UncleFester
Quote from: tagor on May 27, 2008, 11:18:28 AM
are you sure ?
are you sure ?
Yep, sure. First, I re-ran the high voltage supply with same carbon rod. It does the same thing. I also have a radiation burn from when I first ran it. Didn't know what it was at first, but I figured I touched the soldering iron or something, but now I know what happened. When I went to turn off the unit I rubbed up against the toroid with my hand. In that one spot it looks like a blistered area when you've rubbed up against the soldering iron. So the Geiger is picking up both EMI and beta, but how much of each is there? My unit is now fully shielded with aluminum so I wont be getting any more results from the Geiger other than emi, and hopefully no more burns.
Second, it appears as though type of carbon matters. I get little results with my other carbon rods and good results with the larger and different composition rods. I don't have the composition chart here but the color alone say's it's different stuff.
Third, there are only three of us that are really experimenting and have serious equipment enough to pull it off. Like I said with the Meyer stuff, if you don't have scopes, function gens, good control via PWM of alignment fields and cap bank discharge and some electronics knowledge I wouldn't try it until we have a proven schematic.
Still don't have my mini -dv here yet, and waiting on more parts to finally get rid of the 555 timers and go back to my old trusty Pic microcontrollers. Also getting my upgrade for autotrax so I can actually have the ability to draw schematics without doing something goofy like firing up Gimp or windows paint and spending hours for what ends up looking like an elementary school drawing.
ramset
Uncle fester @ you  gentlemen boggle the mind and I swell with pride to see you work thank you for the privilege   TRUE BRAVE PIONEERS    Chet
Thanks Grandma
UncleFester
Quote from: ramset on May 27, 2008, 12:19:15 PM
Thanks Chet, but really it was Juan who started this. I wouldn't have picked it up if Juan had not posted about his device etc. But it is exciting to see some of the results. Within the next couple weeks you should start seeing some major progress.
zerotensor
Quote from: leo48 on May 27, 2008, 09:21:27 AM
Hi all
I did a test
Cool.  It would be interesting to see the difference with the collector biased / unbiased with DC, and with / without the application of an external mag. field.
leo48
QuoteCool.  It would be interesting to see the difference with the collector biased / unbiased with DC, and with / without the application of an external mag. field.
This is the first test tomorrow I will do more testing and i post
  the results are still confident
(sorry if my English is no good I speak Italian and
translate through a translator)
leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
