Hi all,
For those of you that are into these things, here it is -
38 40' 44.13"N, 104 37' 43.16"W ( Google Earth cut-n-paste ).
http://i276.photobucket.com/albums/kk15/fuzzytomcat/pyramids-ColoradoSprings_01.jpg
http://i276.photobucket.com/albums/kk15/fuzzytomcat/Pyramids-ColoradoSprings.jpg
And for more information -
http://www.energeticforum.com/42263-post71.html
Fuzzy
;D
Um....how do know if this comes out at you or away from you into the ground? It looks more like an excavation than a pyramid.
Charlie
Quote from: noonespecial on January 21, 2009, 07:37:02 PM
Charlie
Looking at nearby buildings you can see by shadows that the sun is approx due south.
By the pyramid being brighter on the south side and darker on the north it appears to be a raised pyramid of earth.
You can also see where they harvested the dirt from nearby and can also see big trucks working on the two unfinished mounds.
Charlie
Hi Charlie,
Look at the base dimensions the orientation to the equator square bases angled corners corners , stepped, a small lake to the side ( no water in bottom) ....... secured fenced guarded area, inside of a secured area, one entrance in and out, in a valley. The only way to see it is to scan the earths surface below 4 miles, objects 2000' in "Google Earth" are not accurate use a 'Topo" map. This facility is in a secluded valley the only road near is to the town of Fountain a military community for "Fort Carson" and "Peterson AFB".
http://en.wikipedia.org/wiki/Fort_Carson
http://en.wikipedia.org/wiki/Peterson_Air_Force_Base
Have you heard of these areas, if not now you have.
If you look around closely there are three inside the fenced area and two outside on the back. I would ask that you and all forum member look at the entire thread at energetic forum to see all the evidence.
I was more into verifying Teslas claims on "Wireless Transmission" and this is in direct relationship to it.
Also there are other indications of such a thing being known please see attached.
http://en.wikipedia.org/wiki/Annuit_Cœptis
Any one that cares to keep this topic "HOT" please feel free to "BUMP"
Thank you,
Fuzzy
Perhaps the military is replicating one of the free energy inventions revealrd on this site!
There was another thread like this a while back about a pyramid about 100 km north of Alice Springs in Australia. Shown with the same sort of Google scan as you are suggesting. It showed very clearly a massive pyramid and a road leading up to it. The road turned out to be the joint between two maps, the pyramid is not there. I should know because I know the area and only a few km away is a tourist road to a national park. There is no way you could miss the "pyramid" when traveling along this road.
Hans von Lieven
This is a covered trash dump. There are similar ones in Wichita, Kansas. The area to the west is just starting to be filled. Zoom in, you can see the trash and trucks.
Quote from: hansvonlieven on January 21, 2009, 09:07:55 PM
Hans von Lieven
Hi Hans,
This access is not to far from a back road as you can see at the "T" intersection there is a gate the road actually goes at a incline. If you take your mouse if you do not have a "Topographical" map of the area like a "USGS" map at the peak of the road the elevation is approx 5,644 feet ant the top of the pyramids are at 5,607 feet lower than the road. If you look at the top of the hills directly around it North up on the right they have been added to the just before the pyramid complex there is another gate and then a guard house, notice the power lines that go right to it.... something needed with a Tesla coil "years" ago to experiment with?? The pyramid on the right still has 4 objects at 90 degrees on top and has been shaved off on one side to make sure it's not visible through the lowest part the road in. If you check very carefully using "Google Earth" these pyramids are way below line of sight and it's in a military base and the base area for "NORAD" try flying a plane in there to check it out. It is what it is a pyramid in a small valley surrounded by hills.
Like I mentioned earlier this was a byproduct of what I was doing at Energentic Forum http://www.energeticforum.com/renewable-energy/showthread.php?t=3573 Tesla's wireless electricity transmission, and found this information, every continent has pyramids why not the USA, never believed in them really, I have no reason not to now.
Has anyone ever talked about the "Omega" building on Baltra Island ..... 00 28' 02.50"S, 90 17' 01.71"W ( Google cut-n-paste) the one that points to W 90 30' 00.00" for reference ground, the ohm sign is in the correct perfect rotation for reading with magnetic flux fields going CW.
Then there is the Gizmo that is close to the same parallel one mile away from the pyramids that is like no Circular or Cyclic Particle Accelerator on a "TOP" secret military base, I'm sure 10 years ago no one in the military thought there would be a "Google Earth"and now if they get caught hiding something of this value how the US Military would look to the public.
Then why was Tesla successful with his experiments that are all in the same "arks" that I have found and described at Energentic Forum that pyramids are in unless they work and so did all Tesla's "Wireless Transmission" devices.
Fuzzy
Hi All,
If using the radius 6679.17 Km from the "Earths" equator at each point "set" which is 120 degrees apart, you will pass over "Centered" (5 x 5) 10 miles wide path from every known pyramid and "TOP SECRET" military and civil facility in the world.
The fifth and newly found "Tropical Year Frequency" Circular Arcs goes directly over the middle of "Area 51" facility and has the same type of buildings with several huge grounding circles attached. ( 37 14' 6"N, 115 48' 40"W )
W 37 degrees 00' Phase A center of circle
E 97 degrees 00' Phase B center of circle
W 167 degrees 00' Phase C center of circle
The first was the "Omega" magnetic flux ground reference building -
W 30 degrees 30' Phase A center of circle
E 90 degrees 30' Phase B center of circle
W 150 degrees 30' Phase C center of circle
The second set ties together is "Wardencleffe" Laboratory facility in New York, Camp Upton "Brookhaven National Laboratory the Pyramids in "Gazi" lower Chile and Argentina and "Thunguska" -
W 24 degrees 00' Phase A center of circle
E 94 degrees 00' Phase B center of circle
W 144 degrees 00' Phase C center of circle
The third set ties Teslas sites in Colorado Springs, Peterson AFB, Fort Carson and protected Pyramid complexes on base -
W 35 degrees 00' Phase A center of circle
E 85 degrees 00' Phase B center of circle
W 155 degrees 00' Phase C center of circle
The forth set is used by "Cern" in Switzerland and France -
W 38 degrees 00' Phase A center of circle
E 88 degrees 00' Phase B center of circle
W 158 degrees 00' Phase C center of circle
As far as I can tell "Area 51" is separate similar to the "Cern" set.
