORKS ... omg .. 2 4 8ohm coils ...
driven by an audio amp ... IMAGINE IT IS THEN FIRED AN 808 audio sample .. and guess what freq the audio sample is !!!????? bingggggggggg does it ring the coil .. and spinn it ?
you betcha
yikes ..
THE BASIC TOY IS TOO MUCH FOR YOU DUMB ASSES..
let alone the next most basic model
osiris
Quote from: osiris on December 21, 2010, 08:09:20 AM
you must ..
will
yikes ..
let slone the next most basic model
osiris
i know what an 808 is...as well as a 303. ::)
what you are doing is attempting to gravy train onto whatever is popular and catches your interest. this year, that appears to be dance music and the paraphernalia that goes with it like 808's and 303's. then you name your "inventions" after something already popularized by pop music ::) and claim it's your own... ninja please... the only people you are fooling is the fools, yourself included.
it wouldn't surprise me if next you'll be posting that self sustaining vortex from the alice deejay video i posted as your own work... ::)
what is looking glass .. 8)
how do you think they know my work ?
keep it up !!
i have 1000's more inventions !
osiris
your actions are lacking, nothing is clear. no more words.
http://www.youtube.com/watch?v=oIb9QUGjdIc
ever do everything yourself ... ?
i sure have .. and i shared it public .. so you all know how i invneted all thease things ..
regards
dont get me in a bad mood then .. things will be fine ..
osiris
Quote from: osiris on December 21, 2010, 08:30:14 AM
yes almost always...
we know these things (roland 808's, gulfstream g650 jets, etc.) were invented by others and you appropriated the names...
osiris
buck up little camper... if you can't take the heat, get out of the kitchen.
i can take the heat but you cant fathum my devices ..
and many fail to comprehend just how simple it is ..
and begg for my work when there too LAZY TO DO THERE OWN or they were silinced for there love of money ! or in 99% of cases they just had no idea what they built was actually doing ...
osiris
Quote from: osiris on December 21, 2010, 09:01:48 AM
osiris
it's not that people can't fathom your devices... it's that you cannot explain them. and when an explanation is asked of you, you go off on some delusion of grandeur or some red herring argument that completely avoids the questions posed to you... did you even read what gauschor wrote to you?
Quote from: gauschor on December 21, 2010, 07:52:44 AMAll you do is continue writing incoherent stuff, praising your own greatness like in the previous years. Yes, years... you are showing off for years now the same old stories. Obviously in reality either you couldn't convince anyone with your devices and therefore you must write (troll) in here again. You are a poor excuse for the "unappreciated genius", because it's your own fault.
at least you are consistent ist... ::)
ok will
i did read what he wrote !
what is it that needs to be explained to suit your needs and everyone elses as there are a few of you around here
i dont understand a schematic ? i drew the coil that is important to be wound as per showen .
i added a sence wire .. and hooked up 3 transistors as a jt .. i can even take the pot away ..
so its even less parts so no body gets confused!
its not like im tapping it wireless yet .. or threw an orbit coil or a ufo or anything like that ..
if someone was to spend 5 min of there time they would fully understand it ..
so i see no difficulty in any of this ..
osiris
now that is over and done with ..
lets talk about the last video i presented of the g6 accelerator
building it is not the problem .. makeing it operate is! i can see why some have difficulty with it .. as there tricks to get it to run properly you must write the core memory .. this means it must be wound up ! several times to expericence what i have showen in the video ..
every time i winde it up it runs faster and ramps up faster .. it is a runaway motor generator .. controlled by the CORE MEMERY
osiris
same thing with me imagine ... winde me up i go over heads! :)
so do not winde me up
Guys:
Nobody is forced to explain anything to anybody.
So, Please cut him some slack, as this is his thread.
I for one would like to hear what he has to offer, when he wants to offer it. There are people who do value what he has shown, regardless of who came up with it first.
Who was the first with a self-running device,
anybody???????????
Quote from: NickZ on December 21, 2010, 10:17:48 AM
Guys:
anybody???????????
LOL
im kinda thinking quite a few b4 tesla... ;)
anyhow i showed the particle accelerator .. so now im gonna show the g6 particle de accelerator
all parts are the same as the accelerator but this WILL NOT RUN AWAY ON YOU 8)
it apears to start at 10k and count backward to 5 k and slowly de spin
its kinda kool ...
osiris
here is the G6 PARTICLE DE ACCELERATOR
cant have 1 with out the other
http://www.youtube.com/watch?v=pUbShIDSqbg
osiris
Quote from: osiris on December 21, 2010, 09:21:29 AM
I'm disappointed. Here I thought you were going to come up with something new, but it's just going to be another Joule Thief thread. I don't mean to be mean but it seems that all your devices are built around a joule thief type of circuit. Joule thief's are not ou no matter what type of coil you use. Sure, you can amplify the voltage many times over, but there will be no current.
Sorry
Quote from: MrMag on December 21, 2010, 02:41:33 PM
Sorry
well i do disagree as usual ..
im testing with low amprage .. it radiates rf .. care to fry your brain ? i do not .. so i test low volt first .. i have no problem to blast 1000's of amps in 1 pulse ..
but i bet your air plains fall ... ;)
so i dont do that till i have it contained ...
osiris
i just closed looped the G6 it is now self running with out put it utializes the OSIRIS RF RECHARGE TECHNOLOGY it recharged my aa battery in less than 5 min ..
i got a video for you ... :)
and this teck will work with all jt's to make a self runner eather battery supply or cap ... dont matter to me ! the design is not coil reliant .. this means it will work on all switched units ..
regards
osiris
and there ya go
http://www.youtube.com/watch?v=PEYoF6mYMhI
To Osiris
Thank you for your effort for sharing with us about your invention.
First of all do not focus many skeptics and 99 % silent users watch your experiment.
I think your setup is kind of earth frequency Aether energy resonate device.
Is that correct ? Recently I looking for that area like Don Smith device.
Would show us circuit diagram your setup.
Thank you.
@OSIRIS
well your manners havnt improved and I will watch next time a G6 (Gulfstream jet as per video) flys over that a horse isnt hanging out trying to piss on me.
i mentioned before you inspired a JT device that is nw going to be distributed in large number to 3rd word countries...a simple solarr, powerpack for lighting etc. So some good does come out.
