Does anybody have a clue what this thing is? It seems to imply
that it Keeps Pulsing due to the coil feeding back to itself.
https://www.youtube.com/watch?list=PL9JyruCKDmrW0Ce8bK2SD1GmXt3YIHzNQ&v=KsjoaIz0prw (https://www.youtube.com/watch?list=PL9JyruCKDmrW0Ce8bK2SD1GmXt3YIHzNQ&v=KsjoaIz0prw)
http://ecocreando.weebly.com/bac-coil---free-energy---fuelsaver---magnetiz-water.html (http://ecocreando.weebly.com/bac-coil---free-energy---fuelsaver---magnetiz-water.html)
Apparently the coil is placed over a fuel line or water line.
They are claiming 20% to 30% less fuel consumption if placed over a fuel line in a vehicle.
They are also claiming that it can improve water quality if placed over a water pipe.
You can use Google Translate to view this webpage:
http://ecocreando.weebly.com/bobina-tesla-bac---free-energy---magnetizza-e-risparmia----acqua---carburante---corrente.html
It's hilarious, is what it is. The instructions are right there, go ahead and build one yourself and test it.
QuoteBuilding B.A.C. coil
to magnetize water - fuel - gas
1) Cut STEREO CABLE ( red - black ) at least 1 meters of insulated copper wire 1.0 mm2 .
2 ) Wrap 15 not 30 turns on the tube ( in the video is the V01- FIRST VERSION of B.A.C. Coil ) ,
never to cross over the wires, and fix with duct tape ,
freeing the beginning and at the end of at least 10 cm of thread
Do three or four laps early and fix immediately with tape.
It will be easier winding. Secure the end with tape.
3) Turn the wires towards the opposite end up to overlap in length of at least 5 cm .
Remove with a pair of scissors the plastic insulation at the ends of the wire for at least 2 cm.
4 ) Mix together the 2 internal strands of thread ,
and the 2 external ends of the wire together and tape the whole thing.
And you too can begin saving 30 percent on your fuel cost, get cleaner clothes, cook your food with less fuel, and even walk your dog fewer times a day. (OK, I made that last one up.)
These things surface every few years. All the "data" you get is subjective, anecdotal, and depends on the "tester" knowing that the device is actually attached. Let's say you make two coils, identical except one is bifilar connected and the other is not. Covered with tape they look the same. Then you put one on your friend's car (neither he nor you know which one) and drive for a week or month, keeping records. Then you switch coils and drive for another week or month. Then you look at the records to see which trial period had the better performance. THEN you take the tape off the coils and see if it really was the bifilar coil that was on the car during the better performance period. Neither you nor your friend knew which coil was there during the actual trial, you only peek after the data gathering period is over.
This is called a "double blind" test protocol, and will usually eliminate the "experimenter effect" (technical term).
https://en.wikipedia.org/wiki/Observer-expectancy_effect
And whenever devices like this are properly tested to eliminate experimenter effect, they always have proven to be inoperative.
But don't take my word for it, go ahead and make your own and install it! Since you know that it is there, you probably will pay more attention to your driving habits and you probably will save some fuel!
Here's a simple test.
Build one of these and run water through the pipe.
Next, magnetize a needle on a string, such that it acts as a compass.
Now, test for electric fields in the coil.
Quote from: sm0ky2 on February 08, 2016, 04:58:46 AM
@sm0ky2 and all sceptics:
You can not measure the effect of this coil with any known instrument (not with a compass, not with a Voltmeter, not with an Ampere-meter, not with a an oscilloscope, not with a thermometer).
It is RADIANT ENERGY!
RADIANT ENERGY speeds up atoms and the faster atoms (e.g. the fuel in a car, the gas going to your heating system, the water going to your washing machine or to your cooking pots) do everything faster and better, hence the marvellous savings and beneficial effects.