For additional information and "PHOTOS" on my posting please see - http://www.energeticforum.com/renewable-energy/showthread.php?t=3573 "Tesla's wireless electricity transmission"
Fuzzy
As Fuzzy says, The site is approx 10miles due south of Teslas old lab site.
This link below talks about Teslas site and Pyramids ...
http://www.ancient-world-mysteries.com/tesla.html
Quotejust what is the connection between the work of Nikola Tesla in attempting to build a research station capable of transmitting power, and the Great Pyramid of Egypt?
The answer is to be had from a most notable harmonic association between the pure latitude positions of both sites. One that links the placement of the Great Pyramid and its associated Earth tropical year connection, to the very spot chosen by Tesla for his own power plant, and does so via the well noted progression of the ancient Babylonian Sexagesimal System.
edit:
see the thread fuzzy mentions above for much more info about this!
Quote from: Yucca on January 23, 2009, 04:37:06 PM
Thank's for the information Yucca this maybe the most important thing thats been hidden from the public that we can use, and possibly end world suffering !!
Fuzzy,
;D
Landfill. Go check it out. Nothing more than TRASH!.
Quote from: mindsweeper on January 23, 2009, 05:36:41 PM
Hey Mindsweeper,
If you look at the previous post here on the circle set -
and use the W 155 degrees 00' Phase C center circle you will find that the center of the pyramid on the right with north up is 6674.25 Km from this point to W155 00'. The equation for the three circular arks is -
13358.34 Km circumference
6679.17 Km radiusA remarkable achievement for a pile of garbage being so close to the radius, made by the government, in the most "TOP SECRET" site in the USA ....... OK ...... you might check the angle out and the surrounding area on "Google Earth" @ 1000' or less a little closer.
Here is a link to help get you up to speed ........ you stand alone .........http://www.energeticforum.com/42263-post71.html
Who do you work for some one nice I hope ??
He is not alone.
I have two such sites within 20 miles of my house. I know. I've dumped garbage in both and so has most of the population around here. Just checked. They look very much like the ones you shared.
As far as Google Earth being a value in showing military secrets. Sorry folks. If that mistake has happened it is surely already being cleaned up.
Try looking at the submarine dry docks on the eastern coast of Russia or China. All detail is washed. An obvious poor job too.
Locate pics of Fort Huachuca... There is quite a bit missing. I know because I used to live there ;)
Quote from: BEP on January 23, 2009, 08:29:47 PM
He is not alone.
Hey Bep,
Please take some time using "Google Earth" look at a maximum
1000' to a bought
500 ' above the ground. follow the terrain up from the pyramids in the areas between the hills you will see water diversion areas and pooling areas similar to the pyramids in Mexico and South America. Look closely at the Hills ridge lines the highest points around the area above the pyramids to the left North up you will see it has been modified and has what looks like a old road on top. The access road into the pyramid complex is on a rise and 500' to 800" away is at 6644 feet the pyramids are much lower at all the tops or any thing there in the complex.
The pyramid on the right has 3 areas at 90 degrees you can clearly see exactly like the ones at "
Gazi" with there tops removed because of being made of possible exotic materials. Why would the entrance be gated and the area fenced at the main road which is way below eye level and the so called garbage dump site fenced again with a guard shack before the complex. Why is there a double pole power line that goes to the complex from a power station if you follow it that goes no where at the pyramid site what was all the power needed for was this for a Tesla coil in the 1920 to 1940's for testing. I don't know maybe it's my video card and monitor that is giving me better details some cant see or haven't taken several hours to look at to make a claim such as mine.
Here is what I've came up with on the "Tropical Year Frequency" Circular Arcs I'm looking "Down" on the North pole with the Earth is running CCW with three hundred and sixty (360) CW magnetic flux circular lines penetrating the Earth three hundred and sixty times (360) places around the "Equator" each "Circular Arc" in sets of three (3) phases A, B, and C offset one (1) degree in sets of three (3). There are one hundred and twenty (120) sets for each of the three (3) phases A, B, and C. This is a change as you will see to finalize this theory of "Teslas" wireless transmission. ( everything in multiples of three )
The "Tropical Year Frequency" Circular Arcs .....with quantity of arks in a multiple of three to cover exactly all existing explained and unexplained areas of interest with large grounding rings or pyramids around the world either ancient or new ran by government agency's.
There are one hundred and twenty (120) sets of three (3) circular arcs for each phase or 120 degrees, the three circular arcs per set are connected in a "delta" or "star" more commonly known as a "Y" configuration A-B, B-C, and C-A inside the earth. The one hundred and twenty (120) Y connected sets of three (3) circular arcs are totally separate being one degree (1) apart for a total of three hundred and sixty (360) degrees (Tesla Poly). This would verify 100% of what Tesla said that was possible to send radio waves, electricity, video or photos and energy waves and more as there are one hundred and twenty (120) Y connected sets of three (3) circular arcs to work with as long as you have a "EARTH" ground to gain access on land with each of the one hundred and twenty (120) per phase Y connected sets of circular arcs.