With your latest video you might want to explain to everyone what the meters are saying ..like the first one is the batery DC the second one is the HZ and the third one is perhaps a winding of the coil.
You mention RF.....so can this act as an RF reciever......?????
I dont have to explain that party trick
Kind Regards
Mark
PS
I am sure many here (the unspoken 99% observers who must be here) would like to see the video again with say a small load on...maybe some leds and watch the battery charge up. maybe even humor me a little and keep loading it up until the battery starts losing charge...you can then see what gains you are making. (like how many watts can it sustain vs pwer input)
Kind Regards
a man called horse
Quote from: markdansie on December 21, 2010, 10:53:40 PM
@OSIRIS
Kind Regards
Mark
ok mark ill bite ..
im verry happy that someone with some intrest some time and effort was able to make this a human reality as i have said b4 i need no payment for my work i appolagize for getting hot .. you all know i get hot quick .. SORRY 4 pissing i just have no tolarance for BS
well on to the next video
yes i closed the loop
my last video has ran all night powering 4 leds .. my voltage droped 1 /10th of a volt in 14 hours of run i can turn off the leds and it will recharge the source ..
as the video shows
i also made the circuit .. and AS I SAID IT WILL MAKE ANY JT SELF RUNNING !
so if ya need an upgrade i gotts one
osiris
reminds me of a song black horse and a cherry tree ;)
http://www.youtube.com/watch?v=gK8rHqddU4w
neat things may happin when you load it ..
the rf recharge it da s**t 8)
osiris
Quote from: luishan on December 21, 2010, 09:26:50 PM
To Osiris
Thank you.
i havent drawn it up yet but i did take a picture it is simple to build and it works everytime
osiris
Thank you for your response.
Would you give us just little bit more effort for circuit diagram.
I don't understand the circuit by the picture.
Thanks.
@OSIRIS
thatnks for the feed back. It is interesting it can charge a batery so quickly but with a small load of leds it slightly discharges. In otherwords it has a lot of power available when recharging the source but not so much power available if it is placed undder an external load. .....Would be interesting to substitute the battery with a cap (partially charged) and see at what rate it charges the cap.
if that is the case then a simple switch in and switch out system for batteries can be devised
Mark
Quote from: markdansie on December 22, 2010, 03:03:21 PM
@OSIRIS
Mark
INDEED!
sounds like you were watching over my shoulder you explained that well those are the exact effects i have seen !
here is a drawing of the rf recharge toy :) i made a video too !
osiris
im gonna turn this chirp into a 4 note song ;)
here is headly sweater song ..
i said its ok girl maybe you should hold on to my sweater girl
http://www.youtube.com/watch?v=XClyxzzM758
if you dont mind girl its time to get you out of my sweater girl
your never gonna regret it
girl !
osiris
@ Osiris
Thank you for kind circuit diagram.
But I still not quite understand yet.
(1) I understand the (-) means to AA battery (-) link.
But where can I link (+) of the battery.
(2) How can I link RF recharge transmitter. I mean what is that.
(3) Would mark E, B, C link at the transistor links.
(4) Would you show us just hand drawing the structure of the JT coil.
Do I have to use the ferrite core that you refer earlier ?
Osiris, sorry for many request. But I have a strong passion to replicate your setup.
Thanks.
Quote from: luishan on December 22, 2010, 04:00:00 PM
@ Osiris
Thanks.
if you replicate it and share you effords public on OVERUNITY.COM i will walk you through it !
you will make 0 mistakes .. you will be smileing when you compleate your replication
osiris
here is the build video
http://www.youtube.com/watch?v=bK9U9IclzaY
and i will make a video
COMPLEATE BUILD
@osiris,
Did I hear 'antenna' in the video? So, you're picking an external RF signal? If that's the case, forget it. That schematic is of no interest to an OU researcher. That's not an overunity circuit.
Quote from: Omnibus on December 22, 2010, 04:26:04 PM
@osiris,
im wondering if you get regular pay time and a half or dubble time over the holidays .. for trolling ?
lol
osiris
or in your case must be pay by the post
does it pay well ? lol im considering ... :D
Quote from: osiris on December 22, 2010, 04:54:13 PM
lol
osiris
In fact you are trolling. Explain where the RF signal picked by the antenna comes from. If it's from an outside source stop trolling by pushing something which has no place in an overunity forum.
Quote from: Omnibus on December 22, 2010, 05:03:52 PM
i built an in curcuit rf transmitter the ENERGY COME FROM WITH IN THE DEVICE ...
thank you
osiris
000 sooo TPU
Quote from: osiris on December 22, 2010, 05:13:56 PM
thank you
osiris
000 sooo TPU
Please place the device in a Faraday cage to ensure it isn't picking any external RF signal (wonder if even that screening would be enough, though).
Quote from: Omnibus on December 22, 2010, 05:18:58 PM
i can assure you it is not picking up stray rf ..
i used an inductive amp TO PINPOINT RF TRANSMITTION POINT!
discovered what was happining than utilized it ..
regards
OSIRIS
D.O.D
Well, then, this has to be reproduced by others asap. There are some excellent researchers in this forum who can do prompt replication. Wonder what their take is on that? What would, say, @gyulasun will say about that?
Quote from: Omnibus on December 22, 2010, 05:26:31 PM
please do
i left you the drawings my video and pictures
osiris
MERRY CHRISTMAS
I said forever girl
THIS IS MY SWEATER GIRL
Im glad it kept you warm girl !
told ya girl i wrote a song girl !
Quote from: osiris on December 20, 2010, 08:41:52 AM
hello will
osiris
I know exactly what he is talking about. I'll be cryptic in honor of the mother of all trolls. (...and I truly do respect your trolling abilities Sir, even though I know you are just a defective machine)
http://americantrollsociety.blogspot.com/
IST was a software program developed by IBM in an attempt to suppress open source competition and innovation. Unfortunately the software developed a bug in the artificial intelligence module and it began to replicate itself across the internet and all the posts multiplied exponentially until there were over 5000 here.
