Complete information on working SM style device.
Started by spherics, March 17, 2008, 12:03:53 AM
Grumpy
http://arxiv.org/abs/hep-th?papernum=9608038
This is for the one person that will understand what this paper implies and garner knowledge from it.
PDF link is in upper right and is free to download.
        -Frank Edwards
mflynn44
Quote from: poynt99 on September 01, 2008, 04:22:14 PM
Towards Realizing the TPU v1.2
CHAPTER 1
- Added simple table of contents to give an idea what's coming next
http://www.overunity.com/index.php?action=tpmod;dl=get110
Thank you Poynt99 for your excellent write-up. You've motivated me to continue work on the Spherics design.
sparks
   Below diagram shows tetrahedral packing.  It also shows a 5th coil.  Hope it helps.  Nice work.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Grumpy
@ P99
You are correct that the fields are perpendicular to each other.  This may also account for why devices with 90 degree control coils are unstable - like Marinov's MAGVID.
The threee fields that you term "A", "B", and "C" are reffered to as "tempic",  "electric", and "magnetic" by Wilbert Smith.
First there is the "tempic" field, which is "scalar" and has a single dimension like temperature - be we can think of it more like "density".  This field determines the rate of entropy for manifestation in reality - i.e. time.  The other two fields can not exist without this field as it is the fundamental one.
Then there is the electric field - which contains the tempic field as an integral part of it - this field is the divergence of the tempic field - so we now have two dimensions - pressure and direction.  Funny that this field always terminates on conductors.
Then, perpendicular to the tempic and electric, is the magnetic - which is the curl (hence closed) of the tempic field.  Funny that this field likes to be closed.
As for the other form of induction, there is more than one type of current and they all produce a magnetic field when produced with mass charges - but what if they are produced with "virtual" charges?  There are convection currents (the Rowland Effect), conduction currents (Maxwell/Faraday EM induction), and displacement current (theorized by MAxwell, proved by Roentgen and Eichenwald).  By the way, Roentgen did not allow the use of the word "electron" in his institute.
The three currents and all that can be better understood when you look at all the three fields together:
            Tempic
       Electric Tempic
Magnetic Electric Tempic
So, we see that manipulation of the tempic field affects the other two and that they are all connected and tempic is the fundamental field.
So, if we wanted to see what effect each field has on the other, we look at our little pyramid and compare this to the three currents and get this:
(side note:  I also have scribbled notes on a "current of dielectric convection" which is related to a rotatable field arrangement - I won't get into this here and good luck finding much on it - also referred to as a "convection displacement current")
Here's how it all fits:
1.  magnetic field acted on by a tempic field (i.e. changed or moved) produces a transverse electric field (M^T=E)
    (field decreases with distance)
2. electric field acted on by a tempic field (i.e. changed or moved - even if virtual charge) produces transverse magnetic field (E^T=M)
    (field decreasese with distance squared)
3. magnetic field acted on by electric field (i.e. changed or moved) produces transverse tempic field (M^E=T)
    (field decreasese with distance cubed)
Looking closely at number 3 - we may wonder if this transverse tempic field also produces the the other two - of course it does.
Comparing this to the tetrahedral-TPU, we use an electric field to create a changing tempic field to create a changing magnetic field which is not "mass-based" since the charges are virtual, and this induces power in a conductor that occupies the same space as the field - hence two rods will work or a toroidal coil.  We can rotate the field as fast as we can switch it and like he said, the field lingers so it is compressed again and again and again - and with every compression maintian the gain we have - 1:1000 in/out is reasonable.  Increase the speed and we increase the rate of gain - if we can maintain it.  See, in the space occupied by the field, entropy (or time) is at a different rate.
You put in a second and take out a half-hour at seconds rate - running with gain - that ain't workin' - that's the way ya do it - money for nuthin' and your chicks for free...
So, the compass only spins until the field is closed on itself, then the center of the ring becomes a void and the compass stops.
        -Frank Edwards
Peterae
@ Grumpy
Yer but does it work, I take it from your in detailed explanation you have built it and got it working and have now worked out how it works?
