0 Members and 27 Guests are viewing this topic.
starcruiser
@ Helmut,
IRAN has something the US wants, what it is is not OIL, they have IRAQ for that. A Stargate perhaps or are they working on one and the US wants them to stop?? I know this is out there but...
Quote from: helmut on August 02, 2008, 04:46:21 PM
I would do my laptop  and my credit cart  into the microwave oven. It seems to be a save place.
Ones i put my cellphone inside to test the MW oven against leakage. I was surprised.
The cellphone was not able to receive any signal.
About Iran.
1) They do not have the transport rockets for such a distance
2) They do not have plans to attac USA (i never read about such plans,but read very offen,that israel or USA are planing to
do a preventive strike)
3) As i know, they do not have nuclear warheads. So whats the hype about?
Carl
forest
Quote from: lumen on June 25, 2008, 10:00:01 PM
Under a strong "B Field" the carbon atoms align perpendicular to the impending electron flow. This allows spaces in the carbon for extra electrons to accumulate. As the current increases, the carbon produces a field perpendicular to the carbon rod and the "B Field". When the field in the carbon overtakes the "B Field" the carbon atoms again change direction closing the holes and forcing the accumulated electrons out in the opposite direction of the current flow. This causes the current to go even higher and forces out even more electrons causing the current to go higher continue to flush all the previously trapped electrons in an avalanche. The toroid simply captures the magnetic surge as a large field pulse like a simple single wind on the coil.
The reason it works is because the carbon under the "B Field" can easily be saturated with electrons, then when the field changes direction the carbon works like a battery forcing the stored electrons against the in rushing current. This is typical of all diamagnetic material but shows more in carbon because it is one of the stronger diamagnetic materials.
Interesting.Do you have any source of this information ? I believe it may be true. Do you think that this effect keeps electrons inside carbon rod and only point of release of them is a carbon tip which is perpendicular to both external and internal B-field ? This would explain why so little beta radiation is scoped AROUND carbon, while carbon may be acting like a cannon. Take a look at Edwin Gray patent, copper grids are strangely not around carbon rod but opposite to carbon rod. Also vacuum diode/triode is basically a source of electrons and commutator acting like a switch among two electrical paths.
AhuraMazda
@starcruiser
You are very right. Afghanistan, Iran, Iraq were once the Persian Empire and are parts of the same jigsaw. Bush said that US is not in Iraq for oil and I believe that.
Quote from: starcruiser on August 05, 2008, 07:32:49 PM
@ Helmut,
forest
Quote from: mikewatson on August 05, 2008, 05:08:06 PM
Continuing post 817, I have done the test with two (pure) carbon rods alone without any thoriated tungsten. The carbon rods are in light contact. I have got substantially the same hump effect as reported in post 817, so it works with carbon alone.
I repeated the test again with one single continuous rod of carbon and got a smooth waveform from the capacitor discharge without any humps and no sign of the saturable reactor going out of saturation so a single continuous carbon rod does not work, a spark gap is needed, a lightly touching contact being enough. The spark gap no matter how small is needed to generate the reverse current needed to get the humps on the waveform.
Mike
Excellent! Thank you. Reverse current idea match exactly with Edwin Gray patent.
I'm impressed....
forest
Reiyuki
I fixed up the concept a bit.  Should have the rest of the components for it soon enough.  Most parts are simply borrowed from a Tesla Coil I built a while back.
Before I actually go about building this, is there any reason why this setup shouldn't work, assuming the VSG hypothesis holds true?
- 2kv+ voltage
- High-joule pulses
- Fast switching (sparkgap)
- Neodmium magnet B-Field
- 'Extra' B-Field provided by circuit charging
- AC (no inductive losses)
And my personal favorites:
- NO silicon circuitry to burn up
- Closed-loop operation after initial pulse
I'd like to suggest anyone else that's built a Tesla Coil to order up some carbon and a toroid transformer and give this thing a shot, too.
- Rei
     (PS: Apologies for using MSPaint, but you know the rule, function before form)