As far as I can determine there are only five (5) sets being used as follows -
The first "Omega" ground reference building at -
( 00 28' 02.50"S, 90 17' 01.71"W )
The second set ties together is "Wardencleffe" Laboratory facility in New York, Camp Upton "Brookhaven National Laboratory the Pyramids in "Gazi" lower Chile and Argentina and Thunguska -
( 46 14' 05.59"N, 06 02' 34.98"E )
The Fifth set is used by "Area" 51
Earth
44,075.02 Km cir.
"Arks"
13358.34 Km dia.
6679.17 Km radius
Ark radius at "Equator" points 10 to 15 "Miles" wide ( 5 x 5 ) depending on moon and tidal effects.
addtional information, photos and illustrations see -
Fuzzy
I drove by there today, IT'S A LAND FILL SITE. Honest. Perhaps the secret site is under all that topsoil but I assure you. It's land fill.
Quote from: mindsweeper on January 24, 2009, 05:04:52 PM
Mindsweeper,
The access road into the pyramid complex is on a rise and 500' to 800" away is at 5644 feet the pyramids are much lower at all the tops or any thing there in the complex.
The main secured road at the "Tee" intersection is at 5584 feet at a
locked gate .81 miles on the only road into the complex past the
locked gate .68 miles the road rises to 5644 feet, the pyramids are .13 miles past the high spot on the only road in at 5543 feet 103 feet
below the ridge into the pyramid complex.
How did you see over the hill ridge into the complex its over 100 feet below the main road behind locked gates ?? As far as I am concerned now
you are with the government or a agent and doing nothing but giving out disinformation that has been going on now for years, you have no expertise in this area and have not spent countless hours going over every inch of the 2000 acre's surrounding this area using "Google Earth", other satellite imaging maps, USGS Topographical maps and several other Map references to come up with this information ......
not a drive by ..... that you can't see jack .....
I wish you success at what ever you are trying to accomplish but such threads as this make me want to ask.....
Who are you working for?
Just in case you are what I think you are please include this in your weekly report:
You have succeeded in washing out virtually all of the publicly posted research on the site. However, all of that research continues using other communication methods.
Oh! And sign the quote as 'In God We Trust - All Others We Monitor'. That should wake a few of them up ;D
Quote from: BEP on January 24, 2009, 09:50:11 PM
Hi BEP
Right this minute I work for the
people the common person to make things right and hopefully to stop world suffering, I have never worked as a government "employee" in any shape or form, I'm just a plain "Electrical Contractor" with a "Electrical Engineering" background.
It's also to vindicate one of the greatest inventors of our time "Tesla" he deserves better than what has been given him by the media and the government, dyeing a poor man for what he has accomplished, not to benefit just the military of countries and a few select private government ran laboratory's. I also think that just like anything else using frequency's for TV or Radio that some of these arks can be designated for public "Wireless" use, using some kind of guide lines that can be agreed upon by public and government elected groups.
I could have held this back for fear of what could or may happen to me or my family, I chose to tell the world and believe me I did, and just not a few threads on a couple of forums. If I make anything monetary from this it would be from lectures from this information and possibly some others I have obtained if it's unclassified, right now I've not disclosed because of "real" possible security issues that may be connected.
Fuzzy
@fuzzytomcat
Perhaps you should research what you can see, I have and I wish you all the best on your quest. You are obviously a better person than I as you have come so far and not left the comfort of your armchair.
http://wikimapia.org/#lat=38.844755&lon=-104.579501&z=14&l=0&m=a&v=2
EDIT: Added a list of them:
http://www.mapquest.com/maps?city=Pueblo&state=CO&zipcode=81008-3755&country=US&latitude=38.5589&longitude=-104.6674&geocode=STREET#a/maps/l:::Pueblo:CO:81008-3755:US:38.5589:-104.6674:street::1/m:hyb:12:38.5589:-104.6674:0:::::/io:0:::::f:EN:M:/e
And the Directory with map info for all the public ones. I'm looking for the hazardous site now.
http://www.wmdisposal.com/facilities/results.asp?state=MT
EOS!
Quote from: mindsweeper on January 25, 2009, 06:08:37 AM
EOS!
Sorry man
wrong one thats the one at 38 32' 57.04"N, 104 39' 39.39"W ( cut and paste GOOGLE EARTH )
Your right that's a dump go to the north 6 miles if you can get thru the gates !!
You want
38 40' 44"N, 104 37' 43"W ( cut and paste GOOGLE EARTH )
The other reason this isn't listed it's way out of the
"flux' ark by miles in all my postings with a
radius from the Equator of
6679.17 Km
Here is a site map with areas of interest-
The Turquoise rectangles is land that has been modified for pooling of water for storage countless ponds including hundreds of diversion walls in the valley areas,
Damn that was 70 miles out my way. I'm back over to my fathers house for the last time on Monday. I'll take some cell phone pics for you.
TBH I'm 99.9% sure it's landfill but you never know. There is a site close where all hazardous waste is taken and buried. Stuff like Asbestos and Toxic liquids in barrels, these are harder to find but it could be one of them, secure and out the way.
JESUS'! how many people you got roaming round here?,
If all that work was done via Google then that's a lot of speculation don't you think?
Quote from: mindsweeper on January 25, 2009, 06:53:46 AM
Hey, Like I said it's in double secured area a small deep valley you might be able to see a little of the top but I doubt it, they look to be fairly efficient covering them up, and they may be buried some the one top left maybe is one but I am fairly sure that the one on the top right is a pyramid the 3 visible black spots on the top ( should be four ) it's exactly like the ones at "Gazi" in the same place or position, and it's right on the cross hairs exactly, excellent indication .... if you have a chance to look at them both.