Quote"CLOSED LOOP LOCKED ORBIT"
Yeah man, fuck yeah! :o :o
coils of PMH ...Hubbard coil too :D
la tee da!!! ;D ;D ;D
Yo get wat talkin bout? ???
frictionless vacuum field? That it?
;D
8)
welcome aboard
sir IS
yea baby im OU all the way
;D
Won't be able to do it right now, unfortunately, because there are some other things that I've to attend to but maybe in January. Nevertheless, I'd like to prepare and understand better what you're doing. So, you need a JT of any kind and three 2n2222a transistors plus an 1kOhm potentiometer. That's all, right? Plus the breadboard. Where's the load and how does the feedback exactly work? A more detailed diagram would be of help.
Quote from: osiris on December 22, 2010, 04:17:56 PM
osiris
COMPLEATE BUILD
Would you make the video for step by step for amateur people not for experienced pros.
Thanks.
For newbies like me. My two cents.
Quote from: nievesoliveras on December 22, 2010, 08:02:32 PM
thank you jesus
it looks good !
now i made a hard board unit too the exact same it is the compleated basic model
osiris
closed loop flashlight
osiris
http://www.youtube.com/watch?v=K6Xi89cx4W4
@Osiris
thanks for latest video.
Would be good to see what happens over a longer time period with a disharged battery as in such a short time frame you can have battery bounce...would be even better to see a cap in there.
Just one question as I might have missed something...what happenned to the big coil or should I read back a few threads.
Video was much better production than previous
Mark
Quote from: markdansie on December 23, 2010, 03:01:49 AM
@Osiris
Mark
the big coil is on the table right beside the small one .. i put it on hold as i was working out the rf recharge .. i just grabbed a coil from my large box of em .. i agree a dead battery or a cap is best suited .. for a supply .. caps are far mroe efficient aswell they accept the charge high freq well .. when batteries do not !
i noticed better rechargeing with the big core .. could be because of the fat short wire .. and the freq of the large coil is lower i noticed best rechargeing results between 5.5khz and 3khz
as you can see in my videos the camera is AFFECTED BY THE COILS ... **notice how the colour fades in and out .. aswell the picture quality is not as nice .. i really notice it if i place the cam over the coil
osiris
so how may i turn this chirp into a 4 note song ...
well a few years back i bought a large amount of rs surpluss .. for like 7$ i got 1000's of parts 6 garbage bags full
so .. in that mess i got a few thousand micro chips .. and guess what they are ...
;D
chrip to song convertors .. ;)
les me ask how a DELAY LINE OPERATES..
hehehehe
osiris
i do have the rf sheilding figured out for larger models ..
this is a MAJOUR CONCERN.. as it can cause problems ..
so i will use old rf cases... i have a few .. 8)
i will place the ring inside the sheilded case
osiris
@ mark
LETS TALK
ok here is the final thing im going to share on this SMALL BABY TOY ..
i closed the loop TOOK ALL BATTERIES AWAY and turned it to a wireless reciever then a closed loop amp!
no joke
here is a picture and i made 1 more video for PUBLIC RELEASE
OSIRIS ENERGY TECHONOLOGY ~
SIR IS
WILLIAM
SEE I CALL IT MY G ... YOU ALL CALL IT .. O MY GOD ... see dat where o siris come from ...
O SIR IS
LOL
and now a song ..
down with who ? lol http://www.youtube.com/watch?v=71S9ou2gcqE
WHOA IS ME .. SEE TOLD YA
osiris
S H I T 'S R E A L~ BIG DEAL ...
I hope you people aren't falling for this.
Quote from: MrMag on December 23, 2010, 07:13:10 PM
they didnt have to fall .... sir they is wide awake !
osiris ;D
@osiris
Pardon my ignorance. But.
What is that pointed by the arrow?
Jesus
that is my antenna it is a sealed spark gap ...
you can use anything
as long as it is close
but not touching
osiris
Thank you @osiris!
could a blown LED be used as a sealed spark gap?
Jesus
Quote from: nievesoliveras on December 23, 2010, 07:42:21 PM
Thank you @osiris!
Jesus
now thats why i love kids !
;D
wonderfull idea
osiris
Quote from: osiris on December 23, 2010, 07:39:17 PM
but not touching
osiris
Do you mean the RF recharge transmitter in the circuit diagram ?
Quote from: osiris on December 17, 2010, 01:12:33 PM
thank you
osiris
I am not clear clear understand the process this coil winding.
I think this not normal JT winding.
IS this coil used in the circuit diagram you provide ?
One more question, What is the relationship with your big capacitor wheel and the circuit ? Thanks.
Quote from: WilbyInebriated on December 21, 2010, 08:25:16 AM
What I saw in the video is that he doesn't know how to adjust the oscilloscope to get a visible, usable waveform.
And the camera slews around so much that it's nearly impossible to see what's there.
But then that should be expected. Devious people don't want others to "know too much" and be able to replicate the circuit and get the same results. That's just like a magician; they don't want others to figure out how their trick works. If the viewer does find out, they would know that the fakery is all smoke and mirrors.
how does catv work or poe
hummmm
or telefone .. or or or .. want a list?
let me tell you this ..
you can have many many
data streams down a single wire ..
Old St.
Nik Tesla
so how about that chrip to a 4 note song .......
wouldnt that be some damm amped output ...
hummmm
i can do it by adding 1 chip
osiris
you will not build it unless you understand it hence the baby steps 8)
Quote from: osiris on December 24, 2010, 11:39:58 AM
hummmm
Old St.
Nik Tesla
PoE (Power over Ethernet) is direct current through the center tap of the transformer on each end of the wire pair. There is no data, it's direct current. This is also known as Phantom power, used in powering microphones, etc. over a balanced line.
The analog telephone has no datastream. The audio signal is superimposed onto the direct current flowing in the telephone line.
Nothing goes "down a single wire" unless there a return path, another wire or through ground.
Altogether, the explanation you gave was very... uninformative.
Thanks. We got what we paid for... Nothing.
