Selfrunning Waterpump-generator device runs 60 Watts lamp...
Started by hartiberlin, July 16, 2008, 03:09:31 PM
chep
therealrasta, Yes there is gravity here. The pump is pumping anyway. It doesn't change anything if you put the outside to the floor or to the sky. Its not changing the pomp needs, only the lengt of where the water can go..
YOu should think like this.  We start with -500W (just for exemple, I dont know the pump).
So now the gravity give us 50w (still an exemple)
The belt make us loosing ?%
Is the generator going fast enougth to produce 450w+?%.
On any scientis head, its offcourse no.
But in this case, you dont know the pump and you dont know the generator. And you dont even know there is gravity ,) and inertia as well (there is some water in the spoon on more than half round otherwise we wouldnt see water throught outside the box ,)
All those thing have to be considerated. Its to easy to alway talk about physics law etc etc..
Does anybody already try this? no ofcourse its so obvious....
So obvious that earth is plane and sun is turning around ,))
And he shows us the thing while the pump was already running.
remember for earth turning around the sun? The most difficult thing was to throw it on its orbit, now its going well
yoyo
this is silly low effeciency of all components and looses make this way under OU
AbbaRue
@James Hardy Thanks for the response!
I can understand why you find yourself swamped with emails,
maybe it would be easier to answer everyones questions using this forum.
You can just send people here to read the answers instead of emailing individuals.
Would save you a lot of time.
4Tesla
Some were wondering how much power the pump is.. it is rated at 300W.  I found one close to the one that was used.  So the pump and 60 watt light bulb is a total of 360 watts that the generator needs to generate.
http://www.plumbersurplus.com/Prod/EBARA-EPPD-3MS1-PRO-DRAINER-Manual-Sump-Pump-1-3-HP-1-x-115/10116/Cat/689
Jason
4Tesla
More info for people that would like to calculate things.. I found a 1000W ICE generator that requires a 2.5hp ICE.  It rotates at 3600rpm..
http://www.bestchoicemart.com/12wamaxgage.html
Jason