Have Fun,
Fuzzy
Quote from: mindsweeper on January 25, 2009, 06:57:14 AM
I'll never tell, it's amazing what one can do with the right connections ...... ::)
Quote from: fuzzytomcat on January 25, 2009, 06:45:17 AM
Hi All,
Here is the key list of world locations that have been located onto "Google Earth" the most common satellite imaging source, for everyones reference, including all "flux" ark radius
6679.17 Km on the
Equator for the ( 13358.34 Km Dia. ) Tesla's "Wireless Transmission" and the other points. The file has been zipped and is called ...
Master_World_Points.Kmz ... which when unzipped can be opened by "Google Earth" using .... File .... Open ( file ) .
Happy Hunting !!
Fuzzy
My Google earth does not show anything from you're file. it appears to be blank. I have version 4.3.7284.3916 (beta) ... Anyone else have this problem ?
The file size is only 683 bytes, please repost..
Hey minesweeper,
Well try it one more time ......
Opening Saved Placemarks
You can use the following methods to open placemarks and folders saved to the file system on your computer's hard drive.
From the File menu, select Open. Navigate to the folder on your computer that contains the KMZ or KML data you want to open in Google Earth. Select the file and click the Open button. The folder or placemark appears beneath the Temporary Places folder and the 3D viewer flies to the view set for the folder or placemark (if any).
Locate the file you want to open. Once you have located the file on your computer, you can simply drag and drop the KMZ file over the Places panel or 3D viewer. The 3D viewer load the file and flies to the view set for the folder or placemark (if any).
Tip: When you use the drag-and-drop method of opening a placemark or folder, you can drop the item over a specific folder in the Places panel. If the My Places folder is closed and you want to drop it there, just hold the item over the My Places folder until the folder opens up and you can place the item within subfolders or in the list. Items dropped in the My Places folder appear the next time you start Google Earth. Otherwise, you can drop the item in the Temporary Places folder. Items opened this way appear only for the current session of Google Earth unless you save them.
Hope it works for everyone
Fuzzy
You are kidding right? The US military were pioneers in space based surveillance, but anything Google Earth shows you the Russians or Chinese could see 20 years ago.
Google Maps claims that site is 10000 Squirrel Creek Rd Fountain, CO 80817
Amazingly, guess what else Google found at that address!
http://uswaste.com/colorado/landfill/index.html
Fountain Landfill & Recycling
Customer Service Phone: 719-382-9661
FAX: 719-382-9168
And if you zoom into that address on Google Maps, you get the dead center of your mysterious landfill pyramid!!! ::)
Quote from: wizardofmars on January 25, 2009, 11:52:53 PM
FAX: 719-382-9168
Hey wizardofmars,
If your 100 % correct, I'll buy it ....... but one from a area that has a company known as "Evergreen Helicopters" which is a huge CIA cover up operation across the street from the "Spruce Goose" Museum and a secret FAA tracking station in McMinnville, Oregon in a dumpy airport, titles don't mean much and could be a government operation for all I know.
All this information has been sent by recommendations to some major Archaeologist because of the direct correlation to other facts I found between Tesla's possible use of influences from other pyramids in his "Wireless Transmission" research, development and usage by the USA government. The surrounding 7 mile radius area where hundreds and hundreds of modified landscaping some very large has been done very similar to what was done near the pyramids in Mexico and South America.
As I said before this was a by product of the Tesla's "Wireless Transmission" research I was doing finding the correlation between pyramids and his work ...... so far "no one" has had nothing to say about the Tesla's information I came up with on "Flux" arks and magnetic influences in almost two weeks ..... so I still fell pretty good.
As soon as I get any findings or responses from the numerous places that have this it will be posted, I think there might be just one there well see .....
Fuzzy
OK I drove another 70 miles out my way and as I approached at the main entrance to the site I was prevented from entering by guards on the gate. It was a private security firm who wanted some form of ID and a reason for visiting the site.
As I had no reason to lie I told them the truth and they LET ME IN!
I spoke to Mac the site foreman and he took me on a tour of the facility. It's a huge LAND FILL SITE. It looks nothing like the photographs you see on Google and he said I was not the 1st to come here with tales of pyramids.
All in all it was a nice 45 min tour of the DUMP... There is NOTHING there that deserves examination or further investigation except the exceptional smell of fish, we are many miles away from the sea but the smell of fish at this site is overwhelming.
I don't know what else to say but it is 100% a land fill site.
Sorry Fuzzy.....
Quote from: minesweeper on January 26, 2009, 05:06:38 PM
Sorry Fuzzy.....
Good work .... Thanks for the information minesweeper,
Humm .... Guards & Fish ....
weird ...... If you remember did the chain link fence around the pyramid area look new or old .... rusted like maybe 40 years old ? Any thing else that may be out of place ?
I'm still waiting for a response from all the university's and archaeologist I sent this information to last week. It's strange to have guards at a land fill site you can't see from the road and if things have changed that much, possibly things were buried by the government ..... as I see it to the US military or government this would be 14th century trash just a pile of rocks because they have a new 21st century "Gizmo" several miles away at "Fort Carson" near the airport runway. Many have said that all the satellite photographs looks as if there was a trail or road to the top of the pyramid on the right with the three black dot area at 90 degrees on top and shaved off side. If there was something like a top made of exotic materials they didn't use a Chevy pickup to go to the top in the 1700's when it may have been found, more than likely a wagon pulled by mules.
To many questions for me that's why I got all the other experts involved to look at the whole picture ..... with the land modifications around the area I indicated with the turquoise squares on the last attachment of mine, including the Google Earth "KMZ " file of everything on the Pyramids and my research on Tesla's "Wireless Transmission" for full disclosure and independent verifications.
Thanks again,
Fuzzy
Hey mindsweeper,
With the 45 minute tour how many pictures did you get ...... a bunch I hope ?? Plus any thing on the other questions - If you remember did the chain link fence around the pyramid area look new or old ....
rusted like maybe 40 - 60 years old ? Any thing else that may be out of place ? Was the area hidden like I said below eye view from the main road ?