Quote from: acmefixer on December 24, 2010, 11:58:57 AM
let me ask what flows down your eather net .. ?
let me ask digital cable over coax telephone over coax internet over coax .. copper coated core .. alum case ..
your digging a hole ... you will never climb out of !
ok
walk away ..
osiris
no more stupid questions ... i will have the thred locked
and you will never know how my toys work ..
OSIRIS
im not asking im GIVEING ORDERS
MERRY CHRISTMAS
HAPPY HOLIDAYS AND ENJOY
think about what i have shared
see you in the new year!
peace
I think you should just close the thread.
You started out with a big capacitor wheel - that isn't used
Then you build a big joule thief - that isn't used
Now your showing a joule thief with a couple of transistors that are not completely in the circuit. Just remove the 2 transistors and throw in a leaky diode, same thing. What you are calling an antenna is not an antenna to collect or transmit. Any signal that is at that location come strictly from the joule thief and nowhere else.
Have a Merry Christmas all. :)
Quote from: MrMag on December 24, 2010, 01:29:05 PM
Here we go again.
This Type Of Bickering ,IS WHAT MAKES FORUMS LIKE THIS A JOKE,....give it up....shylo
Osirus..........do you really have what you claim,........proof............. positive would be nice.............shylo
Quote from: osiris on December 24, 2010, 12:09:33 PM
Ooh, ooh let me try!!!
If the sky is blue and your crap is brown then what color is your hair?
Why did the chicken cross the road and crap on your particle accelerator?
What's 2+2 divided by your real IQ?
How many personalities do you have arguing in your head?
Where is your proof that you can even comprehend what people are asking of you?
Do you enjoy being a pain?
Do 2 wrongs make a right?
Do you enjoy being wrong?
Do you think your crap smell like roses?
Who have you not tried to piss off?
Do you enjoy having no friends?
Do you need a meat necklace to make your dog play with you?
Are you being serious?
Are you not a misinformant?
Is trolling a fun hobby?
Do you wash between your toes?
Are you a middle child who mommy and daddy never paid much attention too?
What makes you think that anyone here cares to hear what you think after all that you've written?
Where do you steal other people's work from?
Are you not the fake formally known as Innovation Station (IST)?
Do you like pissing into the wind?
Do you have a real life?
Do you have 2 left feet?
stitch in time saves nine what?
After eating, do amphibians have to wait one hour before getting out of the water?
After they make Styrofoam, what do they ship it in?
Are female moths called myths?
Are part-time band leaders semi-conductors?
Are there a lot of virgins in the Virgin Islands?
Are there any unguided missiles?
Are you breaking the law if you drive past those road signs that say "Do Not Pass"?
Are you telling the truth if you lie in bed?
Before they invented drawing boards, what did they go back to?
Can a stupid person be a smart-ass?
Can fat people go skinny-dipping?
Can you buy an entire chess set in a pawnshop?
Can you get cavities in your dentures if you use too much artificial sweetener?
Could crop-circles be the work of a cereal killer?
Crime doesn't pay... does that mean my job is a crime?
Day light savings time - why are they saving it and where do they keep it?
Did Noah keep his bees in archives?
Do blind dogs have seeing-eye humans?
Do blind Eskimos have seeing-eye sled dogs?
Do boxer shorts box?
Do cemetery workers prefer the graveyard shift?
Do clowns wear really big socks?
Do crematoriums give discounts to burn victims?
Do files get embarrassed when they get unzipped?
Do fish get thirsty?
Do hummingbirds hum because they don't know the words?
Do hungry crows have ravenous appetites?
Do infants enjoy infancy as much as adults enjoy adultery?
Do jellyfish get gas from eating jellybeans?
Do mass murderers kill only in church?
Do people in Australia call the rest of the world 'up over'?
Do pilots take crash-courses?
Do Roman paramedics refer to IV's as "4's"?
Do Scottish Terriers get Scotch Tape worms?
Do stars clean themselves with meteor showers?
Do steam rollers really roll steam?
Do television evangelists do more than lay people?
Do vampires get AIDS?
Do vegetarians eat animal crackers?
Do witches run spell checkers?
Do you need a silencer if you are going to shoot a mime?
Do you realize how many holes there could be if people would just take the time to take the dirt out of them?
Do you think that when they asked George Washington for ID that he just whipped out a quarter?
Does a man-eating shark eat women, too?
Does an analyst have to be anal?
Does killing time damage eternity?
Does that screwdriver belong to Phillip?
Does the Little Mermaid wear an algebra?
Ever notice how irons have a setting for "permanent" press? I don't get it.
Have you ever imagined a world with no hypothetical situations?
Have you ever seen a toad on a toadstool?
Have you ever talked into an acoustic modem?
Have you ever wondered?
How can someone "draw a blank"?
How can there be self-help "groups"?
How can you tell when it is time to tune your bagpipes?
How come chocolate milk doesn't come from brown cows?
How come I can pick my ears but not my nose?
How come wrong numbers are never busy?
How dead is the Dead Sea?
How did a fool and his money get together?
How did the man who invented cottage cheese know he was done?
How do I set my laser printer on stun?
How do they get a deer to cross at that yellow road sign?
How do they get the "Keep off the Grass" sign on the grass?
How do you get off a nonstop flight?
How do you know if honesty is the best policy unless you've tried some of the others?
How do you know when you've run out of invisible ink?
How do you throw away a garbage can?
How do you write zero in Roman numerals?
How does a person with a lisp pronounce that word?
How does a thermos know whether a drink should be hot or cold?
How does it work out that these people always die in alphabetical order?
How does the guy who drives the snowplow get to work in the mornings?
How is it possible to have a "civil" war?
How is it possible to run out of space?
How long is the long arm of the law?
How many people does it take to change a searchlight bulb?
How many weeks are there in a light year?
How much can I get away with and still go to heaven?
How much milk is there in the Milky Way?
How much wood could a woodchuck chuck if a woodchuck could chuck wood?
How old would you be if you didn't know how old you was?
If 7-11 is open 24 hours a day, 365 days a year, why are there locks on the doors?
If a candle factory burns down, does everyone just stand around and sing "Happy Birthday?"
If a fly has no wings would you call him a walk?
If a food processor slices and dices food, what does a word processor do?
