First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
0 Members and 32 Guests are viewing this topic.
nitinnun
clockwise spin,
plus counter-clockwise spin,
equals electricity.
water generates more CW, than CCW
(from 2 diamagnetic hydrogen atoms)
sand generated more CCW, than CW.
(from 2 paramagentic oxygen atoms)
CW builds up in positive clouds.
then rain drops conducts CW down to earth, as lightning.
electricity spins CW AND CCW.
hydrogen atoms in water conduct CW, but not CCW.
oxygen atoms in water conduct CCW, but not CW.
water conducts CW and CCW, WITHOUT merging them together into electricity!
(like copper wire merges them together)
CW energy is not readable by electronics!
(people mistake CW energy, as orgone/ether/whatever)
CCW energy is not readable, by electronics!
(people mistake CCW energy, as negative-emotions/curses/mortal-terror/whatever)
only electricity, is readable by electronics!
(CW mixed with CCW. both discharging each other, out of existance)
water allows CW to build up in copper, and CCW to build up in steel.
salt REALLY conducts CCW. so saltwater conducts even better than water.
saltwater does corrode the metals.
but the energy, comes from CW from air, and CCW from the earth. not "just" from corrosion
atlantians used gold as the positive, and copper as the negative.
gold and copper were more resistant to saltwater, yet still conducted the clockwise spin and counter-clockwise spin.
atlantians compressed saltwater, to make it an even more efficient conductor of CW and CCW.
vibrations in grand gallery, excited saltwater. making saltwater an EVEN MORE efficient conductor, of CW and CCW.
atlantians split saltwater, with hydrolysis, in queens chamber.
then pumped oxygen outside, and pumped hydrogen/sodium into grand gallery.
hydrogen/sodium, was better CW/CCW conductor, than saltwater.
hydrogen/sodium also corroded metals slower, than saltwater?
antenna for CW, and antenna for CCW, were both in grand gallery.
both antenna's touched the same body of hydrogen/sodium.
CW antenna sat at top of grand gallery.
CCW antenna, was moved from bottom of grand gallery, to top of grand gallery.
the closer the 2 antenna's got, the less amperage loss between them.
the space between them, was used to control how much amperage was produced.
when an atlantian was recharging his motorcycle, CCW antenna was at bottom of grand gallery.
when an atlantian was recharging his bus, CCW antenna was in middle of grand gallery.
when an atlantian was recharging his floating gunboat of death, CCW antenna was at top of gallery, right next to
CW antenna.
nitinnun
i came up with a new pyramid design.
i think it works very similar, to thomas trawogers.
i am very certain that he had a wire running from his steel frame, into the saltwater in his copper loop.
thus making his pyramid function like my schematic.
nitinnun
i made a better pyramid schematic.
CCW spins horizontally, in the steel sheet cap.
CW spins virtically, in the 12 copper turns.
nitinnun
i just realized what the floating peak, containing the all seeing eye, on the back of the dollar bill means.
when you combine CCW from the peak,
with the CW in the "eye" in the middle of the pyramid,
you get electricity.
the floating peak, represented the CCW collecting steel peak.
the all seeing eye, represents the CW collecting copper ring.
and when you combine "peak" with "eye", you get electricity!
by the way. in ancient egypt, snakes represented clockwise spin and counter-clockwise spin.
if the snakes head was looking right, than that snake meant CW.
if the snakes head was looking left, than that snake meant CCW.
both snakes were kept sepperated, at all times. as shown by the bulbs around them in that one heiroglyphic.
except when mixed together, to create electricity.
nitinnun
thomas trawogers copper loop, was a water cell!
the steel screw was electrically connected, with the saltwater in the copper loop!
the connection went copper pipe,
saltwater,
copper wire (inside top of copper loop),
steel screw,
copper wire,
capacitor.
i had this missing link, the moment i stuck copper wire and steel wire, into a bowl of water.
the steel frame acted as the steel-sheet peak.
the steel frame was electrically sepperated from everything, so that it could dedicate all of its energy, into cramming CW into the copper loop in the middle.