Thanks,
Fuzzy
Hi All,
Just Updated the "WYE LOCATIONS WORLD KEY" pin numbering and added "Tikal,Guatemala" and "Shaanxi - Xi'an, China" with a new "Google Earth" file ( MWP_Rev_01-31-09.zip ) for all the KLM pin placements and some "TYPO" corrections in bold text.
I also have not heard from anyone including all Top 10 USA Universities ( PLUS some ) and Archaeology Departments that was e-mailed with this information it's quite a list and will post names or e-mail addresses if it continues without any responce.
"Earth"
44,075.02 Km cir.
"Arks"
13358.34 Km dia.
6679.17 Km radius
___________________________________________________________________________________________________
The first "Omega" ground reference building Baltra Island ( 00 28' 2.50"S, 90 17' 1.71"W ) at-
E 89 degrees 30' Phase B center of circle
The second set ties together is "Wardencleffe" Tesla's Laboratory facility in New York, Camp Upton "Brookhaven National Laboratory the Pyramids in "Gazi" lower Chile and Argentina and Thunguska at-
E 96 degrees 00' Phase B center of circle
The third set ties Tesla's sites in Colorado Springs, Peterson AFB, Fort Carson with possible Pyramid complex on base and Central Mexico at-
The forth set is used by "Cern" in Switzerland and France at-
E 82 degrees 00' Phase B center of circle
The Fifth "Area 51" US Military facility ( 37 14' 6"N, 115 48' 40"W ) at-
W 47 degrees 00' Phase A center of circle
E 73 degrees 00' Phase B center of circle
The sixth "Tikal, Guatemala" Dozens of Mayan Pyramids ( 17 13' 19"N, 89 37' 22"W ) at-
W 31 degrees 00' Phase A center of circle
E 89 degrees 00' Phase B center of circle
W 151 degrees 00' Phase C center of circle
The seventh "Shaanxi - Xi'an, China" ( over 100 Pyramids ) Government and military Facilities at-
E 42 degrees 00' Phase A center of circle
W 78 degrees 00' Phase B center of circle
E 162 degrees 00' Phase C center of circle
_______________________________________________________________________________________________________________________________
Tesla "Wardenclyffe Tower" New York
40 56' 50.30"N
72 53' 55.60"W
Camp Upton "Brookhaven National Lab" New York
40 53' 01.26"N
72 52' 33.86"W
40 52' 27.01"N
72 52' 48.41"W
Tesla Colorado Springs, Colorado
38 50' 4.00"N
104 38' 30.60"W
38 50' 02.02"N
104 38' 35.40"W
Peterson AFB Colorado Springs Colorado
38 48' 42.66"N
104 40' 48.33"W
"Fort Carson" ( Pueblo,Elpaso and Fremont County )
38 44' 44.68"N
104 47' 05.67"W
Baltra Island "Omega Building" ( Seymour Island )
00 28' 02.50"S
90 17' 01.71"W
"Cern" Switzerland - France Border
46 14' 05.59"N
06 02' 34.98"E
46 14' 08.09"N
06 03 18.85"E
Colorado Springs Pyramids
38 40' 44.13"N
104 37' 43.16"W
Great Pyramid of "Gazi"
29 58' 50.96"N
31 09' 0"E
"Thunguska" Siberia
48 38' 0"N
134 54' 0"E
Area 51
37 14' 6"N
115 48' 40"W
Fuzzy
Hey Fuzzy,
The files you are posting only contain ONE place mark. I don't know if it's a bug or compatibility issues in version numbers but all the files I have downloaded contain one marker.
Quote from: mindsweeper on January 31, 2009, 02:23:00 PM
Hey Fuzzy,
Hi,
On the LH sidebar ( F11 full screen -toggle- Sidebar ) is the "Places" in the center, make sure all the boxes are checked on, sometimes they are off and you got to turn them on. Should work if not well work it out ..... got to ...
Best,
Fuzzy
Quote from: fuzzytomcat on January 31, 2009, 02:39:35 PM
Hi,
Best,
Fuzzy
Exactly how I'm doing it, I get one place mark. That's it.. Must be a version incompatibility. Are you running.. 4.3.7284.3916 (beta) - Jul 8 2008 - 19:04:33
Quote from: mindsweeper on January 31, 2009, 03:03:46 PM
Thank You, Thank You "mindsweeper"..... the files were in my "Site Seeing" not in "My Places" here is a 77Kb file ...... sorry everyone !!
Best,
Fuzzy
;D
Now I'm on the trail, it works.. One site I am defiantly going to, it's an amazing find..
I'm routing to Asia at the moment but should be back to transatlantic on Tuesday. I should be able to visit on Wednesday if all goes ok and my sick colleague recovers..
I'll let you know what I find and where it is once I have more info.
EDIT: cant spell with excitement.
Quote from: mindsweeper on January 31, 2009, 04:38:45 PM
Hey mindsweeper,
As you can see the Turquoise rectangles is land that has been modified for pooling of water for storage countless ponds including hundreds of diversion walls in the valley areas,
they may be able to bury a Pyramid but they cant get rid of a thousand of these things in a 6 mile radius .... It's happy hunting time !! I'm glad the new "KMZ" 77 Kb zip file works now thanks for your help again.
Fuzzy
;D
Very peculiar, I think the terrain modification for collecting water might be:
(1)
Planning for a future time when the whole area gets closed off from the rest of the USA and then they can be self sufficient with water and use the water to grow crops etc. (This is unlikely, the powers that be could easily secure a greener area than this, should they wish.)
(2)
Training for off world activities like modding other planets for inhabitation, testing cheap and easy terrain mods by earth shifting that will encourage water colection.
(3)
Maybe for some weird reason the water that collects in this area has special properties, super orgone attractant maybe? I admit, this is a way out there theory, but it did pop into my mind.
