My s1r9a9m9 replication!
Started by Super God, January 23, 2008, 07:26:21 PM
nightlife
Here is the link to the video I was talking about.
http://www.youtube.com/watch?v=v8Ztw0nYVS0
Another member, tishatang, has started a thread about this motor as well as he has also posted a link to the patents.
The patent:
http://www.rexresearch.com/papp/2pappats.htm#4428193
The thread:
http://www.overunity.com/index.php/topic,5154.0.html
capacitor70
Modified coil photo
1. it works much better than previous coil.
2. ferrite core.
3. primary 12 turns.
4. secondary 32 turns.
5. no misfire observed
6. much fast spark generation.....
7. you can reduce secondary winding turns.
8. After increasing LV spark gap no problem at all....
@Shanti
Addition of diode at HV side created problem of misfire, direction of diode is confirmed.....
rfsimoes
I don't understand how the coil will isolate the LV from HV.
Well LV since is almost DC,because of the cap, (still using 330uF 400V?) it shouldn't pass through the coil.
The HV from ignition coil, since it is pulsed, it will pass through the coil into the LV circuit.
I'm I wrong?
rfsimoes
xbox hacker
@Cap70;
I thought you said DONT use magnet wire for the coil?
Questions about the coil and setup:
Is the primary on the HV side or LV side?
Are your caps VAC or VDC?
Could i use a VAC microwave cap?
How do you have the LV side hooked into the transformer? ...i need a little more detail  ;D
whats the gap sizes you have on the plugs?
Does the transformer get hot after long term use?
I made a transformer like the one on myelectricengine.com....but i dont have any caps...
capacitor70
yes, I said that, but it may wrong statement...I am using green 7 Stand wire for HV coil,
Primary of green wire is on HV side.
2000V 16KHz 7200pf AC Polyester Film capacitor.
Yes, make voltage level 6000V, series combination, anything can work
series with LV.
With ferrite core just put plugs, no need to change gap at all. Don't worry about gap it works
This is first time I am using, I don't know, I checked with little trials no heat is observed
With air and Iron core it is difficult to get it work...
How it works ?
1. Capacitor charge to HV and first spark plug acts as switch, switch triggers at high voltage
level this plasma channel discharges capacitor in the green winding transformer
primary.
2. If we directly connect HV to transformer(coil) green winding it will not allow
voltage to rise enough to trigger second spark plug. also LC resonance works here
3. Once high voltage spike is given at primary, secondary generates High voltage
and it is connected in series with LV so LV+HV(secondary) makes spark and plasma is generates...
How to test ?
1. Connect primary as shown in figure.
2. Connect spark plug to secondary, Do not connect LV.
3. Once you see spark at secondary, its done,
4. Connect LV in series with secondary and spark plug.
5. Due to low number of turns on secondary it will allow LV through spark plug...