Imagine two bullets, one going faster than the other. The faster one will penetrate deeper into the tree you shoot at. And in the same way the faster atoms (the electrons race faster around the core) burn hotter and food cooked with "fast water" will be faster absorbed in you digestive system and therefore gives you more and better sustenance (faster chemical reactions, hence more efficiency of every chemical, biological and even mental process).
Just keep in mind "speed is money"!
I have such "speed up coils" in my car (around the fuel line from the tank to the carburettor), in my house (around the water supply pipe coming in from the municipal water supply) and around the gas pipe (which comes ultimately from Russia http://www.gazprom.com/about/production/projects/pipelines/yamal-evropa/ (http://www.gazprom.com/about/production/projects/pipelines/yamal-evropa/)).
My savings are truly great, sometimes my meters run in reverse because the fast atoms cause shock waves radiating back to the source. Attention, your digestive system will also work faster possibly causing embarrassing moments in public.
Do not place such coils around your 220 V or 110 V electricity supply line because the shock waves radiating back to the source would destroy the power stations. Imagine what would happen if an atomic power station explodes, or any power station. There is no danger in Austria because the power stations have neutraliser coils around the outgoing power lines. But it is therefore useless to place such speed up coils around incoming power lines in your house or apartment in Austria. I have no idea which other countries have neutraliser coils in their power stations and which countries are careless. You know, one always has to be extra vigilant in a foreign country.
I hope this clarifies the use of these coils. Build them and see for yourself, but be careful, the effects are really great and imminent.
Best is you call me and I build the coils onto your equipment. My fees are reasonable! My last customer paid only 35.000.-- and his savings in the first year were 70.000.-- (the coils last for decades). The beneficial effects on his health were for free. My last customer even became smarter, he is selling such coils himself now (the bastard).
SPUC (Speed Up Coils)
Spulenstrasse 66
A-60966 Deppenstadt
AUSTRIA
Tel: 011111 777999888222
E-Mail: speed-is-your-money@schnell-spulen.info
Greetings, Conrad
Hello ,
conrad is just fooling everbody.
A quick translation/explanation:
SPUC (Speed Up Coils) -> o.k. :)
Spulenstrasse 66 -> Coil Street, a commonly known street in this town
A-60966 Deppenstadt -> Depp is German and means : Fool -> Foolstown
AUSTRIA -> Schlu_______ :)
Tel: 011111 777999888222 -> easy to remember
E-Mail: speed-is-your-money@schnell-spulen.info -> pure fantasy
Some more clarifications, specially for sceptics like TheCell:
The world wide electric power generation cartel has hidden the "neutraliser coils" behind the fraudulent concept of "arc suppression coils".
Since Tesla's time many people have caught on and wanted to install "speed up coils" on the electric power line coming into their home. This would save an enormous amount of energy, which of course the world wide electric power generation cartel would not like. "You shall pay a high price for electricity" is the money making principle of this cartel.
The so called "arc suppression coil" properly installed at a power station would allow everybody to a use a "speed up coil" at the house, and save 80% of electric power. The dangerous back radiation of the "speed up coils" in people's homes would be absorbed and reflected back by the "arc suppression coils" at the power stations (hence saving the power station from exploding)
And now comes the incredible conspiracy perpetrated by the world wide electric power generation cartel:
Since 1917 the "arc suppression coils" are installed backwards in power stations in order to neutralise any "speed up coils" used by knowledgeable people in their homes.
See this web site: http://www.swedishneutral.se/main.php?name=neutral_asc (http://www.swedishneutral.se/main.php?name=neutral_asc)
And how big this conspiracy is, you can see from the "arc suppression coil" market survey of 2015:
http://onlineheraldnews.com/arc-suppression-coil-market-2015-global-industry-size-trends-and-analysis-to-2019/ (http://onlineheraldnews.com/arc-suppression-coil-market-2015-global-industry-size-trends-and-analysis-to-2019/)
Nowadays worldwide, the installation of "speed up coils" over electric power lines in people's homes is neutralised (by arc suppression coils installed backwards in electric power stations).
But you can still install "speed up coils" over a water pipe or gas pipe coming into your home. And you still can install it in your car to save fuel.