Anyone got any other ideas...
Hi all,
Is this some more on the usage of Teslas "Wireless Technology" that has been covered up by governments world wide ...... did anyone look just west of the "Gazi" pyramids in Egypt for any facility's that have a ring a Tesla feature ?? Try four miles west of the magnetic ark and 5 miles from the Gazi pyramid this is the same ark "wye" (Y) set that ties together "Wardencleffe" Tesla's Laboratory facility in New York, Camp Upton "Brookhaven National Laboratory - New York the Pyramids in "Gazi" Egypt, lower Chile, Argentina and the Thunguska explosion.
Great Pyramid of "Giza" - 29 58' 50.96"N, 31 09' 0"E
Egypt "Government Facility" - 29 57' 51"N, 31 03' 20"E
Fuzzy
Quote from: Yucca on February 01, 2009, 07:04:38 AM
(1)
(2)
(3)
Hey Yucca,
The landscaping modifications is exactly the same as the "Garden of the Gods" area, 20 miles North of Colorado Springs or Pikes Peak. The "Ute" Indian tribe was in the Pikes Peak area they were hunters and traders more seasonal and moved South in the winter. The "Hopi" Indians were cliff dwellers and desert farmers the grew lots of corn and believed to have lived around the "Garden of the Gods" area and strangely they also believe in UFO's in there ancient writings. The big problem is there is no record at all of any Indians I can find for this area thats 30 miles away South from the "Garden of the Gods" in the area I proposed a Pyramid is in, and there are 4 times as many landscaping modifications and larger ones here also.
I also found what appears to possibly be a structure in a isolated area on a hill top not far from my proposed Pyramid this is something that the 'Hopi" Indians did as lookouts because of what the Spanish did to them in earlier days, it's not on a map seam or has any visible roads around it.
38 39' 39"N, 104 34' 45"W
I attached the World Master pin set list so anyone can see my findings on "Google Earth" concerning Tesla and the Pyramids it's a 77 Kb ".KMZ" zip file that can be opened and saved.
Hi All,
It appears that some "High Power" resonance experiments may be happening at Colorado Springs, Colorado as I described earlier -
The Tesla's sites in Colorado Springs, Peterson AFB, Fort Carson with possible Pyramid complex on base and Central Mexico Pyramids at "Wye" connections -
KOAA.com - Unexplained ground heat burns boyââ,¬â,,¢s feet (http://www.koaa.com/aaaa_top_stories/x1331638508)
KOAA CH5 NBC News Video
http://static.koaa.zope.net/includes/video/480x400_zope.swf?cat=zog&id=x1331638508 (http://static.koaa.zope.net/includes/video/480x400_zope.swf?cat=zog&id=x1331638508)
Resonance in Colorado Springs (http://www.humanresonance.org/co_springs.html)
Quote:
"The highest temperature we got at the surface of the soil with the sun shining on it was 800 degrees, which is pretty darn significant. Radiant heat from the sun will get it up around 150, 160 degrees, but not to that level."
This area is well within the 6679.17 Km Radius from W155, on the Equator in a 10 to 15 mile wide path in the circular radius ark. With all the circular arks in a CW rotation it seems that the facility at Fort Carson or Peterson AFB must have under shot the target by 16 miles after circling the Earth.
I'm also looking into the "Hopi" native American Indians ancient habitation of this area, there are some really unusual facts parallel to the Aztec and Mayan Indians of Central and South America.
Fuzzy
Hi All,
There is one tasty bit of information that has been discussed but over looked through the years, it's about grasshoppers. During the 1800's the "mesa" in Colorado Springs was infested with grasshoppers billions of them this is probably why the ancient Indian dwellers of the area went to the cliffs or left.
The grasshoppers would show up around the middle of April to May and stay around for four months eating everything in sight estimated 10 to 100 acres a day. It got so bad in 1885 that the governor of Colorado went to congress for help and got none, in 1899 it was the worse it had ever been more like a plague.
In the fall of 1899 is when Tesla did his "Electrical Transmission" experiment when he lighted 200 inductive lamps around 26 miles away in Larkspur or Palmer Lake, this was the night when the ground glowed around the Colorado Springs laboratory like "saint elmos fire" and sparks would jump from the ground to your feet when you were walking.
In the spring after Tesla left in 1900 the "Grasshoppers" were gone well almost they found one and the "Colorado Beetle" or common potato-bug was gone also. The grasshoppers were never to return again to the "mesa" of Colorado Springs ....
Glen
Hi all,
I have been able to establish the location of Nikola Tesla's laboratory in Colorado Springs, Colorado with a photograph in 1970 of a Historic marker to Nikola Tesla in Memorial Park, marking the approximate site of his laboratory on North Foote Avenue and Pikes Peak Avenue. This is two blocks east of the location from a member "rickoff" at Energetic Forum.
I'm still looking into early 1800's maps in the "Fountain, Colorado" area where Fort Carson is but news paper dated information on Tesla and the Colorado Springs area from the Outwest Printing Company, Colorado Mountaineer and the Colorado Springs Gazette has been split up and sent over the four corners of the United States any available information is from Denver, Colorado if your lucky. The maps for all the surrounding area of Colorado Springs have also had the same demise, still in existence somewhere in a box or filing cabinet to be seen by appointment "if" you know what your looking for, hopefully its on what you requested to see.
