Thane Heins Perepiteia.
CRANKYpants
Quote from: waterhouse24 on July 22, 2008, 03:45:40 PM
Nice work Thane!
Looking forward to some nice pictures of the setup.
The OU is starting to taste SWEET! ;)
DEAR WATERHOUSE,
IS THAT HOUSE BOAT OR OUTDOOR WATER CLOSET? :D
ANYWAY I UPLOADED SOME PHOTOS FOR YOU HERE:
http://www.megaupload.com/?d=17RP9ZYV
CHEERS
Thane
waterhouse24
Quote from: CRANKYpants on July 22, 2008, 09:09:49 PM
DEAR WATERHOUSE,
Thane
nope just a house on water ;)
JustMe
BEST TRANSFORMER RESULTS YET!
DEAR ALL,
PLEASE FIND ENCLOSED WHAT I CONSIDER THE BEST PHOTO DATA YET!
INPUT VOLTAGE = 38.13 VOLTS
INPUT CURRENT = 0.02 AMPS
POWER FACTOR = 28.6 DEGREES OR 0.876
INPUT POWER = 0.668 WATTS
OUTPUT = 10.75 VOLTS OR 1.16 WATTS
EFFICIENCY = 174%
PLEASE NOTE THAT THIS IS NOT THE BEST "BRIDGE" BUT A MAKE SHIFT MASH-UP - HOWEVER THAT BEING SAID - EVEN IF THE POWER FACTOR WAS 1 (WHICH IT CLEARLY IS NOT) AND THE CURRENT WAS 0.03 A - IT WOULD STILL BE OVER UNITY.
CHEERS
Thane
CRANKYpants
THANKS JM!
NOW LET'S TAKE SOME LIBERTIES WITH THE ABOVE PHOTO DATA
1) ASSUME POWER FACTOR = 21.6 DEGREES OR 0.93
INPUT POWER = 0.71 WATTS
OUTPUT POWER = 10.75^2 / 100.5 = 1.15 WATTS
EFFICIENCY = 162 %
2) ASSUME INPUT CURRENT = 0.03 AMPS
INPUT POWER = 1.01 WATTS
OUTPUT POWER = 1.15 WATTS
EFFICIENCY = 114 %
3) ASSUME INPUT CURRENT = 0.03 AMPS & POWER FACTOR = 0.93
INPUT POWER = 1.06 WATTS
EFFICIENCY = 108 %
I AM IN THE PROCESS OF REWINDING THE TRANSFORMER WITH A LARGER HIGHER GAUGE WIRE AND SECONDARY CORE WHICH OUGHT TO DIVERT EVEN MORE BACK EMF INDUCED FLUX - THIS WILL HAVE A TWOFOLD EFFECT OF LOWERING THE POWER FACTOR AND LOWERING THE INPUT CURRENT.
CHEERS
Thane
springfield
Quote from: CRANKYpants on July 23, 2008, 10:33:51 AM
EFFICIENCY = 108 %
CHEERS
Thane
@cranky,
Very impressiv - thats overuntiy!! Just to make sure nobody can dispute it how about using a more accurate meter to measre the inpout current? That clampmeter is only accurate to 3 digits so if its reading 0.02, then the real numebr could be as high as 0.05, which would then NOT be overuntiy. So getting the  proof needs a better meter - how about that grey bench meter in the earlier photos - it also measures pf directly. ITs headline news if you can get the proof measurements.
- Mike
