Magnet Motor from Argentina, part2
Started by hartiberlin, April 12, 2006, 10:41:37 PM
kukulcangod
Delleman in my opinion, the wheel works better if lift up the magnet closer to the forward moving end of the rotor magnet, meaning it has to be placed one more space/magnet behind, is like a zipper action, or like a mower cuttin and flattening the jungle of magnetic lines leaving you a clear trial to walk free of obstacles,inmediately in front of you and automatically, I can avoid to also compare with a dunky following the carrot ;D, letting the half moon magnet "fall " into the gap pushed by the rejection of the other magnets which by the way are about 3 against one force, one being that empty space or lifted magnet ,as per the ramp has to be in equivalent place allowing space for the magnet to rise as well as living the one prior to this also up ,in a different degree of course but that will make that rotor move more freely ,at least for me it did worked that way, and fast......now when putting the top I realize the force was simply not enough ,assisted by hand showed that it wanted to  move ,rotate, my design is not that stiff despite modifications , but I feel encouraged about it.Great drawing by the way, Cheers
Dellemann
Hi kukulcangod,
thanks for your info.
Is this now right ?
Hi Delleman,
have a look at the 2 GIF animations
in:
www.overunity.com/torbay
directory.
It seems your right stators are too far away from the rotor and
one one stator at a time is only up and not more stators as in your case...
Dellemann
hi Stefan & thanks,
Then there is not a spiral ramp ?
But some pics on this tread shows them.
Than is this right ?
Hi Delleman,
yes, now it seems to be correct.
What you have shown is the TOP VIEW.
Now if you add a SIDE VIEW you can add the topcap lid,
where the stators are holded down and only one stator is allowed
to move up via the ramp in the top lidcap.
Thanks for the drawing.