Here is a list of the places that most of the information on Colorado Springs is, if anyone cares to research Tesla's work and time there -
Special Collections « Colorado College Tutt Library (http://www.coloradocollege.edu/library/index.php/specialcollections/)
Denver Public Library: Western History Genealogy: Digital Images (http://history.denverlibrary.org/images/index.html)
History of the American West (American Memory, Library of Congress) (http://memory.loc.gov/ammem/award97/codhtml/hawphome.html)
The Colorado College Tutt Library: Colorado Springs Area Early Views Guide (http://www.coloradocollege.edu/Library/SpecialCollections/Colorado/EarlyViews/Guide.html)
City of Colorado Springs - Colorado Springs Pioneers Museum Homepage (http://www.springsgov.com/SectionIndex.asp?SectionID=9)
Colorado Historic Newspapers Collection (http://www.coloradohistoricnewspapers.org/Default/Skins/Colorado/Client.asp?Skin=Colorado&AW=1234163645435&AppName=2)
The Library at the Colorado School of Mines - Arthur Lakes Library (http://library.mines.edu/)
IMLS Digital Collections and Content (http://imlsdcc.grainger.uiuc.edu/)
The Map area I'm most interested in is the Fountain and Fountain NE - T16S, R65W, 1, 2, 11, 12 which has became quite elusive and maybe being suppressed because it appears they do exist somewhere.
The spookiest information kinda unrelated for me I found was on a government study at the "Cave of the Winds" just miles out side of Colorado Springs on "Earths" magnetic pole reversals from the magnetic sediment found inside of these million year old caves ...... 5 to 10 times in earths history ...... WTF does this mean ...... it just can't be good.
http://carsologica.zrc-sazu.si/downloads/361/luiszer16.pdf (http://carsologica.zrc-sazu.si/downloads/361/luiszer16.pdf)
The magnetic field of the earth has reversed many times in the past (Tarling, 1983).
The bottom line for me is there has been a significant effort to silence Nikola Tesla and to make finding out any information a task to be reckoned with, the United States government has a 100 year head start on us all.
Fuzzy
Hi All,
In Reply #46 this thread I also found what appears to possibly be a structure in a isolated area on a hill top not far from my proposed Pyramid , it's not on a map seam or has any visible roads around it this was using "Google Earth" view May 2, 2006.
I found some images on Microsoft "Terra Server" views released September 9, 1999 it's a Black and White from the Russian "Cosmos" KVR-1000 with good details of the surrounding area.
The other image is the one proposed Pyramid thats been modified or side shaved prior to the two constructed on the left of the power lines that go through the center of this aged fenced and secured facility. I have reservations on the actual site being one of a garbage dump possibly this is where the many old buildings from Fort Carson went as the entire Colorado Springs area in on a huge rocky aquifer. The noted and historic springs in the Colorado Springs mesa garbage would cause damage to the surrounding wells and springs in the upper valleys making the exposed reservoirs the only source of clean drinking water.
Fuzzy
Second Photo down on Page 1 (Fort Carson Ring) is a High Explosive Magazine. notice how the dirt is piled up around it so that it deflects the explosion upwards, even across the street. They have these at EVERY military base with EXPLOSIVES. its the safest way to store them. the shape depends on how much explosives needed to be stored in an area & safest layout to prevent secondary detonations of other magazines & other damages. we had these at Norfolk Naval Base in Virginia to store the bombs & ammo.
unfortunately the pile of dirt looks like an excavation site =(
Quote from: fuzzytomcat on January 22, 2009, 06:38:45 AM
Hi Hans,
Fuzzy
Quote from: Professor Z on February 28, 2009, 05:37:34 PM
Hi Professor Z,
The Fort Carson Ring under normal military facilities it might be what you say but it's to close to the runway and it has a underground facility next to it (know someone that's been inside) looks like a big red parking lot, also there are power poles all over the place. What your thinking about is several miles away south, Fort Carson area was a old Silver mine in the early 1800's and has miles and miles of underground tunnels everywhere. There is a download for "Google Earth" a KMZ zip file that thats called WMP_revB_01-31-09 it can be opened and saved with all of my Earth points for this and Tesla's "wireless electrical transmission" research I'm doing which may be helpful to you.
Fort Carson is the home of the 2nd, 3rd and 4th Brigade Combat Teams of the 4th Infantry Division, the 10th Special Forces Group, the 71st Ordnance Group (EOD), the 759th Military Police Battalion, the 10th Combat Support Hospital, and the 43rd Sustainment Brigade. The post also hosts units of the Army and Navy Reserves and Colorado Army National Guard.
http://en.wikipedia.org/wiki/Fort_Carson (http://en.wikipedia.org/wiki/Fort_Carson)
And 8 miles North is Peterson AFB it's home to the United States Northern Command (USNORTHCOM), North American Aerospace Defense Command (NORAD), Air Force Space Command (AFSPC), AFSPC's 21st Space Wing (21 SW), Army Space Command, and the Air Force Reserve's 302d Airlift Wing (302 AW)
http://en.wikipedia.org/wiki/Peterson_Air_Force_Base (http://en.wikipedia.org/wiki/Peterson_Air_Force_Base)
The proposed pyramid the one to the top right has been there for years and years as far as I can find and as of right now some old 1907 topographical maps show something there but it's not a photo and thats what I've been looking for proof. As for possibly being a bunker .... well I think it would be safer inside of Cheyenne Mountain which is 12 miles West from this site. ;)
http://en.wikipedia.org/wiki/Cheyenne_Mountain (http://en.wikipedia.org/wiki/Cheyenne_Mountain)
Best Regards,
Fuzzy
if its that close to the runway, why doubt it of being used to store bombs for the planes?? i was in the military in the weapons department G-3 and it was part of our training to know what Magazines are & what they look like. the rest of the tunnels i have no clue about, that part is quite interesting. you have a link to your tesla research??