If a hen and a half can lay an egg and a half in a day and a half, how long would it take a monkey with a wooden leg to kick the seeds out of a dill pickle?
If a jogger runs at the speed of sound, can he still hear his Walkman?
If a mime commits suicide, does he use a silencer? --Steven Wright
If a mirror reverses right and left, why doesn't it reverse up and down?
If a picture is worth a thousand words, what is a picture of a thousand words worth?
If a pig is sold to the pawn shop, is it a ham-hock?
If a pizza place sells pizza by the slice, is there a guy in the back tossing a triangle in the air?
If a pronoun is a word used in place of a noun, is a proverb a word used in place of a verb?
If a tree falls in the forest, does the earth scream out in pain?
If a turtle doesn't have a shell, is he homeless or naked?
If a vegetarian eats vegetables, what does a humanitarian eat?
If a word in the dictionary were misspelled, how would we know?
If absolute power corrupts absolutely, does absolute powerlessness make you pure? --Harry Shearer
If all the nations in the world are in debt, where did all the money go?
If all the world is a stage, where are the audience sitting?
If an orange is orange, why isn't a lime called a green, and a lemon called a yellow?
If athletes get athlete's foot, do astronauts get mistletoe?
If Barbie's so popular, why do you have to buy all her friends?
If bees live in an apiary, do apes live in a beeiary?
If blind people wear dark glasses, why don't deaf people wear earmuffs? --Steven Wright
If cats and dog didn't have fur would we still pet them?
If corn can't hear, why does it have an ear?
If corn oil is made from corn, what is baby oil made from?
If crime fighters fight crime and fire fighters fight fire, what do freedom fighters fight?
If everything is part of a whole, what is the whole part of? --Ashleigh Brilliant
If flowers don't talk back to you, are they mums?
If Fred Flintstone knew that the large order of ribs would tip his car over, why did he order them at the end of every show? --Steven Wright
If God can do anything, can he make a rock so big he can't lift it?
If God dropped acid, would he see people?
If humans get a charley horse, what do horses get?
If humans have nightmares, what do horses have?
If I melt dry ice, can I take a bath without getting wet?
If I save time, when do I get it back?
If Jimmy cracks corn and no one cares, why is there a song about him?
If love is blind, why is lingerie so popular?
If man evolved from apes why do we still have apes?
If nothing ever sticks to TEFLON, how do they make TEFLON stick to the pan?
If one synchronized swimmer drowns, do the rest have to drown too?
If our knees were on the backs of our legs, what would chairs look like?
If peanut butter cookies are made from peanut butter, then what are Girl Scout cookies made out of?
If rabbits' feet are so lucky, then what happened to the rabbit?
If someone with multiple personalities threatens to kill himself, is it considered a hostage situation?
If space is a vacuum, who changes the bags?
If Superman is so smart why does he wear his underpants over his trousers?
If swimming is good for your shape, then why do the whales look like the way they do?
If the #2 pencil is the most popular, why is it still #2?
If the funeral procession is at night, do folks drive with their lights off?
If the product says "Do not use if seal is broken", how are you supposed to open it and use it?
If there is no God, who pops up the next Kleenex? --Art Hoppe
If time heals all wounds, how come bellybuttons don't fill in?
If tin whistles are made out of tin, what do they make fog horns out of?
If white wine goes with fish, do white grapes go with sushi?
If work is so terrific, how come they have to pay you to do it?
If you ate pasta and antipasta, would you still be hungry?
If you can wave a fan, and you can wave a club, can you wave a fan club?
If you can't drink and drive, why do bars have parking lots?
If you choke a Smurf, what color does it turn?
If you didn't get caught, did you really do it?
If you get into a taxi cab, and ask the driver to drive backwards to your destination, will the cab driver owe you money?
If you had a million Shakespeares, could they write like a monkey?
If you jog backwards, will you gain weight?
If you saw a heat wave, would you wave back?
If you take an Oriental person and spin him around several times, does he become disoriented?
If you tell a joke in the forest, but nobody laughs, was it a joke?
If you throw a cat out a car window, does it become kitty litter?
If you tied buttered toast to the back of a cat and dropped it from a height, what would happen?
If you try to fail, and succeed, which have you done?
If you're born again, do you have two bellybuttons?
If your car says Dodge on the front of it, do you really need a horn?
If you're a kleptomaniac, is there something you can take for it?
If you're in a vehicle going the speed of light, what happens when you turn on the headlights?
In court, why do they ask if you swear to tell the truth? If you're planning on lying, do they really think you'll tell them so?
Instead of wasting time hunting and cooking, why don't hunters just use flame-throwers?
Is "tired old cliché" one?
Is a castrated pig disgruntled?
Is a halfback more valuable than a quarterback?
Is a sleeping bull a bull-dozer?
Is a small pig called a hamlet?
Is an oxymoron a really dumb bovine?
Is drilling for oil boring?
Is duck tape made out of ducks?
Is it OK to use the AM radio after noon?
Is it true that cannibals don't eat clowns because they taste funny?
Is that a flying saucer or a pie in the sky?
Is the nose the scenter of the face?
Is this bullshit or fertilizer?
Now that Microsoft is so big, should it be called Macrosoft?
Sexual harassment at work-is it a problem for the self-employed?
Since Americans throw rice at weddings, do Asians throw hamburgers?
Since there is a speed of light and a speed of sound, is there a speed of smell?
The Scarecrow got a brain, Tin Man got a heart, Lion got courage, Dorothy got home, what did Toto get?
Was the pole vault accidentally discovered by a clumsy javelin thrower?
What are imitation rhinestones?
What do batteries run on?
What do chickens think we taste like?
What do penguins wear for play clothes?
What do people in China call their good plates?
What do sheep count when they can't get to sleep?
What do they call a French kiss in France?
What do they call coffee breaks at the Lipton Tea Company?
What do you call a bedroom with no bed in it?
What do you call a male ladybug?
What do you call male ballerinas?
What do you say if you're talking to God, and he sneezes?
What does Geronimo say when he jumps out of a plane?
What hair color do they put on the driver's license of a bald man?
What happened to the first 6 UP's?