But there are rumours that the German car industry tries to install "Benzine and Diesel neutraliser coils" in cars. The big VW-not-so-clean-exhaust scandal is the means to do that even in already sold cars. So, not only new cars will have a "Benzine and Diesel neutraliser coil", but also cars which have been delivered to the customers in the last years.
You can see from the fact, that the US-government tries so hard to make VW recall every car sold in the last years, that the US auto industry wants to install "Benzine and Diesel neutraliser coils" as well. The argument will be, that every car in the world needs to have a very clean exhaust. California paved the way with the car exhaust clean up laws.
The "clean exhaust conspiracy" hides the fact that gases coming out of the billions of cows (in fact, coming out of every living being on earth) are more decremental to health than the exhausts of cars can ever be. To put it bluntly: farting is the problem, not car exhausts! But who can make money from farts? In contrast, one can make lots of money by selling more fuel by installing a "Benzine and Diesel neutraliser coil" in every car.
Greetings, Conrad
Quote from: conradelektro on February 08, 2016, 07:07:55 AM
Greetings, Conrad
I see. It is an energy we cannot observe...
How then, do we know it is there? and in what quantity?
Do we need to invent a new instrument?
Would a mass-spectrometer work? perhaps we could graph the motion of the atoms and electrons in real-time, to observe this energy?
(oh no,. this energy is way to smart for that, it will wiggle it's way out of that one for sure..)
This is a standard CT, used for monitoring power levels in the substation.
Of course it is difficult to observe or to measure RADIANT ENERGY. Why do you think this knowledge could be suppressed for so long?
The new world order is helped by the mysterious nature of RADIANT ENERGY, otherwise everybody would have caught on long ago. Tesla tried a lot to make RADIANT ENERGY accessible to the masses, but he was persecuted like all fighters for freedom and justice.
Everybody can take a photo of a neutraliser coil and write "current transformer" next to it. What can you prove by such a childish action?
But I have to stop writing the truth in an open forum, otherwise my life will be in danger. You are on your own when searching for the truth. I did what I could, but like always, one is not believed when revealing secrets.
Greetings, Conrad
P-S.: FatBird's post was already censored http://overunity.com/16398/-strange-coil-feeds-itself/msg473504/#msg473504 (http://overunity.com/16398/-strange-coil-feeds-itself/msg473504/#msg473504), watch out.
Quote from: conradelektro on February 09, 2016, 03:55:51 AM
Greetings, Conrad
My apologies. You are right, I should work harder and do my homework to prevent rediculousnesses from running rampant.
https://en.wikipedia.org/wiki/Current_transformer (https://en.wikipedia.org/wiki/Current_transformer)
Quote from: sm0ky2 on February 09, 2016, 04:18:48 AM
It is a good thing that you try to prove your point. Unfortunately the well known Harvard University has the following to say about the basis of your proof:
http://isites.harvard.edu/icb/icb.do?keyword=k70847&pageid=icb.page346376 (http://isites.harvard.edu/icb/icb.do?keyword=k70847&pageid=icb.page346376)
Nevertheless, when you're doing academic research, you should be extremely cautious about using Wikipedia. As its own disclaimer states, information on Wikipedia is contributed by anyone who wants to post material, and the expertise of the posters is not taken into consideration. Users may be reading information that is outdated or that has been posted by someone who is not an expert in the field or by someone who wishes to provide
misinformation.
In your case the Wikipedia-Poster seems to be an agent of the world wide electric power generation cartel which is hiding the neutraliser coils in plain sight and makes sure that encyclopaedias remain consistent with the falsehood held up by the cartel.
I know that sm0ky2 tries his best and intends no evil. But it is the nice and thoughtful people who are targeted by the misinformation campaigns of the new world order.
Cynical bastards like me are by nature favoured to look through deceptions mainly because they are not above deception themselves. It takes a deceiver to catch a deceiver, as they say.
