Hubbard coil
Started by EMdevices, July 01, 2008, 05:03:36 PM
z.monkey
Quote from: innovation_station on July 18, 2008, 11:16:57 AM
HAVE ANY OF YOU GUYS EVER REVERSE ENGINEERED A UFO PROPULATION SYSTEM WITH OUT KNOWING??
Howdy InnovationStation,
I'll let you know if the Infinity Coil levitates...  That would be cool...
Blessed Be Brothers...
Goodwill to All, for All is One!
innovation_station
Quote from: z.monkey on July 18, 2008, 11:27:30 AM
cool stuff
well i got your blast off figured .....
;D ;D
ist
ever see a large  cap discharged super fast to a coil.....
;)  hummmm....
giantkiller
@Grumpy, thanks. I will not add any complication to this. I can see my marching orders very clearly. I will have a test come the farthest by Monday. Gotta get some rod magnets or I can split cabinets magets. These will fit in the rat shack spools. As far as the center goes I will uses multiple around the inside. Would be nice to use a ring magnet like Marco has shown. Or do we need the flux to break into seperate paths as in a matching outer and center magnet pair?
As far as a wave goes...
Lets do a parallel analysis.
The compression wave is like an offset cam. And where has anybody seen any academic expression of this? And in any product?
The highest point of compression looks like the running of a Wankle engine (Mazda). Now in this new Hubbard / Deyo configuration (there are slight differences) there is a smooth roll and compression as the 500hz would do. But lets go above 40khz. Things get snappy. There are high speed emissions. The GK4 had these and also an iron core that got magnetized.
The field compression smacks of Kunel. And when a coil and center are pulsed the flux is squeezed between the two but there is an over flow to the forward and aft coils.
The resonant rise, bell shaped envelope scope shot showed me something new to play with. Definately something external. I am all over this this weekend.
The internal magnets give an unending supply of flux. Using just iron causes the need to power for flux. I would love to see the magnetic signature of the Hubbard and Deyo coils running. Singerxyz used an EGA monitor. I got one sitting in the garage just for this.
This weekend is available for this build. Stuck at work this friday. :P
The field in the center never gets a chance to diminish while the sequenial outer coils push against or squeeze the resultant field of each new relationship.
http://www.uic.nnov.ru/~kovy2/conf_in.htm Here is the answer.
We are done, boys.
http://searleffect.com/
http://www.geocities.com/Area51/Shadowlands/6583/project163.html
http://www.davidhamel.com/  His took off vertically also!
Same thing across all these links. All else is futile.
And why do UFOs have spinning lights on the bottom of the craft? Is dark in space? Think about that! We are being given and example. And which direction do the lights all spin? The ships don't spin! What The Flip is going on?
Searle, Hubbard, Deyo, Brown, Hamel, Leedskalnin. Betcha ED had loops around the round motor housing. The rusty one with the funny fan plates on the side.
@z.monkey,
I am gonna build me one of these!
--giantkiller. This incorporates safety by dissemination. You guys have been great!
p.s. Where the Hell have I've been?
z.monkey
Howdy GiantKiller,
Nice set of electrogravity links, my favorite!
The future is so bright I gotta wear shades...
giantkiller
And this one is really kick butt!
It looks the iron wire is the outer ring. If this is so then as each coil field builds the outer loop is only catching one pole of the smaller coils. Pulsed DC.
--giantkiller.