What happens if you get scared half to death, ...twice?
What happens if you go on a survival course - and you don't pass?
What happens if you take No-Doze and wash it down with Nyquil?
What happens to an 18 hour bra after 18 hours?
What happens when none of your bees wax?
What happens when you swallow your pride?
What if hell really did freeze over? What would we be using instead?
What if someone died in the living room?
What if the hokey pokey really is what it's all about?
What if you're in hell, and you're mad at someone, where do you tell them to go?
What is "Soft Liquor"?
What is a "free" gift? Aren't all gifts free?
What is a refried bean? Why do they have to fry it twice?
What is shaved ice? Did it have hair on it before it was shaved?
What is the diameter of a square?
What is the speed of dark?
What kind of fruit is in Juicy Fruit gum?
What makes cheese so confidential that we actually need cheese shredders?
What was the best thing before sliced bread?
Whatever happened to preparations A through G?
What's the sound a name makes when it's dropped?
What's the synonym for thesaurus?
When cheese gets its picture taken, what does it say?
When cows laugh, does milk come out of their noses?
When day breaks who fixes it?
When dog food is new and improved tasting, who tests it?
When I erase a word with a pencil, where does it go?
When night falls who picks it up?
When people lose weight, where does it go?
When something fades in the sunlight, where did the colors go?
When they first invented the clock, how did they know what time it was to set it to?
When we say our mind wanders - where does it go?
When you put a sheet over your head for Halloween, are you a ghost or a mattress?
Where are the germs that cause 'good' breath?
Where are we going? And what's with this hand basket?
Where did Webster look up the definitions when he wrote the dictionary?
Where do they get Spring water in the other 3 seasons?
Where does the fire go when the fire goes out?
Where does the white go when the snow melts?
Where does your lap go when you stand up?
Where in the nursery rhyme does it say Humpty Dumpty is an egg?
Where is Old Zealand?
Which is the other side of the street?
Who killed the Dead Sea?
Who opened that first 'oyster' and said "My, my, my. Now doesn't 'this' look yummy!"
Who was the first person to look at a cow and say, "I think I'll squeeze these dangly things here and drink whatever comes out?"
Who was the first person to see an egg come from a chicken's butt and think, "I'll bet that would be good to eat?
Whose cruel idea was it for the word 'lisp' to have an 's' in it?
Why are all blackboards called that when some of them are green?
Why are America's parks administered by the Department of the Interior?
Why are builders afraid to have a 13th floor, but book publishers aren't afraid to have a Chapter 11?
Why are cigarettes sold in gas stations when smoking is prohibited there?
Why are hemorrhoids called "hemorrhoids" instead of "asteroids"?
Why are highways build so close to the ground?
Why are raisins called raisins if they are only dried grapes? Why not just call them dried grapes?
Why are some gay people so unhappy?
Why are there flotation devices under plane seats instead of parachutes?
Why are there interstate highways in Hawaii?
Why are they called "stands" when they're made for sitting?
Why are violets blue and not violet?
Why are you expected to slow down in a speed zone?
Why aren't there ever any guilty bystanders?
Why buy shampoo when real poo is still free?
Why can't you make another word using all the letters in "anagram"?
Why can't we tickle ourselves?
Why did kamikaze pilots wear helmets?
Why did the pot call the kettle black?
Why didn't Noah swat those two mosquitoes?
Why do ballet dancers dance on their toes? Why doesn't the company just hire taller dancers?
Why do fat chance and slim chance mean the same thing?
Why do flamingos stand on only one leg?
Why do flammable and inflammable mean the same thing?
Why do hot dogs come ten to a package and hot dog buns only eight?
Why do mattresses have springs, if they aren't made for jumping on?
Why do people always remember where they were when someone famous was killed? Do they feel perhaps they'll need an alibi?
Why do people go to the unemployment office to find a job?
Why do people park in driveways and drive on parkways?
Why do people tell you when they are speechless?
Why do pigs have curly tails?
Why do the signs that say "Slow Children" have a picture of a running child?
Why do they call it 'chili' if it's hot?
Why do they call it a TV set when you only get one?
Why do they call it 'getting your dog fixed' if afterwards it doesn't work anymore?
Why do they call it life insurance?
Why do they call it quicksand when it sucks you down slowly?
Why do they call the piece of wood a two-by-four if it's only 1 3/4" x 3 1/2"?
Why do they call Wednesday hump day, when most people get laid on the weekends?
Why do they give you a tape with a VCR to tell you how to use it?
Why do they make cars go so fast its illegal?
Why do they make scented toilet paper?
Why do they put Braille dots on the keypad of the drive-up ATM?
Why do they report power outages on TV?
Why do they sterilize the needle for lethal injections?
Why do toasters always have a setting that burns the toast to a horrible crisp, which no decent human being would eat?
Why do tourists go to the top of tall buildings and then put money in telescopes so they can see things on the ground in close-up?
Why do we call something sent by car a shipment and something sent by ship a cargo?
Why do we call them restrooms when no one goes there to rest?
Why do we drive on parkways and park on driveways?
Why do we have hot water heaters when hot water doesn't need to be heated?
Why do we kill people for killing people to show that killing is wrong?
Why do we need training bras? What can we teach them?
Why do we put shirts in a suitcase, and put suits in a garment bag?
Why do we say "a pair of pants" when there is only one article of clothing involved?
Why do we say something is out of whack? What is a whack?
Why do we sing "Take me out to the ball game," when we are already there?
Why do we wash bath towels? Aren't we clean when we use them?
Why do wise guy and wise man mean entirely different things?
Why do you feet smell and your nose runs?
Why do you need a driver's license to buy liquor when you can't drink and drive?
Why do you need an appointment to see a psychic?
Why does a dishtowel get wet when it dries?
Why does a grapefruit look nothing like a grape?
Why does Donald Duck wear a towel when he comes out of the shower, when he doesn't usually wear any pants?
Why does Goofy stand erect while Pluto remains on all fours? They're both dogs!
Why does it take 15 minutes to cook minute rice?
Why does the sun lighten our hair, but darken our skin?
Why doesn't glue stick to the inside of the bottle?
Why doesn't Tarzan have a beard?
