Stanley Meyer replication with low input power
Started by hartiberlin, August 18, 2007, 04:39:57 PM
xbox hacker
Quote from: capacitor70 on August 18, 2008, 10:20:58 PM
How many people successfully replicated Mayer's cell ?
I have done lot of R & D on Mayer's bifillar coil, but not a single coil worked for me. Ravi says he is using step up transformer 200:600 ratio for his cell.
Dave lowton video shows without coils nearly same output can be obtained. bifillar coil is not much important.
What I see in my research is conditioning of tube is very important I have taken multiple trials of conditioning at high current, low current and Dave lawton steps for conditioning, After conditioning of tubes output of gas goes very high and current requirement goes low. But pulsating input is required to get best results after conditioning....
Pictures
1. Conditioning at high current (after long time blocking problem occurs, easily breaks, powder like coating)
2. Conditioning using Dave Lawton Steps. (Hard non conductive uniform coating)
The step up transformer and some tubes are all i need now. I was thinking about useing that DC-DC cap charger we were talking about....do ya think that will work in place of the Step up Toroidal Transformer??
The Dave Lawton vid also shows the use of the "modified alternator" method thats why their is not coil (but the alternator is like a coil)....Ravi used the Coil method. Personally i think i would rather have the coil one compared to a motor running a alternator on my bench.
xbox hacker
sbeehre
when you say Dave Lawton steps do you mean the ones in the D14 PDF? if so how long did it take to get to that stage? the cell that a friend and i have built is almost done except for conditioning and atm we get low gas rates. We are using a toroid step up transformer going into a 100 turn bifilar wound coil over a ferrite rod with a blocking diode on the positive wire. I'm thinking that conditioning the tubes is all we need to do now to get much higher gas rates....
capacitor70
Basically Step up troidal with rectifier and capacitor makes DC-DC converter.
Yes
sbeehre
Quote from: capacitor70 on August 19, 2008, 01:13:21 AM
Yes
and how long did it take you?