An other word of advice for sm0ky2 and sceptics:
Before you run off to look for proof in papers published by University professors and scientific staff, keep the following in mind.
The new world order has a tight grip on Universities (and their scientific staff) by help of the tenure track.
See here for an explanation https://newworkplace.wordpress.com/2011/08/22/what-is-academic-tenure/ (https://newworkplace.wordpress.com/2011/08/22/what-is-academic-tenure/)
The article about the tenure track names 4 criteria you have to fulfil in order to get "tenure" at a University (life long employment). But there is a hidden 5th criterion, which young eager scientists have to fulfil, and it is "do not publish a secret".
Some rather dull scientists never discover secrets and therefore might slip into tenure without ever having heard of the 5th criterion. Only the bright and eager scientists who are after the secrets of the world hit the 5th criterion and if they obey, immediately get tenure. This is the reason why mostly bright guys get tenure and they are for sure bright enough to strictly keep a secret.
Now you will ask: "Bloody hell, how can I ever find the truth?"
Lean back and think for a moment! Secrets are only secrets if they are kept secret! Everything is done that you never find a secret and that is what will happen.
Greetings, Conrad
What is the definition of "Radiant Energy" ?
Quote from: Paul-R on February 09, 2016, 12:16:33 PM
If I gave you a good answer I would be killed.
I spare you the double talk and the bull which you can read yourself in many posts in this forum.
Greetings, Conrad
Radiant Energy, as historically defined by Tesla:
High-Energy electromagnetic waves that can propagate at great distances, Penetrate all forms of matter, and exist in a vacuum.
This energy is thought to originate from a multitude of source including stars and electrified gas clouds, supernovae, black holes, galactic collisions, pulsars, or any other highly energetic event, from which such waves might propagate.
These waves permeate everything around us as a complex field of interacting waves of electromagnetic radiation.
Tesla claimed to be able to, through use of discrete oscillating circuits, filter out some of these waves for use in energy production.
The magnitude of the energy contained in these waves depends on the wave itself.
Factors such as frequency and amplitude can lead to drastically varying results in the energy equations.
The ideal situations for such filtering of radiant energy, is high frequency, low impedance.
(not worried about the MIBs)
Quote from: conradelektro on February 09, 2016, 12:19:58 PM
A price worthy paying?
Radiant simply is a cool beam glowing of lights carrying by the pulsating waves. :)
Quote from: FatBird on February 11, 2016, 11:27:20 AM
I wonder if this U-Plug is related (or part of) the other U-Plug company?
https://www.youtube.com/watch?v=UE9iFE_Pdpg (https://www.youtube.com/watch?v=UE9iFE_Pdpg)
Oh no,.. the overpriced PFM.... I hope not
Quote from: sm0ky2 on February 09, 2016, 12:31:08 PM
Hey Smoky
Would you happen to know round about what freq range were looking at here?
Mags
good morning everyone, my name is Marco Cocca. I'm the creator of "bifilar Autoinductive Closed Coil" - "B.A.C. Coil". The Strange Coil that Feeds Itself :)
With our association "Ecocreando Earth in Harmony" we experience from 3 years various solutions for energy saving and energy self-sufficiency - Free-energy
"B.A.C. Coil" is the simplest and economical solution to save fuel, healthy drinking water, improve the growth of plants and animals, gradually clean up the environment.
One principle... Many applications Virtually illimited applications.
The applications are many, and many are yet to be discovered
These Are The Best configuration for "B.A.C. Coil" on different application: updated to Februry 2016
last our video for "BOBINA B.A.C - B.A.C COIL" building (italian language, and when possible, we will also add other languages)
https://www.youtube.com/watch?v=kQoKB5ZbOGI
with stereo cable wire 2x1 mmq - AWG 18
* 13 turns for FuelSaving mounted on the main fuel line
(Gasoline - diesel - LPG - Methane - Propane - butane) UP TO 30%
It depends on the engines, most are old can improve more, most have traveled more miles can improve, because it cleans the engine gradually
* 15 turns for Magnetized Balanced Natural Alkaline Water PH 7.3 to 7.6 no limescale, chlorine and toxic substances read
15,000 BOVIS Vital Unity Misured - 13 turns boost to 80,000 BOVIS Misured (It depends on the scales used, still very vital water and energy) very purifying water, light and neutral.