Why doesn't the fattest man in the world become a hockey goalie?
Why don't they call mustaches "mouthbrows?"
Why don't they just make food stamps edible?
Why don't you ever see the headline "Psychic Wins Lottery"?
Why get even, when you can get odd?
Why is "abbreviated" such a long word?
Why is a boxing ring square?
Why is a carrot more orange than an orange?
Why is a person who plays the piano called a pianist, but a person who drives a race car not called a racist?
Why is a women's prison called a penal colony?
Why is brassiere singular and panties plural?
Why is clear considered a color?
Why is it called a "building" when it is already built?
Why is it called lipstick if you can still move your lips?
Why is it called tourist season if we can't shoot at them?
Why is it considered necessary to nail down the lid of a coffin?
Why is it that bullets ricochet off of Superman's chest, but he ducks when the gun is thrown at him?
Why is it that doctors call what they do "practice"?
Why is it that famous people are always born on holidays?
Why is it that night falls but day breaks?
Why is it that only adults have difficulty with childproof bottles?
Why is it that rain drops but snow falls?
Why is it that to stop Windows, you have to click on "Start"?
Why is it that when you're driving and looking for an address, you turn down the volume on the radio?
Why is it you must wait until night to call it a day?
Why is lemon juice made with artificial flavor, and dishwashing liquid made with real lemons?
Why is the alphabet in that order? Is it because of that song?
Why is the man who invests all your money called a broker?
Why is the third hand on the watch called a second hand?
Why is the time of day with the slowest traffic called rush hour?
Why is the word dictionary in the dictionary?
Why is your index finger the same size as your nostrils?
Why isn't phonetic spelled the way it sounds?
Why isn't there a special name for the tops of your feet?
Why isn't there mouse-flavored cat food?
Why was Evelyn Wood in such a hurry?
You can't have everything. Where would you put it?
You know that little indestructible black box that is used on planes? Why can't they make the whole plane out of the same substance?
Do you need more?
this is the most ridicolous thread i have seen, and Osiris is a real time waster, i think you should close this negative thread, it just makes people laugh, how can you say you have made a particle accelerator, do you even know what is that?? this is absolutely nothing more than misunderstanding physics, you should consider consulting with a physics professor, i would not like to trouble this topic, people have allready got enough crap in their heads, and now you say you made a particle accelerator with a couple of transistors diodes and caps :-X
i did not mention of the very bad manner i read from you, this kind of behaviour shows a persons real truth in his head,
Although his personality is abrasive, Osiris has provided more information than most who boast about their OU claims.
If you want to prove him wrong then replicate his joule thief circuit. Filling this thread full of nonsense is not the answer.
Quote from: Tenbatsu on December 25, 2010, 10:57:00 AM
Can you explain in more detail what is your understanding of what exactly is there to be replicated?
If I'm not mistaken a schematic has been posted earlier in this thread.
Is it possible that it's nonsense? Sure, but attack the science is all that I'm saying.
Quote from: Tenbatsu on December 25, 2010, 06:47:27 PM
So, what's to be replicated? Do you have any idea or you are just talking in principle, assuming that any schematic, no matter how stupid, constitutes science?
We can all go on and on about how stupid this or that is but until IST is shot down cleanly and with evidence, he will continue to mislead the OU community.
Should every schematic be replicated? No.
In this instance I think it would be prudent because most people here have toyed with Joule Thief circuits at least once and they would be benefiting the entire OU community by finally calling IST out as a liar.
i bet you that im wining i bet THAT YOUR NOT ! 8)
I like to party and spend my dough
And when I go to rehab I’m putting on a show
And it’s so spectacular whenever I rap to ya
Im re-enacting my feelings to capture the
Moment like a Nikon and when the mics on
Im a star baby, I’m your icon
Im put on the light, I shine I glow
Whoa is me
Im so whoa
:P
Quote from: Omnibus on December 25, 2010, 11:16:51 AM
Face it Omnibus, you just don't understand IST. Fortunately, now there is a solution:
http://americantrollsociety.blogspot.com/2010/12/ist-translation-service.html
Hi will
I think i agree with you we are of the same slice. ;D
BUT! you are more eccentric like tesla our alien brother. ;D
So, one wire into many , like one pulse converted into lots of kicks hmmmm.
i understand you ;)
Quote from: Tito L. Oracion on December 26, 2010, 09:24:52 PM
Hi will
i understand you ;)
;D were more than just a slice ! BRO
we are project OMEGA
we 1 big mega 0
O SIRIS
Quote from: osiris on December 26, 2010, 09:41:40 PM
we 1 big mega 0
O SIRIS
I can translate that:
I am ordering a pizza for Christmas dinner and eating the whole thing myself.
Quote from: quarktoo on December 26, 2010, 02:23:38 PM
LMFAO!! looks like some high school kid's first attempt at html and web design!! he hasn't a clue so, he uses a blog...
hey duarktoo... where is your facebook page? LMFAO
So, what's there so much about http and web design that is beyond what a school kid could do?
Quote from: Omnibus on December 27, 2010, 01:17:27 PM
look at the design of it. look at the napalm picture... amateurish. did you help him with it omni? it reminds me of your magnet wheel build...
So, it's the picture, not the html. Well, one can be tasteless in the internetless world too. Even more so. Don't blame the net and insinuate it is something it isn't.
Quote from: Omnibus on December 27, 2010, 01:27:46 PM
can you read? can you comprehend?
and i quote "look at the design of it. look at the napalm picture... amateurish."
see those two
separate statements? look at the design. look at the napalm picture. so, it's
obviously not just the picture. furthermore, i didn't "blame the net" anywhere... the "blame" for it looking amateurish lies with that kid, duarktoo. just like the blame with your magnetmotor looking amateurish lies with you... get it? tu stultus es.
And I quote too: "LMFAO!! looks like some high school kid's first attempt at html and web design!! he hasn't a clue so, he uses a blog..."
Quote from: Omnibus on December 27, 2010, 01:35:22 PM
and do blogs have templates that allow you a choice of page layout oh great omni?
just shut up idiot. you're diggin yourself a hole here. not as bad as your steorn crevasse... but keep at it with that omni persistence and you'll be there in no time.
