goldenequity
Greetings all.........
take a look at this.... a plasma circuit (Tero design) running a 4 stroke motorcycle..
plasma demo
http://www.youtube.com/watch?v=y5zh12n0lEg
engine running (smooth!)
http://www.youtube.com/watch?v=DXFMIfcOo_I
no, not water.... gasoline on plasma
Congrats to revizal!!!!!!!!!!!!!!!!!!!
nul-points
hi Luc
apologies for late reply, i've been away for a few days
> Hi Sandy, are you saying we use the top of the piston as our ground Electrode?
yes - i'm just wondering if this is why we're not seeing much evidence of an explosive force around the plasma on contact with the water: because the force is along the current - and usually the spark occurs between the two rigidly fixed electrodes of a commercial spark plug
i appreciate what Gary is saying about oil insulation and piston/cylinder pitting - i'm not suggesting that sparking to the piston is an acceptable end-solution - just that we try to fully understand what is really happening with this effect before dropping it because it seems like a dead-end
a new method of applying force may require a new method of capturing it (eg. direct drive onto 'flywheel' type crank from multiple discharges?)
ok, perhaps unsuitable for direct ICE application, but could we miss discovering a new drive technology as a result?
just a thought
all the best
sandy
Doc Ringwood's Free Energy site:
  http://ringcomps.co.uk/doc
pese
Quote from: Dread on August 29, 2008, 07:48:13 AM
I sent this Q to Aaron but he might be busy.
@ everyone.
Would this modification to the Aaron circuit, with X-box's 1/2 wave voltage doubler work?
I don't think I can send the increased voltage through the relay without problems but I can still get it to where it counts most.
D.
This 100 Ohm Resitors are to high !
Will burn !!
about 5 ohms is ok
PESE
foxwhisper
Hi all,I was wondering if anyone has performed actual underwater "explosions" ( not mist or vapour ) with a high intensity arc? Any feedback re method & results would be much be appreciated. Perhaps an approach in this direction may be worth investigation in harnessing the shockwave energy in another way. FW
GrawpSVK
Quote from: foxwhisper on September 01, 2008, 08:01:12 AM
Interesting. I have been thinking about the same.
Did you know that plasma arc in water can cause mechanic cavitation? I know that NASA was studying this during freefall (of airbus).