* 15 turns on the "spark-plug HV Cable" to Boost Sparks UP TO 20% - more power, more torque, more speed, less polluted emissions
It collects the HV electric field dispersed around the cable and inserts it inside the HV cable, increasing the electromagnetic charge and therefore the power of the spark.
* 8 to 15 turns on the branches and trunks of plants, wound on a water-resistant support which does not tighten the plant, to promote germination and growth.
sprouts that grow quickly in small trees, half-dead plants that seem to be born again. Growth of larger beans by 30% compared to normal. We only tried a few plants for now.
* 1 turn to be wearing as a belt around his waist, thinning all the fluids of the human body. It improves blood circulation, tissue elasticity, reduces muscle pain, energizes the entire body to suffer less fatigue, even during work or sport. 2-3 turns to the same principles, to create bracelets and anklets for the human body.
* 10-15 turns to magnetize bearings, to reduce friction metal bearings mounted on a metal rotating shafts of wheels, engines, and more.
We tried on some bicycles. The wheels spin really better, we do not know what exactly but after some HOUSEH by mounting the "B.A.C. Coil", was reduced by 25% the travel time of the same proven way with the bike.
Video B.A.C. Coils on Mountain-Bike https://www.youtube.com/watch?v=ZNgIoyE20I4
We are not yet able to measure the energy that uses the "B.A.C. Coil" for now. MA a friend told me that connecting the terminals an oscilloscope that measures up to 20MHz signal, noted a very dense wave, high frequency, theoretically from our studies is a Ghz microwave signal.
But we do not have instruments that allow us to have more clear and accurate results. I think there is also a part of Radiant Energy.
We are open to collaboration with all those who are of our philosophy OpenSource, from all parts of the world.
Anyone who can help us to discover new features, improve existing and find a way to measure the energy used, please contact us. thank you.
We have already contacts with friends in Mexico, Spain, England, Albania.
When I can I like reading this beautiful forum. One of the best network. Public as soon as possible other data that we have. I do not have much time to read or write to the forum.
We are very busy with the association.
I hope that our work can be understood and shared to allow everyone to improve their lives at no cost, or almost. Thanks so much.
Thanks to Mr. Nikola Tesla and M.Rao. Velagapudi for their works and genious. Because this solution is the fusion of 2 patents. 1 Tesla and 1 Valagapudi.
Official italian site "Ecocreando Earth in Harmony": ecocreando.weebly.com
Facebook Official Page: https://www.facebook.com/EcocreandoTerraInArmonia/
many foto of vary applications in our Photo Album.
Youtube Playlist Various "Coil BAC - BAC Coil" from youtube users Vary
https://www.youtube.com/playlist?list=PLzq8H-LdFTNdRhF4wk3GrOWgrt5wMqpn9
This text has been partially translated by a translator. I write from southern Italy.
Good day and good work. :)
technical information, for those in the industry. Patents and studio sources for testing.
http://www.google.com/patents/US5134985 "Burner fuel line enhancement device" Velagapudi M. Rao
http://www.magnetricity.com/Bifilar.php patent "Coil for Electromagnet" #512,340 , Nikola Tesla
important data for the engines on trial:
vehicles with electronic control unit, disconnect the battery at least 12 hours, so the unit is reset to factory value, and calibrates itself again alone, in an optimal manner. If you do not detach the battery, the controller can adapt itself in time (it reads the sensors and calibrates itself autonomously every 100km, 300 km, or 500 km etc.) only on cars with simple electronic control units, medium-and low-end engines older generation. With BMW vehicles - MERCEDES - High end AUDI, with many on board electronic systems, so with a sophisticated control unit, serves to disconnect the battery at least 16-24 hours, to discharge the capacitor that keeps track of the controller values, how about some cars we've tested.