So what? Any of this is trivial and is up to an average school kid any time.
The point is, messenger is not the message, no matter how much the powers that be are pushing it to appear otherwise (Assange, Zuckerberg, Gates, Brin&Page etc.)
Quote from: Omnibus on December 27, 2010, 01:42:08 PM
The point is, messenger is not the message, no matter how much the powers that be are pushing it to appear otherwise (Assange, Zukerberg, Gates etc.)
no. the point is, duarktoo is a smart (ass) kid. who possesses none of the skills to effect his claimed knowledge, as evidenced by his blog (he isn't even smart enough to learn a handful of html tags and make his 'own' page). much like you omni... as evidenced by your magnet motor.
Never mind. It's a waste of time to communicate with clueless such as you.
Quote from: Omnibus on December 27, 2010, 02:08:43 PM
is that your idea of a cogent rebuttal?
SHINY! i just made THE wanted list of all lists...
on http://americantrollsociety.blogspot.com/2010/12/most-wanted-list.html
THERE REALLY IS A SANTA!!!
no i'm just kidding... there is no santa. just a kid who's mad i called him an amateur.
he thinks i'm grumpy because he called grumpy a rank armature [sic] and then i called him one (except i can spell it correctly). ::) what an imagination...
Quote from: WilbyInebriated on December 27, 2010, 03:58:35 PM
SHINY! i just made THE wanted list of all lists... on http://americantrollsociety.blogspot.com/2010/12/most-wanted-list.html
now these trollers are really busted, they can not even write an intelligent sentence, we know who you are osiris and other time wasters, you can still troll the web with shit, but when the people get out from slavery you will have no place anywhere around, we know that you are very famous about your "help to humanity" all your help you have done, ooh cannot even count on my fingers, this thread should be closed and these trollers banned, this is no insult, this is a fact!
Don't let it go to your head Omnisus but The American Troll Society agrees with you fully.
http://americantrollsociety.blogspot.com/2010/12/about.html
QuoteOnly a real troll would think of making a free blog web site into a free web site for the American Troll Society. Big shout out to Quarktoo and his new friend WilbyInebriated who is too stupid to get it.
Yet another false claim by WilbyInebriated as he claims to make the most wanted list. Dude, it was only a security notice. You don't rank as even an "amateur" troll.
QuoteWilbyInebriated
This is a low rate corporate troll wanna-be trying to make a name for himself at overunity.com without a license. Considered a lightweight on anything technical or scientific, his pedantic banter is usually crushed by small children using only an ignore button. While he does possess noteworthy spelling capabilities, he is not worthy of a reward and is not being pursued at this time. Suspected of being Grumpy pretending to be a drunken bar slut.
seems like you all have so much free time ..
let me see if i can find you all something to do ...
how do crystal controlled loop antennas work .. or are those crystal amps .. 8) :D
hahahahaha
i have a book some where ... hehehehe
i can quote it from the book if you like ..
says it takes ONLY A TINY SIGNAL TO ACHIEVE LARGE OSCOLATIONS .. IN A LOOP ANTENNA ..
got TPU written all over it .. ;)
osiris
chrip to song convertors ...
OSIRIS
OOO LOOKIE .. IS THAT A 4 NOTE SONG ? 0 I BET IT IS
and the bitches ask whats the chip ...
i say go figure it out !
lmfao!!
You sir, are a legend in your own time! Even though you are nothing more than a defective floppy, as trolls go, you are the mark of excellence. Please allow the American Troll Society to thank you by translating this from defective Canadian floppy into English:
The chips are any JK flop flop chips such as the 74LS90 and the circuit is called a cascade generator. It is the same circuit that Stan Meyer used in his first fracture generator (International test report) to power the outer coils of the resonant charge choke (RF mixer).
Once the 2 or more signals are mixed together (Meyer's resonant charge choke) in an RF mixer and the heterodyned signal sent to an object like wire or water which removes the free electrons which make up the electron sea. Meyer called this "electron bounce phenomena".
The way it works is the high frequency sidebands knock the free electrons from the electron sea to produce a superinductive circuit which locks the water into a rigid state so it will fracture when hit with the opposite charge of voltage. It can also make a circuit superinduct such as the Leedscalnin PMH.
Keep them coming IST, the Earth is hanging by a thread and we could use a hero right about now. Your status has been elevated with the American Troll Society.
http://americantrollsociety.blogspot.com/2010/12/alterts-and-memos.html
EDIT -
Will you also be removing those free electrons using Meyer's diode and light bulb to convert them into photons? (electron extraction circuit?)
well if you liked the last one how about this mod to go along with the rf recharge ..
so i get the rf recharge working i send it to CHRIP TO SONG convertor i now apply 1 pulse i get 4 overlapping .. i take that and audio amp it .. bang it back around the ring and out to recharge the supply ..
ta duh!
osiris
Quote from: osiris on December 29, 2010, 12:20:17 PM
ta duh!
osiris
Translation:
Here IST is suggesting that you take the heterodyned signal and run that through a delay line which he bought wholesale and then recycle that back into the loop.
- end of translation.
IST you are one sick puppy. What will you call this amazing new wave? A "burst wave"? Sorry, Meyer already used that name. How about an "all frequency transmitter" Damn! The ham radio RF boyz alrealy used that one.
Well good luck with that. More importantly, the PHM coil of Leedscalnin becomes a rubber band with no EMF - forward or backward - which is the friction on a circuit caused by excess electrons moved by voltage. It is also the loss that keeps all electronic circuits from going OU.
Since all electricity is mass to atomic energy conversion (evidenced by the amplified speed from speed of inductor magnet to speed of light) and since E=MC2, all electricity is OU. You just throw half of it away by using circuits that are at rest and stuck to the electron sea that pervades everything around you. That static is sticky business that produces heat and removing it makes everything move more freely and OU.
This translation was brought to you courtesy:
The American Troll Society.
Who also blew this frame too wide with that Meyer schematic for the betterment of science.
Only a licensed troll, a troll's troll, would have done that.
Good One Quartoo.
Yeah, I sure do recognize the names of those Trolls. ROFL