~Z
Quote from: fuzzytomcat on March 01, 2009, 05:35:53 AM
Hi Professor Z,
Best Regards,
Fuzzy
Quote from: ProfessorZ on March 01, 2009, 05:51:23 AM
~Z
Hi Professor Z,
He is the link for the research I've done on Tesla's "Wireless Electrical" transmission in Colorado Springs, Colorado laboratory, Shoreham, NY "Wardencluffe" laboratory and now I'm at the "Telefunken" site at Sayville, NY and the "Marconi" New Brunswick site, one of the last know sites Tesla worked at for the US Navy from 1911 thru 1921. The photo I have included is the one of mystery with some of the greatest scientists of the era attended. From left to right are: three unidentified men, David Sarnoff, Thomas J. Hayden, Ernst Julius Berg, S. Benedict, Albert Einstein, Nikola Tesla, Charles Proteus Steinmetz, A.N. Goldsmith, A. Malsin, Irving Langmuir, Albert W. Hull, E.B. Pillsbury, Saul Dushman, Richard Howland Ranger, George Ashley Campbell and two unidentified men. This was a bunch of scientist that didn't really like each other together at a "radio" station and Albert Einstein made a special trip from Europe just for the gathering ...... something else was going on there and possibly we have the answer. ( Nikola Telsa was 65 in this photo )
http://www.energeticforum.com/41728-post35.html
We're at post 125 now with the possible explanation on how the 1931 Pierce Arrow was modified and powered.
As for the possibility of the ring to be what you say at Fort Carson the person I know has only been inside of the bunker complex at that location not on top, security is really high with areas off limits period. You could be correct as there is a know "particle accelerator" at Peterson AFB to the North of the airport runway where the underground bunkers are under the parking lots they don't really need two 4 miles apart.
Best Regards,
Fuzzy
Wouldnt Tesla stand a lot taller than the person listed?
Quote from: Blacksmith on March 01, 2009, 03:55:26 PM
Hi Blacksmith,
I know what your saying ....... all the articles that include a height say he was as tall as 6 foot 7 inches but looking at all the photographs available it appears to be about 6 foot tall ( plus or minus ) the 1921 photo came from http://en.wikipedia.org/wiki/Newhaven_Marconi_Radio_Station http://en.wikipedia.org/wiki/File:Somerset_01.jpg
There is another photograph the clearest being from http://smart90.com/soulfind.com/frederickcollins.htm showing him as number 20 it's the "NBS Wireless Telephone Demonstration" in Philadelphia, Belmont Park in 1902 and he seems to be about the same height as most the other men there not a towering giant.
Sometimes a picture is worth a thousand words. ;)
Fuzzy
Are you still chasing after these phantoms Fuzzy? Discovering your pyramid was a landfill didn't convince you? :P
Here is the one problem with your new phantom - that isn't Tesla in the photo you posted! Apart from the obvious height problem pointed out by Blacksmith, the original source of the photo says the gentleman's name is Dr John Carson of the Western Electric Co. :o
Einstein visits the New Brunswick Station
Wireless Age
June 1921
Volume 8, number 9
Reading from left to right: David Sarnoff, Thomas J. Hayden, Dr. E.J.Berg, S. Benedict, Professor Albert Einstein, John Carson, Dr. C. P. Steinmetz, Dr. A. N. Goldsmith, A. Malsin, Dr. Irving Langmuir, Dr. Albert W. Hull, E. B. Pillsbury, Dr. Saul Dushman, R.H. Ranger, Dr. G. H. Campbell and C. H. Taylor
Source: the June 1921 issue of Wireless Age, Volume 8, number 9. On file: Stanford University Library, Ca., Sarnoff Collection at the Sarnoff Corporation, Princeton, NJ and Camp Evans.
See http://www.infoage.org/einstein.htm for the article text.
If you Google further, you can find all about Dr John R Carson. Some kind people even wrote a Wikipedia article about him! ;D
http://en.wikipedia.org/wiki/John_Renshaw_Carson
And the nice people at Princeton have an archive with a lovely photo of a young Dr Carson, just for you! ::)
http://diglib.princeton.edu/ead/getEad?eadid=AC017&kw=
Nice try - no Tesla!
Quote from: wizardofmars on March 04, 2009, 01:10:32 AM
Wireless Age
June 1921
Volume 8, number 9
Hey wizardofmars,
I saw that lone article you referenced http://www.infoage.org/einstein.htm with the crummy photograph and what I think your saying is that the photographs I posted do not have Nikola Tesla in them, and that these web sites have it wrong including "Wikipedia" that hasn't corrected the mistake yet. The photos at New Brunswick, NJ and from the Stubblefield "Wireless Telephone Broadcast" in Belmont Park, Philadelphia is a John Carson one of the Carson twins that went to Princeston University http://diglib.princeton.edu/ead/getEad?id=ark:/88435/qj72p7137 and worked for ATT it's him??
http://fuel-efficient-vehicles.org/tesla-flying-machine/Tesla-biography-Nikola.php
http://www.plasma-i.com/tesla.htm
http://www.reformation.org/nikola-tesla.html
Also there is this from - http://www.bibliotecapleyades.net/tesla/esp_tesla_14.htm
QUOTE -But later years turned a kindlier edge toward him. Long after his principle foe had died, other sought him out. Employed by the Rockefellers in their RCA venture, Tesla was given the task of restructuring the now failing Marconi System. David Sarnoff did not permit Tesla the dignity of working under his own name! .............. ............. While working for RCA under the name "Terbo", his mother's maiden name..........
As far as the proposed pyramid it's covered in garbage now the US Governments 17th century "trash" you know the same thing they did to the Native American Indians, it's in the way so get rid of it.
Hey wizardofmars,
No comments at all on the photos not enough proof or was your words about Tesla nothing but a drive by slam? :P The writer and publisher Leland Anderson is the only person that has indicated that the photos isn't Tesla and someone else ( selling books not facts ) ....... need more proof ...... check out this other photo, again a man around 6 feet tall ( plus or minus ) notice the facial bone structure and the ears compare it with the other photos it's Tesla not John Carson from ATT. ;)
Fuzzy