Some vehicles also have anti-theft systems or other with codes to be entered. Careful to check first if you need other special operations, after prolonged detachment of the battery and reset the unit.
Quote from: Marco Cocca on February 24, 2016, 10:40:20 AM
Hi and welcome !
In the patent, it speaks of a coil of "prescribed length and number of turns". How does one determine the length and the number of turns (which, of course, are linked by the diameter of the former)?
Marco, the effects of chewing too much Coca are clearly visible. You shoud try to kick this brain numbing habit.
Greetings, Conrad
Hello Paul-R
I don't know exactly how many turns, are linked to diameter of the former. I don't have a formula.
I did many experiment to understand how "feel better".
I am not an engineer, not a degree, I'm just a humble seeker of truth. I always try first. when I talk about it because I tried, and tried, and tried, and tried, so many times that you even imagine.
And 'the only thing to do. Try again and again to verify the data in the Reality.
The theory is just theory .. facts are facts.
Many things do not add up to the academic classical physics.
It does not matter. We continue, however, and we share our findings so they can also be useful to other people in the world.
You do not have to believe me. You have to try.
@Conrad. I do not use cocaine, I am a healthy and civilized person, unlike you from the top of your ignorance, insult without trying to understand.
I am always available to share and understand.
Greetings, Marco
Quote from: Marco Cocca on February 29, 2016, 07:08:46 AM
Length = (Number of turns) . 2. pi . (radius of former)
Sometimes the length of wire in a coil is of crucial importance, relating to wavelength of an oscillation.
Any advice, Marco?
(I fancy breaking the circuit with a load and ammeter)
Click on this Link for a clearer reading patent:
http://www.pat2pdf.org/patents/pat5134985.pdf (http://www.pat2pdf.org/patents/pat5134985.pdf)
Quote from: FatBird on February 29, 2016, 01:56:11 PM
http://www.pat2pdf.org/patents/pat5134985.pdf (http://www.pat2pdf.org/patents/pat5134985.pdf) .
Thanks. I didn't know you could link to a patent as directly as that. useful.
I was wondering what happens if one breaks the cct with a load and meter and then arranges for magnets around the tube and salt water (an electrolyte) to flow through the tube. If there is an interesting result, it might have boating applications.
I was intrigued by the talk of a critical wire length. Those exotic Don Smith folk go in for this sort of talk. But it is predecated on oscillations.
QuoteYou do not have to believe me. You have to try.
Greetings, Marco
I agree with you, Marco. If he did not use such a poisonous tongue others might share more. A kind word goes a long way.
protonmom
while it seems odd, this is not entirely out of the realm of physics.
much study and $ has gone into determining what frequency gasoline resonates at.
http://ieeexplore.ieee.org/xpl/login.jsp?tp=&arnumber=5690321&url=http%3A%2F%2Fieeexplore.ieee.org%2Fiel5%2F5678851%2F5689839%2F05690321.pdf%3Farnumber%3D5690321 (http://ieeexplore.ieee.org/xpl/login.jsp?tp=&arnumber=5690321&url=http%3A%2F%2Fieeexplore.ieee.org%2Fiel5%2F5678851%2F5689839%2F05690321.pdf%3Farnumber%3D5690321)
there are effects for every element or molecule, compound, physical object, astronomical system, and probably the universe itself, at varying frequencies.
I have not tested what marco presents here, but it cannot be discluded at face value.
how to determine these frequencies? follow the physics behind atomic and molecular "detectors".
they are starting to make detectors for everything, that can single out components of our environment, one by one.
the information in their mathematics can lead to unlocking frequency-based potential applications for everything we know.
Quote from: sm0ky2 on March 02, 2016, 03:25:45 AM
That paper suggests frequencies in the "sub-MHz to a few MHz range". This is pretty wide. Can you narrow it down?
Bearing in mind my posts 26 and 28 (page 2), if we knew a relevant resonant frequency, we could determine the wire length for the coil.
