Can someone smarter then me tell if this will work?
Started by MacGyver, August 21, 2006, 03:49:35 PM
tbird
hi MacGyver,
from your statements above it sounds like you will need enough force to turn all disks.  will that get you any closer to your goal?
maybe you should have a look at this guys unit
http://peswiki.com/index.php/Directory:Paul_Harry_Sprain_magnet_motor
there are many others you can read about too that might help you down a productive path.  i know it takes a lot of time to go thru all the material, but in the long run it will save you time, frustration and money.  try not to reinvent the wheel before you know how the current ones are built.
keep up the enthusiasm!!
tbird
It's better to be thought a fool than to open your mouth and prove it!
Jdo300
Hi MacGyver,
It sounds like what you are making is more or less like a magnetic gearing system where the force on one disk is transfered through the magnetic field all the way around the circle. in this case, whatever input you add would probably be eaten up by the friction of the rotating disks. You'll need some way to permanently unbalance the fields for the design to work, otherwise there won't be a constant sink for the wheel to want to rotate towards. e.g. the dog chasing it's tail analogy :-).
God Bless,
Jason O
wizkycho
Quote from: MacGyver on August 21, 2006, 03:49:35 PM
I've never built any permanent magnet motors, I stumbled onto your forum yesturday and had an idea to get over what you all call locking.
If you've seen it before, let me know that too.
Ok, I can't draw, so no pictures, but I'll try to describe what I'm thinking of.
First, setup like most others i've seen with say: 16 cylinder magnets in the outer edge of a rotating disc, so that the pos. is on one side and the neg. is on the other side, depending on size, take say 16 of these discs, and put them on a shaft thats curved into a full circle, do the math so that the disc to the right of each one is set just before the locking point, do the same all around the doughnut, so that each plates magnets are repeling the plates next to them, I think the total number of plates may have to be odd though. +--++--+
Anyway, each plate wants to push the plate next to it away (rotate away), and this folows around the circle back on to itself, which would keep going.
I don't know if alot of plates would be needed to make the angle to each other less, or if the edge of the discs inside the doughnut would repel enough on their own.
Can someone tell me the reason why this is wrong.
Almost forgot, perhaps a sort of ratchet on each disc, so they only will rotate one way.
Sorry.
Nice idea with two major problems. Very expensive and if it would work it wouldn't work for long because
You are using repell forces (push) which will eventually "deplete" magnets. If you make magnets more distanced
you won't "deplete" them that fast but will get very low energy output.
Other disadvantages - this would be very heavy and big.
but don't get discouraged... keep on thinking
Igor
Perihelion Labs
MacGyver
Thanks for all the input, I think I'll look online for some neodymium magnets and play around (hopefully without loosing many fingers in the process).
Also, I searched the forum and was unable to find any discusions on meta-materials (left-handed) here, I was wondering what the size of the split ring resonators in an array would have to be to manipulate a magnetic field.
Thanks again for all the input.
mikestocks2006
Quote from: tbird on August 21, 2006, 07:31:27 PM
hi MacGyver,
tbird
A video of the machine running. Do they claim power input to the solenoid is less than can be created by the
machine's rotary motion?
http://video.google.com/videoplay?docid=2703180506289064827&q=free+energy&hl=en
If Steorn's concept is proven to work as claimed, maybe a shield/magnet arrangement would do the trick?
